I figured out some valuable information and thought I would share it with you all.
Issue: Cooling temp constantly changing from around 210* to 180* and back to 210*. When at 210* there is no heat inside the car, but when it drops to 180* there is heat inside the car.
Solution: If you have worked on ANYTHING that requires messing with ANY part of the cooling system, you must bleed the air out of the cooling system using the bleed screw on top of the thermostat housing. Failure to do so will result in an air pocket forming in the top of the engine which can cause the thermostat not to open resulting in the car overheating. You can also have steam pressure in the top of the engine build up enough that coolant will not flow through the heater core inside the car causing you not to have heat in the cabin.
The car should be cool when adding fluid. Take off the radiator cap and top off the radiator, then start the car. Open the bleeder screw about 1 full turn. As soon as you see coolant dribble out, close the screw and top off the radiator again. Open the bleeder screw again about 1 full turn, close it when you get a steady stream of coolant coming out of the bleeder screw. Top off the radiator one more time and replace the cap.
Hope this helps you guys
webracin
