Thread: how-to: diy aux input for 04+ xm equipped cars
Page 7 of 7 FirstFirst ... 567
Results 121 to 140 of 140
  1. #121
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by PCweber View Post
    does anyone have a solution for the non -XM 6 disk with On Star input? I have searched high and low, gave up and bought a Scotche FM modulator that goes inline with the antenna cable. It worked for a week, now works for 10-15 mins, cuts out. My problem is the door chimes, etc come through the speakers so if I replace the head unit I loose all the headlight alarms, etc.
    What's ur ride?
    Sent from my pager using Morse code. ... .. ... ....
  2. #122 Re: how-to: diy aux input for 04+ xm equipped cars
    Feb 2009
    NE
    04 Grand Prix GTP
  3. #123 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    just go get the gm harness, will retain chimes and such
    Jun 2012
    There's a special harness that keeps all the chimes and all. Only down side is brand new its 100 bucks. I used to have one for my car but already resold it to someone on here. And if u want steering wheel controls to work go to pac audio website
  5. #125 Re: how-to: diy aux input for 04+ xm equipped cars
    Dec 2012
    Florida
    Quote Originally Posted by marines542 View Post
    Made by Metra it's part number GMOS-01. The salesman may try to sell you the GMOS-04 because you have the Monsoon system, but that leads to low audio output using the low-level RCA inputs on the module. Just use the GMOS-01 with it's high-level inputs. Works fine in the Grand Prix. It's going to retain your door chimes, keep your retained accessory feature when the car is off, OnStar (if equipped) and also give you the ignition wire you need for an aftermarket headunit (that the factory harness doesn't have). If you care about your steering wheel controls, you'll need Metra part number ASWC. It plugs right into the GMOS-01 and auto-programs, making life pretty damn easy (read the manual, because certain cars require you holding a button to trigger auto-programming). Retail, you're looking at about 200 bucks for both pieces. But you can probably get them for half that online.
  6. #126 Re: how-to: diy aux input for 04+ xm equipped cars
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    Cool write up, but I just got an isimple gm5...has 2 aux ports 1 for iPod and the other for standard 3.5 mm headphone jack...easy hook installation considering I tried others with no success....I have monsoon in dash 6 cd, xm, on star ....but this product is perfect
    COMP G
  7. #127 Re: how-to: diy aux input for 04+ xm equipped cars
    Mar 2012
    OHIO
    To anyone that did this mod, when your phone or mp3 device is connected to the aux jack and also have your charger connected, is there ground loop feedback or does the XM receiver filter it out?
  8. #128 Re: how-to: diy aux input for 04+ xm equipped cars
    Dec 2012
    Oswego, Illinois
    Does anyone know a method similar to this for an 02 with bose?
    Sent from my POS Lumia 822 using Board Express
    2002 GTP: My Daily
    Wizaired CAI
  9. #129 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    i believe there is a write up to add aux but you have to have a tape deck i believe.
  10. #130 Re: how-to: diy aux input for 04+ xm equipped cars
    Yoga city
    if you connections are solid you will not recieve any feedback, this been in my car for a while and anything ive hooked up and charged has sounded quite good.
    Quote Originally Posted by xbryxsetsfire View Post
  11. #131 Re: how-to: diy aux input for 04+ xm equipped cars
    Donating Users Jordan's Avatar
    Oct 2011
    Richland Center, WI
    Just tried this...got everything soldered together but all I hear when I go to XM is a crackling noise? I have the right hooked up to the brown, the left hooked up to the green and the copper from each of those into the common.
    Here's how I set it up
    EDIT: I attached the ground common wire going out and now it seems to be working. But is this the right way?
    Edit 2: Also, the sound is interrupted when I plug my phone into a charger while playing music, no sound at all.
    2009 Cobalt SS/TC Coupe |
    Summit White | 131k | ZZP charge pipes, ZZP heat exchanger, ZZP 3" downpipe, HP tuned, Muffler delete, K&N Typhoon intake, dual interceptors, retrofits with switchback halos
    2006 Grand Prix GXP | Black | 95k
  12. #132 Re: how-to: diy aux input for 04+ xm equipped cars
    SE Level Member Orange04CompG's Avatar
    Aug 2013
    Austin,Texas
    so the rca to aux that i got is just the male aux with two wires coming out of it, one to each rca, and when i cut the male rca's there was only one wire in each. so i hooked it up anyways, one to the green and one to the brown/white, and it works and sounds clear but its kind of quiet. not super quiet, its a normal car ride music volume but thats at full blast. i cant get it to like, roll the windows jamming to your favorite song, volume. is this the same for you or what?
  13. #133 Re: how-to: diy aux input for 04+ xm equipped cars
    Aug 2013
    Austin,Texas
    nevermind, i just got a better quality cable and it worked fine. thanks, great write-up!
  14. #134 Re: how-to: diy aux input for 04+ xm equipped cars
    solder and shrink tube your connections if it looks the same as the pics of the last set up.
    the old twist and tape truly blows.
  15. #135 Re: how-to: diy aux input for 04+ xm equipped cars
    Aug 2013
    Austin,Texas
    yeah it was a temporary thing. its soldered and working well!
  16. #136 Re: how-to: diy aux input for 04+ xm equipped cars
    Jun 2015
    Ohio
    This topic still alive I've got a question and I've read through I believe I understand everything just a little confused.
    Fist I'd prefer to splice behind the radio if I can which I believe is possible from what I've read? I have the 6cd monsoon 2007 gxp
    Also the cable I have only has 1 wire in each rca with wire wrapped around it. Is that around it the shield or the ground? Should I just get better cables since those might be junky based on what is in them?
  17. #137 Re: how-to: diy aux input for 04+ xm equipped cars
    Enfield, CT
    Subbed
  18. #138 Re: how-to: diy aux input for 04+ xm equipped cars
    Dec 2012
    Florida
    Quote Originally Posted by arepok View Post
    The "shielding" is the ground. It connects to the barrel of the RCA. The center insulated wire is the positive. It connects to the center pin of the RCA.
  19. #139 Re: how-to: diy aux input for 04+ xm equipped cars
    Apr 2016
    Maryland
    Sirricealot made this thread hilarious I couldn't stop reading he's so foolish I read how to do it 10 times while he was still asking questions hahaha
    Sent from my XT1060 using Tapatalk
  20. #140 Re: how-to: diy aux input for 04+ xm equipped cars
    GTP Level Member
    Oct 2014
  1. using XM radio 2004 Grand Prix? (not equipped)
    By Wanted in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2011, 08:50 PM
  2. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
  3. Could a small valve cover leak cause a loss of boost on a PCV equipped vehicle?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 11:57 AM
  4. Tap Shifters on a car not factory equipped?
    By sickofsoyo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2009, 05:25 PM
  5. New User equipped with a GXP!
    By Cableguy in forum Introductions/Noob Questions
    Last Post: 10-13-2008, 06:02 PM
