Thread: Detaching and Reattaching Throttle Cables to L67 Throttle Body
Results 1 to 14 of 14
  1. #1 Detaching and Reattaching Throttle Cables to L67 Throttle Body
    Donating Users
    Jan 2013
    Huntsville, AL
    Hi all,
    As I recently replaced an ailing throttle body and encountered some difficulty removing throttle cables (being afraid to break anything plastic), and as I got help from the community to do so, I thought I would make a formal write-up detailing my experience so future newcomers can do this job with confidence.
    I've never written a how-to before, so please be nice, or be mean with creativity
    Experienced folks, please feel free to edit for readability. EDIT: I believe this information is valid for 1997-2003 Grand Prix GTP's.
    What we're doing:
    Two throttle cables attach to the throttle body (TB) of an L67 (supercharged 3800) engine. One is from the accelerator pedal, and the other is from the cruise control (CC) module. Both do the same thing - they pull to open the butterfly valve inside the TB, allowing more air into the engine. We're detaching both of them, a necessary step in removing the throttle body in order to replace it or clean it thoroughly away from the car.
    Notes:
    I wouldn't do this if it's very cold outside as it's much more likely for the brittle plastic clips to break.
    Take it slowly and don't break anything you can't unbreak.
    Let's go:
    Remove the sight shield (engine cover) if you keep it installed. (I've removed mine to help keep the S/C cooler).
    Start by removing the 10mm nut atop the shield:
    Unscrew the oil filler neck, not just the cap but the entire cap and neck assembly:
    Remove the sight shield:
    To keep dust out of the crankcase, screw the oil filler neck back in. I also screw the 10mm nut back on to prevent losing it.
    This is the throttle body. The oval above and to the right encircles the throttle cables:
    Here is another view from the driver's side:
    These are the throttle cables up close:
    We first need to detach them from the black metal bracket, then from the throttle body itself. A plastic tab holds each cable firmly to the bracket:
    Here is a better view of the CC cable's plastic clip, on the right. The accelerator pedal clip is on the left but is hard to see from this angle. See next photo.
    Here is a better view of the accelerator pedal cable's plastic clip:
    Remove the CC cable's clip by GENTLY pressing in the plastic tab with a thin instrument such as needlenose pliers, then pulling the entire clip straight up. Turn it CCW slightly (looking down from above) as you pull up to help liberate the plastic tab:
    Remove the accelerator pedal's clip the same way, also turning it slightly CCW and pulling straight up:
    Now the clips have been released:
    Remove the bracket. It's held in by two 10mm nuts (view from firewall looking toward front of car):
    Lift away the bracket. Now pull the rotating metal assembly of the throttle body toward the driver's side of the car to slacken the cables. Hold it there:
    The CC cable detaches simply by pushing firmly away from the direction of the cable:
    After detaching:
    To detach the accelerator pedal cable, start by derailing it from its circular track:
    Next, still holding the rotating throttle assembly at full throttle (toward driver's side), use your thumb to begin lifting the accelerator pedal cable upward:
    Keep going until you can pop the end of the cable out to the right:
    Done!
    You can now completely remove the throttle body or replace throttle cables.
    To reattach the cables, follow these steps in reverse order.
    Feedback and suggestions welcome!
    Thanks,
    Komrad36
    Last edited by komrad36; 04-29-2017 at 09:21 PM. Reason: Fixed broken image links.
    1998 Grand Prix GTP. Open cone intake, ZZP downpipe, dogbone flip.
  2. #2 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    I am pretty sure the 03s used the same tb and cables.
  3. #3 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    That is one clean engine!
    Official GPF Red Neck
  4. #4 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    Donating Users
    Jan 2013
    Huntsville, AL
    Updated with crossover info. Thanks slick2500!
  5. #5 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    Donating Users
    Jan 2013
    Huntsville, AL
    Quote Originally Posted by TwiztdWun View Post
    Thanks!
    Trying my best. Still stock-ish except coupler replace and open cone.
  6. #6 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    Apr 2017
    Woodinville, WA
    Am I missing pictures? I don't see any.
  7. #7 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    I don't see any either.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  8. #8 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    Donating Users
    Jan 2013
    Huntsville, AL
    Sorry about that! I was using ImageShack to host those images; it looks like they stopped providing free hosting. I've switched to PhotoBucket and updated all the links. All the images should be working now.
  9. #9 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by komrad36 View Post
    They work and they are NOICE!! Good job, man.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  10. #10 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    Donating Users
    Jan 2013
    Huntsville, AL
    Thank you! From the ImageShack website it looks like the links were broken for a long time. Nobody told me!! Haha.
  11. #11 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    Apr 2017
    Woodinville, WA
    Great
    Thanks komrad
  12. #12 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    **** imageshack. ****ing pricks, provide a service for free for years than up and decide to start charging for the service and just deleting any images that aren't paid for. **** you I hope you stupid ****s go bankrupt.
  13. #13 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    ^ LOOLOLooOOLll!!!
  14. #14 Re: Detaching and Reattaching Throttle Cables to L67 Throttle Body
    They didn't even offer a limited free account, just a 30 day trial. I had hundreds of pictures on there that are now just gone. Supposedly they sent out emails saying that they were going to delete the images that weren't on paid accounts, but I never got an email from them about it. I didn't even get an email saying that they were going to start charging for image hosting.
    I can understand them wanting to charge for their services, those servers aren't cheap, but they way they went about it was just shady. Why not limit the free accounts to X amount of storage, then offer premium accounts with additional storage space?
  1. Throttle body
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 06:43 AM
