We don't have one of these lol. I have searched WICGP, ClubGP, North American Grand Prix Club and etc and I could not find any posts on how to wire these so I took my chances, and what do you know I got it right lol. So I made a write up when I did the 2nd light.
This is just how to connect them to your park lamps. The little light on the far end corner of your corner light. So when you turn on your daytime running lights, your halos come on too =)
IF YOU DO THIS WIRING TO WIRES SHOWN YOUR HALOS WILL BLINK WITH YOUR TURNING SIGNALS
...it actually looks kinda neat imho...
Step 1.
If you haven't gotten around to taking out your stock Lamp, you have to take out all the bulbs from the old light and re-connect them into the new headlamp. So after you have that done, look at the Park Light connection. It's the smallest bulb out of all of them. The Brown is Positive and the Blue is Negative.
Step 2.
You want to cut these tires and re wire them together to place a connector on them. You have to do it to the Blue wire as well.((I don't know what the actual name of the connector is called.)) Be careful when you strip them because they are heated plastic coated instead of just ran through a plastic tube. So you have to get the wires as clean as possible.
http://a116.ac-images.myspacecdn.com...1f716652eb.jpg
In my opinion these are the best connectors for this. They aren't a big hassle or anything to deal with. But if you have your own style for it then go ahead =)
Now after you have the first wire cut, like I said u have to re wire it back together like this:
http://a531.ac-images.myspacecdn.com...149f15a04a.jpg
Now you want to take the two red wires for the Halos, and wire them together like you did with the Park light wires. You want to wire the two black ones together as well.
http://a539.ac-images.myspacecdn.com...f855d84ce2.jpg
Step 3.
Once you have the wires all twisted together, it's time to cap them off with the connectors.
http://a481.ac-images.myspacecdn.com...3130f9a420.jpg
http://a69.ac-images.myspacecdn.com/...fe878b90bc.jpg
You can connect these anyway you want to. The connectors I have circled on the pictures aren't required to go on that certain wire, they can be vise versa just aslong as you have one slot and one insert connector so you can connect them.
http://a863.ac-images.myspacecdn.com...14a91c51ae.jpg
Connect Black to Blue and Red to Brown. Make sure you wrap electrical tape arround the connections, this prevents them from touching, water getting on them and to help keep them together for some reason they should disconnect.
After that, go test your new lights =) You shouldn't have a problem with them not working. If your doing this in lots of sunlight its hard to see if the Halos are on.
http://a325.ac-images.myspacecdn.com...afb94a8b84.jpg
any questions? Let me know =)
