Thread: Adding HUD and a DIC to your 97-03 GP
Page 8 of 9 FirstFirst ... 6789 LastLast
Results 141 to 160 of 167
  1. #141 Re: Adding HUD and a DIC to your 97-03 GP
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by KoldAsIce View Post
    OK I have a 2001 GP GT and it has a DIC in it but it's just the picture of the car for the door lights etc.. I want to change it to the DIC with the MPG, oil life all that good stuff do I need to splice any wiring for this or is it just a swap? I did read the first few pages but I just want to make sure before I spend cash on it if it's not going to work! And my father had a 2003 GTP and I didn't find the HUD to be worth the money or time to drop it in a GT it's actually kind of annoying IMO. Thanks
    You would need to remove your dash to see if you have the connectors already there. If not then you will need to splice. It is not that difficult to do. Just follow the connections on the first page. As stated you want a DIC from a 98-02. The 97's need 97's and the 03's are slightly different and it is recommended to stick with an 03. You also want to get the GT digital DIC. If you get one from a GTP the traction light will be on. This can be easily fixed with this write up ClubGP:
  2. #142 Re: Adding HUD and a DIC to your 97-03 GP
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    Well my traction lights on anyway lol but yea it's not that it's hard just I'm disabled and I can't use my right hand the best so I'm afraid if it's like very dexterity needed I won't be able to do it but I'm gonna get a GT one pointless to get a GTP if I'm gonna spend the money anyway and I will see if I have the connections if not maybe I can use those wire taps.. The blue connectors that you crimp and it links them up.. If I make any sense lol
    I was thinking since I've gotta take the cluster out I might as well change the bulbs to LED 1 of the bulbs is out but it's not that big of a deal but like I said being I have to anyway might as well! There should be no power issues swapping to LEDs right? I know there is a red film so pointless to make it another color but I was thinking super white LEDs and I assume the #74 bulbs just leave stock.. I know this isn't the place to ask this but I assume you or someone on here knows about this thanks!
  3. #143 Re: Adding HUD and a DIC to your 97-03 GP
    Mar 2013
    Staten Island, NY
    In case anyone is looking to add a HUD to there car I found someone selling a dash with the HUD hole for $60!
    97 98 99 00 01 02 03 Grand Prix Heads Up Display Trim Panel Grey | eBay
    I was gonna get it but I don't need the HUD no big deal to me so I'd rather a fellow GPer get it!
  4. #144 Re: Adding HUD and a DIC to your 97-03 GP
    Dec 2012
    troll land
    i installed an 02 gp gt hud in my 97 monte carlo
    Quote Originally Posted by l67ss View Post
    kinda curious about how hard it would be to convert a 97 monte carlo to gp hud
  5. #145 Re: Adding HUD and a DIC to your 97-03 GP
    Jan 2013
    United States
    What about doing this on a 2007? I already have the full dic I just want to add the HUD.
    Sent from my Galaxy Nexus using Tapatalk
  6. #146 Re: Adding HUD and a DIC to your 97-03 GP
    Dec 2012
    troll land
    The hud is easy. Hardest part is making the hole in the dash
    Quote Originally Posted by sevenhellz View Post
  7. #147 Re: Adding HUD and a DIC to your 97-03 GP
    Jan 2013
    United States
    Well I could buy the top dash price for HUD off a 2008 for $60 and that already has everything cut with the glass over top
  8. #148 Re: Adding HUD and a DIC to your 97-03 GP
    Jan 2013
    United States
    Its more about does my car have the cables already there to hook it up or would I need to wire everything myself, will my pcm know to even send that type of info out for rpms and speed to the HUD?
  9. #149 Re: Adding HUD and a DIC to your 97-03 GP
    Dec 2012
    troll land
    Dont kno if the wires are there. As for the pcm , all the hud is is a fancy cluster. So yeah itll work fine with the pcm
  10. #150 Re: Adding HUD and a DIC to your 97-03 GP
    Jan 2013
    United States
    Last question, I found a HUD off a 2007 grand Prix but no wires or anything it's just the unit. Do I need any other wires?
