Thread: Replacing Injector O-ring's [*]
Results 1 to 12 of 12
  1. #1 Replacing Injector O-ring's [*]
    Port Hope Ont,Canada
    This How To write-up on Replacing Fuel Injector O-rings has been added to the How To Section and can be found HERE.
    Grand Prix FIRES? THE injector replacement o-ring write up with pic's
    This artical is from Jason Farnsworth AKA GR8racingfool
    ~Farnsworth~
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  2. #2 Re: Replacing Injector O-ring's [*]
    Guess that recent thread really was beating the dead horse
  3. #3 Re: Replacing Injector O-ring's [*]
    utah
    what would happen if you broke a few of those plastic "lips" when taking off the old o-rings? Can you reinstall the injectors without them?
  4. #4 Re: Replacing Injector O-ring's [*]
    Charles City, IA
    I ran mine for about a year with broken clips. No ill effects
    SMGPFC Two Nipple General
  5. #5 Re: Replacing Injector O-ring's [*]
    utah
    where did you get the clips from? I went to advance, autozone, and pepboys, and none of them knew where to get them from. I bought a "Seal Kit" from all the places and the lip wasnt in the package.
  6. #6 Re: Replacing Injector O-ring's [*]
    Jul 2011
    Virginia
    yeh i just broke my number three plastic clip yesterday and have no clue what to do with out buying new injector???
  7. #7 Re: Replacing Injector O-ring's [*]
    Bunnell, FL
    ^^^ steal one off another car
    I'm a Sex Offender
  8. #8 Re: Replacing Injector O-ring's [*]
    Jul 2011
    Virginia
    cool where's yours parked lol
  9. #9 Re: Replacing Injector O-ring's [*]
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Link to the write up is broken....anybody know where to find?
  10. #10 Re: Replacing Injector O-ring's [*]
    Texas
    Quote Originally Posted by Burbman View Post
    Pretty straightforward. Disconnect the fuel rail using fuel line removal tool. Then pull off injectors and replace the top and bottom rubber gasket on the injectors. O rings can be purchased from any parts stores.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: Replacing Injector O-ring's [*]
    the fuel rail has 4 nuts holding it down, ( 4 outside corners) remove the injector clips, the vac line off the fpr on the rail, lift the rail up, the injectors will pull out of the lim, no real need to undo the fuel line. unless you want it off, then you'll need a 2 different size fuel line disconnect tools.
    to change the O rings i found it easier to cut the old one off with a razor. oil the new one, roll it on. get some q tips, a lot of them, then clean out the injector holes real good, i used brake cleaner sprayed into the cap, dipped the q tips in the cap, then cleaned the holes. re oil all of the o rings, and slide them back in. bolt it back down, install the injector plugs and vac line..
    if your changing the top o rings as well, theres a clip you pull out, then pull the inject or out of the rail. its easy to see how that part comes off. same deal cut them off roll a oiled new one on, put it back in the rail, re clip it.
  12. #12 Re: Replacing Injector O-ring's [*]
    Dec 2008
    ****'s Creek
    Thanks guys, this came up in a search on the fuel line disconnect o-rings and I found what I was looking for here. On the injectors, I sent them out to Mr. Injector to be ultrasonically cleaned, balanced and rebuilt when I did the LIM gasket, and they came back with new O-rings.
  1. Fuel Gauge Problems
    By thermanlee in forum General Tech Discussion
    Last Post: 05-29-2008, 12:33 PM
  2. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
