Thread: How to change lower motor mount and trans mount
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 How to change lower motor mount and trans mount
    SE Level Member AlanP's Avatar
    Dec 2012
    Fair Haven, NJ
    Ok, I couldn't find any great write-ups on this. So now there will be.
    Tools needed:
    Jack Stands
    1" x 8" x 16" ish wood
    Real Jack (no scissors)
    15mm rachet AND open end 15mm
    17mm rachet
    #2 Phillips Head
    1. Remove the bolts from the upper motor mounts where they attach to engine. 17mm rachet. Pull the dogbones up.
    2. If you have a front strut tower bar you'll need to remove it too.
    3. Jackstand car on left AND right side of subframe.
    4. Take off both tires. If only doing motor mount u can leave driver side on and skip to step 10.
    5. Remove the 2 lower and 2 upper nuts from the trans mount. 15mm rachet.
    6. Put the wood across the oil pan and trans pan and bring the jack up to it. Make sure it is only on the pans and not any lines or the oil pan drain screw. The more surface area the safer you are lifting the motor.
    7. SLOWLY start jacking the motor up, checking to make sure it moves easily. Don't force anything. Once it is high enough to pull the trans mount out then do so. Clean the area where the mount was and put new mount in.
    8. SLOWLY lower the motor. Don't worry if it doesn't align with the new trans mount bolt perfectly. Once the motor is off the jack by at least 3 inches u can stop. If the bolt holes didn't line up u can GENTLY rock the motor and it will slip onto the bracket.
    9. Tighten the beejesus out of the 4 trans mount nuts.
    10. Back on the passenger side now. There's 2 plastic screws holding the splash guard on in front of the oil filter. Take them out and move guard out of way.
    11 Take the 2 bottom nuts off the motor mount. 15mm rachet. Now use a 15mm open end to get the nuts off the upper mount. Patience. If the nuts are oil grime coated be sure to clean them BEFORE unscrewing.
    12. Bring the Jack back up as in step 6.
    13. Lift the motor up enough to get the mount out and remove the mount.
    14. Clean out the grimy, filthy space the mount was in. EXTREME CAUTION putting your fingers under the motor. If the jack slips your fingers are GONE.
    15. Insert new motor mount, offset bolt towards front of car.
    16. SLOWLY lower the motor. Don't worry if it doesn't align with the new motor mount bolts perfectly. Once the motor is off the jack by at least 3 inches u can stop. If the bolt holes didn't line up u can GENTLY rock the motor and it will slip onto the bracket.
    17. Tighten the beejesus out of the 4 motor mount bolts. Yes, open end on the top bolts.
    18. Put the splash guard on, put the wheel on, take the car off the jack stands, put the upper motor mounts back on, put the stb bar back on. Close the hood. NO, WAIT!! Don't close the hood!! You're filthy and are gonna get fingerprints on it. Go wash first.
  2. Thanks destroyd 1gtp thanked for this post
  3. #2 Re: How to change lower motor mount and trans mount
    Nov 2012
    Madison
    Nicely done....awesome how-to......thanks
  4. #3 Re: How to change lower motor mount and trans mount
    Apr 2013
    bellevue nebraska
    I feel a "kicking" in front under the car, when I park on a hill or when i take off fast from a dead stop/foreward and backwards. could that be the mounts?
  5. #4 Re: How to change lower motor mount and trans mount
    GTP Level Member
    springfield IL
    I remember reading that some other different brand/style mounts cause vibrations, do you have you that with yours??.
    I'm pretty sure I'm needing both. I have started my car with the hood up and the motor shakes like an alcoholic.. Lol
  6. #5 Re: How to change lower motor mount and trans mount
    Dec 2012
    Fair Haven, NJ
    Quote Originally Posted by tc300 View Post
    I have very little vibration. Nothing upsetting. But then again my motor is smooth as a Rolex.
  7. #6 Re: How to change lower motor mount and trans mount
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    went and bought myself a 15mm ratchet wrench to get those top 2 nuts on the engine mount, much better and thanks for the how to.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  8. #7 Re: How to change lower motor mount and trans mount
    Jan 2013
    Buffalo,NY
    Very nice how-to. Plan on tackling this soon.
    Thanks
  9. #8 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    Very good write up might have to change out my motor mount
  10. #9 Re: How to change lower motor mount and trans mount
    Jan 2013
    Buffalo,NY
    Got this done this past weekend. No hang-ups. Thanls again for the guidance.
  11. #10 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    There's no way I can get a 15mm open end on the engine mount upper bolts my wrench won't even grab the nut any tricks I can use on my 05 maybe a slimmer open end wrench
    Sent from my SGH-T999N using Tapatalk
  12. #11 Re: How to change lower motor mount and trans mount
    Ocala, FL
    Quote Originally Posted by kurupt305 View Post
    Those are a pain to get a wrench on.
    A slim enough ratchet will work better.
    The first time I did a set I used an open ended wrench, it worked but was a pain. The problem with a wrench, is you can't go flat/straight at the bolts, you have to angle your wrench enough to get to the nut.
    The most recent time I used a craftsman max axess ratchet which made it a breeze.
    Only difference between this writeup and the way I do it, is I just turned the wheels to the left to do the driver side, and to the right to do the passenger instead of taking them off.
  13. #12 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    Might have to buy a slim 15 them because I can't get any bite on the nut
  14. #13 Re: How to change lower motor mount and trans mount
    i broke the top motor mount bolts free with a socket wrench, took it the rest of the way off with a open end wrench.
  15. #14 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    Theres no way to get a socket over my nut theres a stud blocking the socket from getting on
  16. #15 Re: How to change lower motor mount and trans mount
    let me clarify, i put the socket on the nut, then put the ratchet on the socket. you can only get a turn or two like this or it gets stuck in there.
    racketing box wrenches seems to be the best tool in the end tho.
  17. #16 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    Ill have to invest in a slim ratchet
  18. #17 Re: How to change lower motor mount and trans mount
    Jul 2010
    Coquitlam,BC,Canada
    A regular open ended wrench will work, but you only get about 1/8 turn, so it is a pain.
    Get a wrench like this and it is much easier:
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  19. #18 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    That wrench won't work for me as I believe my mount set up is different I can't slip on a closed end wrench as to there is something in the back obstructing it from going on
  20. #19 Re: How to change lower motor mount and trans mount
    that would be dirt, grease and grim. clean it up around the nut, try again.
  21. #20 Re: How to change lower motor mount and trans mount
    Jul 2010
    Coquitlam,BC,Canada
    I was thinking the same thing. Here is what I scraped out when I did mine......
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Need some help on Lower Motor Mount
    By Burbman in forum General Tech Discussion
    Last Post: 11-16-2012, 09:29 AM
  2. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  3. What does a Passenger Lower Motor Mount look like?
    By brenglen in forum Brakes/Suspension/Chassis
    Last Post: 08-07-2012, 05:32 AM
  4. Lower motor mount...
    By Iceman6669 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 02:23 PM
  5. changing lower motor mount
    By Jakegday in forum General Tech Discussion
    Last Post: 01-20-2011, 08:00 PM
