Thread: Water in floorboard (Take 2) - The Permanent Fix
Page 19 of 34 FirstFirst ... 9171819202129 ... LastLast
Results 361 to 380 of 662
  1. #361 Re: Water in floorboard (Take 2) - The Permanent Fix
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    Are all you weather strips intact? Could be leaking in there.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #362 Re: Water in floorboard (Take 2) - The Permanent Fix
    Wausau, WI
    Do you have a sunroof? Is your windshield sealed good?
  3. #363 Re: Water in floorboard (Take 2) - The Permanent Fix
    GTP Level Member
    springfield IL
    so yesterday( in H E L L like humdity and temp) i attempted to install this deflector... 2 problems, i have the single one piece cowl and cant ge the wiper arm off but was able to bend it up around the hood(hood was open)
    part installed very EZ... now i cant get the lil L shaped plastic off the cowl.. tried for an hour with razor bladeknife to cut it off but it didnt seem to "dig" into much..... this plastic is F'n HARD!!! lol
    only other thing i can think is buy or see if a buddy has dremel....???
    any other ideas guys?!?!?!?!?!?!?!
  4. #364 Re: Water in floorboard (Take 2) - The Permanent Fix
    Toronto, Canada
    just keep scoring it with an exacto knife or razor blade, and eventually you should be able to cut it enough that it will snap off ..
    I had to score mine quite a few times. it took me a while to , but eventually I had made enough of a groove , do this on both sides where you want to cut it.
  5. #365 Re: Water in floorboard (Take 2) - The Permanent Fix
    SE Level Member Marks97GTP's Avatar
    North Carolina
    Well thought I had it fixed , buy using glue to attach the rubber seal. Well it leaked yesterday when we had 6" of rain, not bad but the carpet was wet. Gonna go to the dealer to see if I can get the shield/guard what ever it's called.
    Mark
  6. #366 Re: Water in floorboard (Take 2) - The Permanent Fix
    North Carolina
    Quote Originally Posted by Marks97GTP View Post
    Mark
    Ordered the defelector today $3.39 ... lol , be here Monday
  7. #367 Re: Water in floorboard (Take 2) - The Permanent Fix
    Jul 2010
    Outside ATL
    Quote Originally Posted by tc300 View Post
    score like hell and use some big azz wire cutters or dremel
  8. #368 Re: Water in floorboard (Take 2) - The Permanent Fix
    Wausau, WI
    I used a tin snips...
  9. #369 Re: Water in floorboard (Take 2) - The Permanent Fix
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    The next time I do one, I plan to use a hack saw and cut some small slices. Pinch slices with a vise-grips and carefully break them off by twisting back and forth.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  10. #370 Re: Water in floorboard (Take 2) - The Permanent Fix
    North Carolina
    Well picked up the deflector, gonna wait till later to put it in ...
    Mark
  11. #371 Re: Water in floorboard (Take 2) - The Permanent Fix
    St. Cloud Minnesota
    Thanks for all this great info !! I posted it up on our local board and have had a ton of hits and comments over there too. Solved the problem on my 04' GT in about 10 minutes.
  12. #372 Re: Water in floorboard (Take 2) - The Permanent Fix
    Germantown
    Quote Originally Posted by ls6velless454 View Post
    There are other reasons for water in the passenger floor board. One reason being hvac evap boot drain getting clogged. Mine was fine and I bought the deflector car still leaked. Then I took off the boot, and stuck my finger in the pipe where it drain out and it was clogged so problem fixed just letting you know if you didn't already address that.
    I have a '98 GT and I'm planning to buy one of the replacement deflectors, but I'm worried about the water that is already stuck somewhere in the car.
    I believe that I successfully removed the rubber elbow or AC drain boot which I found protruding from the firewall about 1 foot below the alternator and hidden behind some other hoses.
    The boot was not clogged and the pipe it was connected was not clogged either. I had also previously taken the AC blower motor completely out so I know that the blower area is completely dry, but I can still hear large quantities of water sloshing around when I turn.
    Does anyone have any idea where that water could have ended up?
    I've read some other postings in other web forums which implied the there might be another drain point, perhaps a green plastic or rubber elbow somewhere lower in the car, but I have not been able to find it.
  13. #373 Re: Water in floorboard (Take 2) - The Permanent Fix
    Texas
    My wife has a 2004 Grand Prix and we woke up this morning after a rain with water in the floor board. Does this part work on a 2004? If not, what part number should I order to fix the leak? NEVERMIND I FOUND THE ANSWER
  14. #374 Re: Water in floorboard (Take 2) - The Permanent Fix
    SE Level Member Comanche1959's Avatar
    Nov 2010
    Kentucky
    I have a 2001 GTP and read the deflector instuctions here awhile back when I had to replace the blower resistor due to a couple drops of water shorting out the low speed on the fan. I've never had a flooded right side floor, but don't want to wait 'til I do.
    Here's the problem. I searched out an internet source for part #15794785 and ordered it from NewGMparts.com in MA. I guess there was a blank on the order form where they asked the year and of course I put 2001. Hell they ended up changing the part number to 10388810 and sent me the rubber channel seal that's already on the car. Now I have to deal with returning a $5 part....marvelous. Does anyone have a good source in the middle of the country to get one from, or should I just go to a dealer and tell them just to sell me the part # I want and not to worry what its going on?
    Is 15794785 a part from a different year that you guys have discovered fits on the '01 (with the trimming of the top cowl)?
    Thanks,
    Steve Frankfort, KY
  15. #375 Re: Water in floorboard (Take 2) - The Permanent Fix
    Charles City, IA
    Just call the dealer and ask them for that part number.
    SMGPFC Two Nipple General
  16. #376 Re: Water in floorboard (Take 2) - The Permanent Fix
    Nov 2010
    Ontario
    I just had this problem on an 04 Grand Prix and it landed up being just the blower motor, resistor was fine.
    I really wish I researched the fix a couple years ago when my parents had the problem the first time. I just put the rubber strip back on thinking a lube shop had knocked it off putting in the cabin filter.
    I called the dealership parts department and gave them the part # from the TSB from Feb05, and they said the part # changed to:
    plenum water deflector (Part# 15794785)
    So it is in the system even if you give them the old TSB part #.
    That is the correct part #. Why they even have the old part # for the rubber strip is beyond me.
  17. #377 Re: Water in floorboard (Take 2) - The Permanent Fix
    Toronto, Canada
    because without modification of this new plastic deflector
    the 2004 part does not fit in 2003 and older cars
    when I was ordering the new plastic deflector for my 01 GP the dealer kept saying they did not think it was the right part for my 01
    but with the wonderfully illustrated instructions you can make it work
    my floors have been dry ever since.
    Thanks again !
  18. #378 Re: Water in floorboard (Take 2) - The Permanent Fix
    MA
    Does anyone have any suggestions if I have a leak on both the passenger and driver side? I'm going to buy this part for the passenger side. But what should I do about the driver side?
  19. #379 Re: Water in floorboard (Take 2) - The Permanent Fix
    Nov 2010
    Kentucky
    Oh yeah....the people that sold me the wrong part and won't take it back was NewGMparts.com Don't buy anything from them.....their lack of expetise and bad customer service sucks major pond scum.
    I'll go buy the damn part from a f*&^%$* dealer like I should have to begin with.
    Steve
    Frankfort, KY
  20. #380 Re: Water in floorboard (Take 2) - The Permanent Fix
    Kansas
    Let there be water!
    SOLD 1999 GT Silvermist TS
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
