The old stock pieces rusted.
It was a metal clamp inside a rubber piece.
Metal rusts out, boom, piece fails and you get water on your floorboard.
I didn't see anyone ask a question on this but I ran into the problem where the blower motor remains on after key off and I pulled the power wire running to it. I all ready have the solid state controller to replace and ordered the new piece to keep the water from going in the motor. Do I still need to install the capacitor since the water is no longer draining down into the motor? Thanks.
Picked up my part for a whopping $4.41 at the local GM dealer. Have the one piece cowl but didn't need to remove the wipers to cut off the excess plastic in the cowl.
Does anyone know if this problem may apply to 2005 GTP?
Pretty sure it does considering I have an 05 and I ran into this same problem. They didn't start installing them until the 08 model years.
I RTV'd the weatherstrip back on and it that didn't work.
Picked up the part from Huber Chevrolet for 3.60.
That should do it. I had a one piece plastic shroud I guess you call it and I still didn't have much of an issue. I bent it towards the windshield best I could and broke off the plastic pieces so it didn't get in the way of my new water deflector.
Should work great.
10 minute job tops.
Thanks man!! Got mine for 3.30!!
There are other reasons for water in the passenger floor board. One reason being hvac evap boot drain getting clogged. Mine was fine and I bought the deflector car still leaked. Then I took off the boot, and stuck my finger in the pipe where it drain out and it was clogged so problem fixed just letting you know if you didn't already address that.
I know your not lying club gp had a write up on alot of the problems
this is a old post but is gm part #15794785 still available?
where do I get it then cus I dont know. I have checked online
