Thread: How to change lower motor mount and trans mount
Results 21 to 40 of 41
  1. #21 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    Sorry to bring this up but anyone with a 04 and up have problems woth this there seems to be a lip or tab in the way of removing the engine mount bolts ill upload a pic if I can on here uploadfromtaptalk1398780063383.jpg its upside down but as you see there's a piece of metal bracket in the way
    Sent from my SGH-T999N using Tapatalk
  2. #22 Re: How to change lower motor mount and trans mount
    unbolt both sides of the mount, then jack the engine and tranny up enough to slide the old mount out. you may need to lift the engine a bit higher to get the new one in.
  3. #23 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    Scotty I know that but im talking right byr the silver bolt that piece of metal gets in the way of an open end wrench if you notice the other pictures of other people changing the engine mount they don't have that piece of metal in the way
  4. #24 Re: How to change lower motor mount and trans mount
    Pennsylvania
    It freaks me out a little thinking about jacking the motor up by the oil pan. Im paranoid it's going to collapse or puncture... I know it's the most common way to do this, but that worry is what keeps me away from tackling this yet.
    Sport Edition Kv5 18x8
  5. #25 Re: How to change lower motor mount and trans mount
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    Use an offset wrench like this, it's what I use and I never have a problem with it.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  6. #26 Re: How to change lower motor mount and trans mount
    Jun 2013
    Hollywood ,FL
    I bought those thing is I can't get the wrench over the fwd bolt head due to the engine or something hitting it I need like a narrower thinner wrench or socket
  7. #27 Re: How to change lower motor mount and trans mount
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by FriboRage View Post
    Put a 12" long piece of 2x4 between the jack and the pan; spread the pressure out. Jack slowly and when the engine won't move, stop jacking.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #28 Re: How to change lower motor mount and trans mount
    i used a 2x6 or 2x8. a 2x4 is so narrow 3.5 inches wide only.
    unbolting the dog bones helps the engine to rise with less resistance too.
  9. #29 Re: How to change lower motor mount and trans mount
    GTP Level Member
    Aug 2012
    st louis park, MN
    A couple things to add to this thread, potentially for the 04+ guys.
    First, instead of wood, i use a hockey puck and placed it on either of the 2 black brackets coming off the oil pan. Choose the bracket on the side of the motor you need to lift.
    As far as i could tell you HAVE to have the offset 15mm wrench to get the motor mount done. The best i could do was about 1/8 or a 1/16th of a turn per bite, there's just no way to get another wrench on there. ALSO, the metal half moon opening above the forward nut was casted such that i couldn't get my wrench on the nut. I had to dremel out the half moon opening to get some additional space to get the wrench on.
    Anther item of note was that i didn't like how hard I had to jack the engine to get either side up and the mount out. I'm not sure what was taking the stress but hopefully just the other mount :/
    This was one of the easier jobs I've completed so don't be too intimated by it. You must be patient. All said and done, the old mounts looked fine and likely didn't need to be replaced. Try to visually inspect yours before assuming they are bad because of mileage - I'm at 100k.
    Edit: For sale - used motor mount and transmission mount
  10. #30 Re: How to change lower motor mount and trans mount
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    I finally did this after having the mount for years, always put it off because I was afraid of messing up my oil pan.
    I'm in process of fixing the little things that have been wrong with this car for a while. This is one of those things.
    This write was a big help. Thanks Alan!!!
    So jacking up the motor, yeah this is kinda scary. I for sure though I was going to fuk something up, pull the some wires, hoses etc lose. When I looked at the new mount before I was jacking the motor up. I was like damn this thing is huge. LOL
    Jacked it up, little by little. Just enough room to get the old mount out. wheeww!!
    That part wasn't too bad.
    Cleaned up all the crap in that bucket and put the new one in.
    NOW, this is the fun part. I knew when I was jacking the motor up, it was going up at an angle.
    So when I started lowering the motor back down. It wasn't even close to lining up with the mount.
    I read on the other forum, this could happen so just my luck when working this car. Nothing every goes to plan.
    On the other forum, they said to pry on the motor to get it shifted. I was like am I going to pry on. LOL. I need a damn engine hoist to get it to move anywhere. I tired prying down by the mount and bracket where it bolts too but didn’t do much.
    The motor need to be pushed back about 1/2", so this might sound dumb but I put a towel around the supercharger snout and gave some hard pushes and it moved. Did it again, but still wasn't going far enough. Car was on jack stands and I had my other floor jack on the sub frame.
    Jacked the motor up again, lowered it. Pushed some more. Did this a few times. Still wasn't moving enough. CLOSE though.
    I wanted to give up, but I couldn't and I didn't want the damn oil pan holding my motor forever. LOL
    I was about to call my neighbor/friend who btw was doing a cam swap on a Camaro no less, but then his parents rolled up and was not going to bother him.
