Anybody know the proper procedure to bleed the air from the coolant system? 3.8 series III
open the rad cap, let the car idle till the fans come on, then open the bleeder screw till a solid stream of coolant comes out. then shut the screw, top off the rad,and cap it.
if your having a heat problem, take the hoses for the core off the engine and flush/fill the core. bleeding the engine wont help get the heat back.
