Impala should have the aluminum cradle. The oil pan and mount setup is completely different. The impala will be a breeze in comparison.
Sent from my SPH-D710 using Tapatalk 2
Twas not a breeze in my Impala. The U shaped engine bracket is the same as other 3800 pictures I've seen. Glendayle: Are you talking about the aluminum cradle shown in the middle posts of: Learn me about aluminum engine cradles - TCG Yes that's what I've got in my Imp. The passenger engine mount went into the oval hole on the right side of the picture where the cradle was standing up. How would the Al cradle make the job easier? Plus when searching for possible oil pan replacement, it appeared that Impala/GPs both use the same oil pan.
Not familiar with that thread. I guess I don't exactly know what all of the oil pan setups were. I switched to an AL cradle from an 03 Impala. I got an AL oil pan from an 08 Lacrosse(3800). It's got different motor mount bracket that just bolts to the bottom of the oil pan. I just assumed that the Impala's with the aluminum cradle had this new oil pan and mount setup. Maybe that change came later.
Cleaned surface thats why.
Its not "cast" like the pan.
And yeah they don't use a gasket on the aluminum pan, just a bead of that rtv stuff.
In this segment of "getting to know your aluminum oil pan" we will educate the locals on the details of the aluminum pans.
Some of the other body's that got the pan in 2000 had a gasket. Most are like the above and GM as a whole from what I've seen on the W body never used a gasket. Below is a pic of a 2000 H body pan, it takes a nice inlaid rubber gasket and like the engine sealant they use on the non gasket pan, it works great.
Here's what you can do with your oil pan when you launch the bearings and check out the cool gasket.
I was hoping the W-body pan had the same channel but ooo well.
Honestly, one you put on a pan with the engine sealant, it usually will never need to come off ever again.
Yup, here I go again. Now its time for a new oil gasket this time for the LS. Hopefully it goes much smoother this time, but its not really that bad to begin with. When you take in the consideration that you can save $300-$600 or possibly more, the job becomes relatively easy.....for the most part anyway LOL.
So you guys think a offset wrench would be better than using a regular 15mm wrench? I think I used a reg wrench last time which now im thinking is why it gave me a lil trouble.
Good thing I have Ratcheting wrenches, Makes it a lil easier. Just ordered some double box indexing ratcheting wrenches for future jobs like this which will work much better for me and maybe you to.
Ok one more question.
Other than physically looking different how are the L36 motor mounts different than the L26 mounts?
I am thinking about just using a L26 mount but noticed that the L26/L36 motor mounts have different part numbers.
