Thread: Water in floorboard (Take 2) - The Permanent Fix
Page 27 of 34 FirstFirst ... 172526272829 ... LastLast
Results 521 to 540 of 662
  1. #521 Re: Water in floorboard (Take 2) - The Permanent Fix
    Dec 2012
    Illinois
    Just finished doing this. Really simple and took all of 10 minutes to solve this issue! Loved the parts guy asking "Where'd you find this part number?"
    My only problem is that when removing, I lost the far right cowl as it flew into the dark and likely in the neighbors yard. Can I pick one up at a parts store?
  2. #522 Re: Water in floorboard (Take 2) - The Permanent Fix
    Aug 2012
    florida
    junk yard
  3. #523 Re: Water in floorboard (Take 2) - The Permanent Fix
    Dec 2012
    Illinois
    My girlfriend located it in down the driveway yesterday...score!
  4. #524 Re: Water in floorboard (Take 2) - The Permanent Fix
    Aug 2012
    florida
    ALLLLLLLLLL RIGHT.DID YOU GIVE HER A BIG KISS
  5. #525 Re: Water in floorboard (Take 2) - The Permanent Fix
    Dec 2012
    North Carolina
    Great tip! Thanks, now I can get some new carpet and not worry about the water.
  6. #526 Re: Water in floorboard (Take 2) - The Permanent Fix
    thought id post pics of my ghetto cowl repair.
    you can see the shield is torn, thats why it leaks.
    and this how the just a bag has been tucked in the lip. this has worked for over 2 years. had the cowl off today to run a amp power line.
  7. #527 Re: Water in floorboard (Take 2) - The Permanent Fix
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    Should have just ordered the part for $8 and swapped it out when you knew you were going to take it apart.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  8. #528 Re: Water in floorboard (Take 2) - The Permanent Fix
    you know what? its worked for 2 plus years, why mess with it. i got bigger fish to fry with this car then a cowl deflector.
    this is one way to fix it tho. without it costing a dime.
  9. #529 Re: Water in floorboard (Take 2) - The Permanent Fix
    Aug 2012
    florida
  10. #530 Re: Water in floorboard (Take 2) - The Permanent Fix
    Dec 2012
    Illinois
    Brilliant bush fix man! Love it.
  11. #531 Re: Water in floorboard (Take 2) - The Permanent Fix
    whats quite inventive of me i must say is, that i fixed this way before i ever saw this thread, i just took it apart and looked for the problem, then tried to solve it, and here were are over 2 years later, it still works.
    i did hose test it before i called it good to go. it passed.
    a wet floor will make you look, then found rain running down from the fan, something had to be done....
  12. #532 Re: Water in floorboard (Take 2) - The Permanent Fix
    GT Level Member 91gpse's Avatar
    warren, mi
    do they make one of these for my 91? cuz i keep getting water on my passanger floor from the cowl.
  13. #533 Re: Water in floorboard (Take 2) - The Permanent Fix
    Aug 2012
    florida
    maybe start at the begining to see picture.start at first page
  14. #534 Re: Water in floorboard (Take 2) - The Permanent Fix
    warren, mi
    do you realize there are 107 pages? that would take hours...
  15. #535 Re: Water in floorboard (Take 2) - The Permanent Fix
    Quote Originally Posted by 91gpse View Post
    if i were you, i'd take the cowl apart and see whats going on with it. it may have a ripped diverter like i posted on this page. if so its repairable with a little creativeness.
  16. #536 Re: Water in floorboard (Take 2) - The Permanent Fix
    Feb 2008
    Cumming GA
    I'm all for saving a buck. But if it takes you an hour or two to figure out how to fix it, isn't your time worth more than the $8 it takes to just go order the part? You're going to have to take everything apart anyway. It's off. You put the new cowl on. You put everything back in place. DONE. No testing with a hose to see if it still leaks, then ripping it apart to see why or where.
    Just my 2 cents.
  17. #537 Re: Water in floorboard (Take 2) - The Permanent Fix
    you missed the part where he drives a 1991 GP. and taking the cowl off takes 10 minutes tops, any longer your doing it wrong.
    for his year there may be no dealer part to fix it like the newer 97-03 so taking it apart then see if you can figure out why its leaking, then address it maybe his only option.
  18. #538 Re: Water in floorboard (Take 2) - The Permanent Fix
    warren, mi
    I have had it off and made sure the drain was cleared. Nothing was torn... Blower motors shot and locked up and theres currently a frozen puddle in my passanger floor board. Cars parked for the winter so its no big deal for passangers except the fact the floor may mold up and ruin it... I guess I will pull it apart and see if I cant make my own part for it using sheet metal or something if they don't have one. I wonder if just due to age gaps formed and thats whats causing the leaking... I mean the car does have 235k miles lol.
  19. #539 Re: Water in floorboard (Take 2) - The Permanent Fix
    Aug 2012
    florida
    I MENT GO TO PAGE ONE WITH THE PICTURES ON IT .MAYBE (ABRASIVE ) STILL ON LINE HE SENT THE PICTURES MAYBE HE HAS ANSWER FOR IT .JUST A GUEST.I HAVE 2004 GP .MAYBE SET UP NOT THE SAME OR MICKY MOUSE IT WORKS SOME TIME .LIKE (SCOTTYDOGGS)IT WORKS
  20. #540 Re: Water in floorboard (Take 2) - The Permanent Fix
    Mar 2013
    SW MO
    I wanted to personally thank Abrasive for the how to and part numbers. I have hopefully fixed the issue now. Testing with buckets and the water hose looked good. We'll see after a real heavy rain.
    Sent from my SPH-L710 using Xparent Red Tapatalk 2
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