    So went back into the garage, gave two big pushes on the snout. BAM, mount studs slid into the holes.. YAAAAAAAAAAAAAA!!!!!!!!!!!
    What’s funny now, as soon I got the upper mounts bolted I noticed there’s a few things closer to other things than before. My vacuum lines I just re-did, one of them is hitting my Evap and my air filter is about to hit my I/C res..lol. I think they will be ok, but crazy how much the motor was leaning back.
    Anyways. Sorry for the long post. Just was one hell of a day and my wife could care less on hearing what I’m doing to the car..lol
    Steven
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  11. Likes 02GPinNY, pleaseshootme liked this post
  12. #31 Re: How to change lower motor mount and trans mount
    Sep 2015
    IL
    Would it be helpful to raise both ends of the car instead of just the front so when you raise/lower the motor its not coming down at an angle? Just wondering if anyone has tried this because I've read around that people have a hard time 'shimmying' the engine into place once they get off the trans mount or motor mount.
  13. #32 Re: How to change lower motor mount and trans mount
    Houston/Baton Rouge
    Quote Originally Posted by 310toumad View Post
    Sounds like it might have helped.
    I almost needed a strap to tie to the rear engine mount bracket and tilt it forward but I had nothing to anchor it with.
  14. #33 Re: How to change lower motor mount and trans mount
    id not jack the whole engine up from the pans. if you want to lift the whole engine use a engine hoist.
  15. #34 Re: How to change lower motor mount and trans mount
    Houston/Baton Rouge
    Quote Originally Posted by ScottyDoggs View Post
    Ohh, I agree. Just don't have one... I was nervous that's for sure.
  16. #35 Re: How to change lower motor mount and trans mount
    Sep 2015
    IL
    Also, another dumb question: all the how-to's on doing this I've read state that you unbolt the top two mounts, then you either start by doing the bottom motor mount, or the trans mount separately. Wouldn't you need to unbolt ALL of these simultaneously in order to raise the engine/trans, otherwise how is it going to lift up if either the trans is still bolted to its mount, or the motor is still bolted to its bottom mount? I'm just confused because everything I've read says you can do one at a time, re-tightening them as you finish and then move onto the other.
  17. #36 Re: How to change lower motor mount and trans mount
    the mounts are rubber and they will move.
    taking the dog bones off lets the engine raise easier.
    its how ive done it every time, pick a side change it, then the other side. just get a 2x6x 2 foot long, span the both pans and jack it up.
    you can trust just about every how to here, all are proven to work over and over again.
  18. #37 Re: How to change lower motor mount and trans mount
    Sep 2015
    IL
    Ok thank you
  19. #38 Re: How to change lower motor mount and trans mount
    Donating Users gingerdude's Avatar
    Dec 2016
    IL
    Thanks for the writeup. I used this to do the mounts on my 3100. The only difference is an extra bracket on the engine mount that takes some extra effort to get out. This was probably one of the easier things I have done. Minus getting the engine to line up on the engine mount side. That was a pain since I didn't have another person to help. I just pried around until I got it into place.
  20. #39 Re: How to change lower motor mount and trans mount
    Nov 2017
    MO
    This guide was great.
    I found out that my issue in my 2006 was trans/motor mount the hard way. I kept hearing and feeling movement in the front end of the car. Replaced tie rods, bearings, rotors, ALL FOUR struts, lower control arms... still had the sound and feeling. Finally realized it could be the mounts. Replaced them and now it drives like a DREAM (probably has something to do with all the new parts too).
    You WILL need an offset 15mm wrench for 04+, just an FYI. I couldn't have done it without one.
  21. #40 Re: How to change lower motor mount and trans mount
    Jan 2021
    Ohio
    2001 Pontiac Grand Prix.
    Just got the car when I test drove it I thought it was just wheel balance but when driving the car home it feels like tires out of balance but when I let the gas off it goes away. The seller had mentioned the person that fixed the exhaust said it needed a motor mount would that cause my symptom?
    It's not a real violent vibration or anything again feels much like a tire out of balance.
    The car only has 103,000 mi on it.
  1. Need some help on Lower Motor Mount
    By Burbman in forum General Tech Discussion
    Last Post: 11-16-2012, 09:29 AM
  2. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  3. What does a Passenger Lower Motor Mount look like?
    By brenglen in forum Brakes/Suspension/Chassis
    Last Post: 08-07-2012, 05:32 AM
  4. Lower motor mount...
    By Iceman6669 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 02:23 PM
  5. changing lower motor mount
    By Jakegday in forum General Tech Discussion
    Last Post: 01-20-2011, 08:00 PM
