Thread: Push Button Start 50$ for a unique mod
Results 21 to 40 of 56
  1. #21 Re: Push Button Start 50$ for a unique mod
    you should have used something more fun than a push button. like the switches they use to start nascar cars:
    i hope to do something more fun and flashy like that when i gut the crap out of the interior.
  2. #22 Re: Push Button Start 50$ for a unique mod
    Nov 2008
    Waterloo, Iowa
    I've thought about all this before. I see it being possible to make it work how newer cars work, but being a lot of work. Requiring chips and sensors for a key/keyfob, locking out grinding the starter, and also making the button turn the car off, or into strictly auxiliary. Making it even more difficult for myself would be how it would interact with my remote start. Would pressing the button turn the car off, do nothing, or work as intended? And if it doesn't work, how would one make it work?
    So many possibilities.
    And **** if you go through all that trouble you may as well give the car range-sensitive door locks. If you get close, unlocked, if you get far enough away, locked... again, like a new car.
  3. #23 Re: Push Button Start 50$ for a unique mod
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Actually I got the idea from my remote start when I installed it, and the way I'm designing it is to actually emulate a remote start system (it's being designed with remote start in mind). The system will have an input detecting if the car is running, and if so it will cut power to the ignition line and send a pulse to the brake pedal sense line which will shut off any remote start system (provided the system is properly installed).
    Also, I suppose I can program in some unlock code for when you approach the car since there will be a few extra relays open. Of course this will be a configurable option if I do decide to include it because I'm not a fan of the auto lock/unlock. Actually, theoretically speaking I could make an entire remote start / alarm system to go with this too, but that would be a little much imo.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
    Bunnell, FL
    In for auto unlock lock. I have no key holds and the oem.keyfobs need to be aimed at the middle of the dash to work
    Android Fire
    I'm a Sex Offender
  5. #25 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    I like the idea of a switch. Is there anyway that you could get a switch that has an on and off position but make it have to be pushed past the on to crank the starter like the key? I'm not the most electrically inclined but i can follow a chart and solder if someone else could write it up. Im thinking I dont need the key in the ignition cuz i live in a small town and aint really worried about theft if someone has gotten that far? I really like the idea and if its not possible with the switch i would like to just put a button start in
    Bunnell, FL
    Quote Originally Posted by Freddy View Post
    Only way you could wire without the key is if you didn't have the chipped keyes. My 97 doesn't but my 00 did
    Android Fire
    I'm a Sex Offender
  7. #27 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    i got a 99 how do you know if its chipped?
    Ohio
    Look for "pk3" on the top of your key... Actually you'll see the chip towards the top
  9. #29 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    It looks like its just metal with a little rubbber deal on top. i also have a valet key without the rubber piece that will start the car and open the doors but no the trunk or the backseat pass through
  10. #30 Re: Push Button Start 50$ for a unique mod
    I live here. TLSheff's Avatar
    99pgpgt Unless you have some weird late model or special model that is better than my 99 GTP, you should know that the 99s don't have "chipped keys" the PK3 setup wasn't implemented in our GP until 2000.
    If your car isn't engraved with PK3 at the base of the key it is like all other 97-99s and doesn't have any sensing capabilities. Also, there is something wrong with your "valet" key if it won't open the trunk, mine opens everything.
    I actually prefer it that way, if someone wants to steal it, they will steal it regardless of the "security" system our cars have. Heck they steal new laser cut programmed Mercedes cars all the time, you think they can't bypass resistors in our old cars??? haha
    I really considered wiring up a push button and modding the lock cylinder so it only hits the ACC - OFF - ON points and you HAVE to push the button to start it. But I want my button hidden, like where the AC Power is the over head console. The drop down cover would keep it hidden if you didn't know it was there, and how many people would look for it up there???
  11. #31 Re: Push Button Start 50$ for a unique mod
    Ohio
    lol i had a dumb moment....
    that is a good idea for the overhead...i usually just keep my rubbers up there but the button seems even better
  12. #32 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    Thanks I wasn't sure and It's ok if it don't cuz It's the key I keep at home and the rents won't be able to get nothin in there
    I think I'm just gonna do it the way it was originally written up
  13. #33 Re: Push Button Start 50$ for a unique mod
    Minnesota
    I wish I had more time to work on finishing this...it's on my long list of things to do.
    2015 Evo MR
  14. #34 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
  15. #35 Re: Push Button Start 50$ for a unique mod
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
    Wow that is cool, I bet it would work.
  16. #36 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    after looking at the dimensions its like 3 1/2 by 2 1/2 and i measure the cubby hole and its 3 by 2. do you think there would still be enough room for the switch if the plate was behind the trim 1/4 of a inch all around?
  17. #37 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    so i ordered a button finally and im wondering what it would take to make my key only hit the acc-off-on and then i was thinking of putting it in the glove box by the trunk switch or in place of the cigarette lighter by the ash tray
    also what gauge wire?
  18. #38 Re: Push Button Start 50$ for a unique mod
    That would take some modification to the lock cylinder, not sure how to go about it.
    Button placement, hidden is nice but consider how often you get in and out and how many times you want to open the glove box just to start the car, or open the ash tray to hit the button. That is why I said I wanted it in the over head console power outlet area... hidden but the cover holds itself up so you can leave it open or close to conceal.
  19. #39 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Abilene, KS
    i was wondering how to mod the lock cylinder and i dont have a overhead console
  20. #40 Re: Push Button Start 50$ for a unique mod
    Jan 2012
    Philadelphia
    what did you have to do to move the HUD switch to the other side?
  1. push button start (progress thread)
    By z3r0 in forum Visual/Body Modifications
    Last Post: 12-01-2011, 08:38 PM
  2. push button start
    Last Post: 06-01-2011, 11:09 AM
  3. push button ideas
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 05-14-2011, 08:48 PM
  4. Stuck in park! Cant push shifter button!
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 04-05-2011, 09:23 AM
  5. Push button Start
    By crock in forum General Tech Discussion
    Last Post: 08-31-2010, 04:41 PM