  11. #151 Re: Adding HUD and a DIC to your 97-03 GP
    Dec 2012
    troll land
    You need the plug and at least a few inches of wire coming out of it if your car doesnt have it. I know that on 97-03 gps its kinda a crapshoot if it has the plug, unsure on 04+. If it uses the same plug as the earlier hud i have spare lug i can send yaif you dont have the wiring already
  12. #152 Re: Adding HUD and a DIC to your 97-03 GP
    Jan 2013
    United States
    I appreciate that. Im gonna take my dash off next time I get a day off and loom
  13. #153 Re: Adding HUD and a DIC to your 97-03 GP
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Been reading through the whole thread. Great information. Forgive me if I miss somethings, but it is such a long thread it might not hurt to revisit, at least that is the excuse I am trying to use. :-)
    My question may be best broken up into two areas, one cosmetic the other interfacing. For now to narrow the context I am going to ask from installing a DIC, but can be expended to HUD and maybe something custom.
    Interfacing:
    Sounds like I maybe boxed into a corner, since I have a 97 GP GT. In my shelter life all I have ever seen is analog DIC on my 97, 02 SE, 02 GP. Once I moved into the 06 (two of them), 07 GXP then I saw a digital. After doing some googling I did see where someone was selling an earlier model digital. Looking at some of the names of the wires there seems a mixture of signals. Some are "a wire (bit on/off)" and "bus (communicated serial?)" I know you stress 97's only 97's. Is that because of connectors? It was mentioned because of "tire pressure" notification. What's/How is the sensor? What about using a latter model digital (cosmetic issue discussed in next section)?
    Cosmetic:
    Adding a round peg into a somewhat square hole? Of course the cosmetic is mute point if interfacing can not be worked out.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  14. #154 Re: Adding HUD and a DIC to your 97-03 GP
    GT Level Member mikejohnlewis's Avatar
    Jul 2014
    Manchester, Iowa
    how can i tell if my '97 is wired for the dic already?
    1997 Grand Prix GT 3.8(SOLD)
    2002 40th Anniversary Coupe GT (SOLD)
    2000 Daytona Coupe GTP (Summer Car)
    2011 Ram 1500 (daily)
  15. #155 Re: Adding HUD and a DIC to your 97-03 GP
    Mar 2013
    United States
    Quote Originally Posted by mikejohnlewis View Post
    i never did get an answer to my question. This may be a dead thread.
  16. #156 Re: Adding HUD and a DIC to your 97-03 GP
    Dec 2008
    Lawndale, CA
    Easiest way is to remove the dash and see if the wires are there.
  17. #157 Re: Adding HUD and a DIC to your 97-03 GP
    Jul 2014
    Manchester, Iowa
    I did this and there is another set of wires behind the non digital dic, its a large black connector.
  18. #158 Re: Adding HUD and a DIC to your 97-03 GP
    Donating Users
    Sep 2012
    LI, NY
    Excerpts from previous posts. Only 97s and 98s have the harness because GTP was a factory option on GTs for those years, rather than being a model of its own. The DIC harness should be on the side near the glove box. The HUD harness should be behind the analog display.
  19. #159 Re: Adding HUD and a DIC to your 97-03 GP
    Nov 2013
    Idk if I'm posting this right or not, but I have a question about installing both the DIC and HUD in my GP. I have a 97 SE and it has all the same options/connectors as the gt and gtp. So I cut the dash out and install the HUD and I got a DIC from a 97 gtp out of the junkyard. The HUD works and the DIC works but I'm getting flashing zeros after the car is on for a few seconds. Can anyone plz help with this, oh and I did not have to splice wire as the hookups were already there.
  20. #160 Re: Adding HUD and a DIC to your 97-03 GP
    Sorry.. never heard of flashing zeros.
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Thinking about adding a turbo
    By MS1227 in forum Turbo
    Last Post: 12-13-2008, 04:22 PM
  3. adding gauges
    By keenan00gtp in forum Visual/Body Modifications
    Last Post: 10-12-2008, 11:48 PM
  4. news question about adding performance shift
    By abuckley1290 in forum General Tech Discussion
    Last Post: 07-16-2008, 11:56 PM
  5. Adding acetone to gasoline
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2008, 01:24 PM
