Thread: How To Install ARP Head Bolts by Farnsworth
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: How To Install ARP Head Bolts by Farnsworth
    The Boss Iceman6669's Avatar
    Jun 2011
    We had clearance issues with SD headers. Just had to drive the studs in a bit farther.
    2011 F-150 Yote powered
  2. #42 Re: How To Install ARP Head Bolts by Farnsworth
    hangover park IL
    best thing to maek sure they seal/install properly, is to cut 2-3 cleaning groves across the threads of an old head bolt and run it through each hole to clean the OEM bolt crud out....
    ~James~ Psychotic Gearhead
  3. #43 Re: How To Install ARP Head Bolts by Farnsworth
    Jun 2011
    Or use a tap.
  4. #44 Re: How To Install ARP Head Bolts by Farnsworth
    hangover park IL
    tap cuts out the root of the threads and weakens em.
    use a thread chaser or its cheaper to cut slots in the bolt with a 3" cutoff wheel or a dremel...
  5. #45 Re: How To Install ARP Head Bolts by Farnsworth
    Kemmerer, Wyoming
    How straight would the slots have to be
  6. #46 Re: How To Install ARP Head Bolts by Farnsworth
    hangover park IL
    not at all, but i cut em at an angle, one in a clockwise and one counterclockwise..one cleans well going in, the other cleans well coming out...then just a wire/nylon barrel brush "thread" em and/or compressed air
  7. #47 Re: How To Install ARP Head Bolts by Farnsworth
    Nov 2011
    NY
    Hmmmmmm... Just want to clarify the torque spec and ask what everyone else has done.
    For the L67, 3800 block, head STUD kit, ARP says 80ft.lb with Molly Lube (link)
    http://arpinstructions.com/instructions/193-4001.pdf
    I've read, 75, 80, & 90 ft.lbs respectively online... What say you?
  8. #48 Re: How To Install ARP Head Bolts by Farnsworth
    Kemmerer, Wyoming
    this is what I used to seal the threads: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    as far as the torque sequence, I dont remember if I torqued them incrementally, but I do remember I torqued them to 80 ft/lbs. been driving around for a couple weeks and no issues.
  1. ARP Header bolts
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-29-2008, 01:57 PM
  2. S/C Bolts ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2008, 03:18 PM
  3. ATTN Farnsworth - tool info needed
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-14-2008, 10:54 AM
  4. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
