Thread: How to install your WBS Intercooler
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: How to install your WBS Intercooler
    hangover park IL
    its a toyota pos
    ~James~ Psychotic Gearhead
  2. Thanks Welderman thanked for this post
  3. #42 Re: How to install your WBS Intercooler
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Where can I get this relay for an IC install?
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  4. #43 Re: How to install your WBS Intercooler
    Mercer, Pa
    Look up 12volt relay on ebay and get lots of hits even with a wiring harness. Radio Shack also has them but will cost 10 times more.
  5. #44 Re: How to install your WBS Intercooler
    Jun 2013
    United States
    I'm installing a zzp short stack and was wondering about sealing the coolant passages with dimes? I heard of this when my buddy did his years ago but is it a necessary thing and where are they? Are they the wholes where the yellow orings are? Thanks!
  6. #45 Re: How to install your WBS Intercooler
  7. #46 Re: How to install your WBS Intercooler
    if you seal the two ports off you want to hog out the H from the side cover to let the coolant flow better.
    like this.
  8. #47 Re: How to install your WBS Intercooler
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Is it necessary to modify the the LIM with an inter cooler install?
  9. #48 Re: How to install your WBS Intercooler
    you should at least plug the coolant holes and hog out the coolant passageway. at that point whats opening up the hole to match?
  1. intercooler install
    By jrock in forum General Tech Discussion
    Last Post: 06-07-2012, 05:49 AM
  2. intercooler install
    By JROCK1987 in forum General Tech Discussion
    Last Post: 02-23-2012, 06:21 AM
  3. intercooler install questions
    By screamingreenmonster in forum General Tech Discussion
    Last Post: 05-17-2010, 05:17 PM
  4. How to install stage three intercooler?????
    By GINOSGTP in forum General Tech Discussion
    Last Post: 02-25-2009, 07:52 PM
  5. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
