Thread: Push Button Start 50$ for a unique mod
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
  1. #41 Re: Push Button Start 50$ for a unique mod
    Bunnell, FL
    Quote Originally Posted by gtpeddie View Post
    what did you have to do to move the HUD switch to the other side?
    made an extension harness and just swapped the spots
    I'm a Sex Offender
  2. #42 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    do you know what gauge wire goes to the start button?
  3. #43 Re: Push Button Start 50$ for a unique mod
    Never Never Land
    Boat you make any progress on this? I'm curious how the unlock/lock part would work with having an aftermarket alarm. I understand you can program an RF fob to unlock the car within "X" feet. Could it also be programmed to unarm the alarm at the same time?
  4. #44 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    nobody on how to mod the cylinder or wire gauge?
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Freddy you could just reroute the starter wires from the lock cylinder to your button. Though I would recommend that you also run a NC relay to cut the accessory power while the starter is engaged because that's how the cylinder does it. Doing so makes sure the starter gets as much power as it can without the radio or anything else sucking up much-needed juice.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  6. #46 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    whats NC stand for? and how would i go about rerouting them?
  7. #47 Re: Push Button Start 50$ for a unique mod
    Minnesota
    NC = normally closed. Meaning when you apply current to the relay trigger it will open the load circuit (aka cut power). You just take the two wires that are hooked into the lock cylinder switch, cut them, and then just attach them to your pushbutton switch. If you choose to include the relay just put it inline with the button. Observe:
    [ Starter (+) ] -------> [ (+) Relay Trigger (-) ] -------> [ (+) Pushbutton (-) ] -------> [ Starter (-) ]
    And for the accessory part of the circuit:
    [ Accessory (+) ] -------> [ (+) Relay Load (-) ] -------> [ Accessory (-) ]
    Note: This is an extremely crude and hypothetical diagram to be used for descriptive purposes only. If you break your car, it's not my fault. Get the wiring diagram for the lock cylinder switch harness and take note of the correct wires.
    Also, you should probably at least get into some basic electrical circuitry stuff not related to the car before you just delve right into modding your electrical system. If you don't know what you're doing you could seriously **** some **** up, and even kill yourself. Jsyk.
    2015 Evo MR
  8. #48 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    ok thanks man
    GTP Level Member apierce1289's Avatar
    United States
    Actually you don't need a key. Just look for a bypass module for the passkey 3 module installed in 01-03 grand prix. I'm not sure what they use in the newer gp's though. After that you should be able to take the key out of the whole equation. I could be wrong though maybe there's another way around not having a key?
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
    United States
    Might be able to use some diodes or something :-\ I'd need to research the anti theft system a bit more because the bypass module will let you start a car without keys but I don't think it will let you drive away?? Although that could be a feature of some alarms and if you don't have an alarm you wouldn't have to worry. But that's a big maybe :-\
  11. #51 Re: Push Button Start 50$ for a unique mod
    Houston
    Quote Originally Posted by apierce1289 View Post
    Then there is nothing to stop someone from smashing your window and driving off with your car. Insurance doesn't cover that. Total loss.
  12. #52 Re: Push Button Start 50$ for a unique mod
    Its so easy to hack into a cars computer and lockup the brakes or open/close the throttle entirely.
  13. #53 Re: Push Button Start 50$ for a unique mod
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I did my PB statt according to Brian (BackInBlack).
    I still need the key, but use the button to start. I did it more of the "cool" factor.
    The only way to really have a true PB start is to have it like today's car where you need a transmitter to be in your pocket to start the car.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  14. #54 Re: Push Button Start 50$ for a unique mod
    SE Level Member simongtp's Avatar
    Jun 2010
    Longview, TX
    is there a way to access the red and yellow wires to get a few pretty pictures. i want to do similar buttons, just in a different location and eliminate the key and have "easy" written on the button
    simon
  15. #55 Re: Push Button Start 50$ for a unique mod
    Minnesota
    To anybody who's still interested in the Arduino solution, I'm finally beginning to work on mine lol. Just got my Uno today, and I have a Mega 2560 and some other goodies coming soon. I'll start my own thread though.
    2015 Evo MR
    Jun 2011
    Dew the dew.
    Sent from my Samsung Galaxy S3
  1. push button start (progress thread)
    By z3r0 in forum Visual/Body Modifications
    Last Post: 12-01-2011, 08:38 PM
  2. push button start
    Last Post: 06-01-2011, 11:09 AM
  3. push button ideas
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 05-14-2011, 08:48 PM
  4. Stuck in park! Cant push shifter button!
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 04-05-2011, 09:23 AM
  5. Push button Start
    By crock in forum General Tech Discussion
    Last Post: 08-31-2010, 04:41 PM
