This is to show how to install a FMHE on your car. This is a stage 4 from ZZP. They said it will not fit if you still run a/c and have the ac condenser installed. I'm about to show you how to make it work.
Here are some comparison pics of the stage 2 and my new stage 4.
First take the front bumper COVER and BUMPER off (bumper has 6 bolts)-
Next remove these tabs as it won't go into place with these here.There is one on both passanger and drivers sides-
Grind/cutt them off with an angle grinder but be sure not to slip. If you do you will be riding around without a/c untill you get a new a/c condenser(Not sure why the SAFTY glasses are on my head?)-
They should look like this when your done.Both passenger and drivers side-
Next you'll have to make the brackets for the FMHE-
These will slide into the front radiator support chanell and will look like this-
Next comes the top mounts- make them look like this-
Next it should look like this when mounted-
Next notch the lower air dam (corners so it will clear the hoses ect.) with a thick razor blade or dremel
Put the bumper back on and should look similar to this-
Put the bumper cover back on.And you're done!!
