Thread: PVC Valve Replacement (L67) [*]
Results 1 to 5 of 5
  1. #1 PVC Valve Replacement (L67) [*]
    Louisville, KY
    This HOW TO write-up on Replacement of the Positive Crankcase Ventilation (PCV) Valve has been added to the How To section and can be found HERE
    My Cardomain
    Topeka, KS
    Nice Write UP. I have the replacement part but still need to do this. Thanks for reminding me.
    chicago
    i forgot, but correct me if i'm wrong if you shake on the pcv and hear a rattle sound. does that mean the pcv is still good?
    Louisville, KY
    Quote Originally Posted by 38special View Post
    If you hear a rattle or click it's good, if not replace.
    My Cardomain
  5. #5 Re: PVC Valve Replacement (L67) [*]
    SE Level Member TooMch's Avatar
    St. Louis, MO
    I didn't see any way to leave comments on the actual write up. I
    the write up seems pretty simple to me (except for the inclusion of the torque specs - that was good).
    For someone who ddin't know what to do how would they know where the PVC access cover was? Seems like it needs pictures.
    2004 GTP CompG
    wizair| LQ4| S2IC| 3.0| 1.9RR| RS12YC| 160°| 39#|TOGX|3" Hogan DP| Corsa| tune
    2007 = 13.034 @ 103.68 (TOGX, AL103, ZZP DP)
    2004 = 14.576 @ 94.34 || 2005 = 13.822 @ 97.57 || 2006 = 13.224 @ 99.98 (PEMs,TR6IX, RT DP)
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
  3. The First ZZP's aluminum valve covers finished
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 01-06-2008, 11:18 AM
  4. PCV Valve Replacement (L36) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 01-03-2008, 11:25 PM
