Thread: Oil pan removal: my how-to, my hell
Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
  1. #41
    GT Level Member glendayle's Avatar
    Salt Lake City
    Impala should have the aluminum cradle. The oil pan and mount setup is completely different. The impala will be a breeze in comparison.
    Sent from my SPH-D710 using Tapatalk 2
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  2. #42 Re: Oil pan removal: my how-to, my hell
    SE Level Member TallTexan's Avatar
    Houston, TX
    Twas not a breeze in my Impala. The U shaped engine bracket is the same as other 3800 pictures I've seen. Glendayle: Are you talking about the aluminum cradle shown in the middle posts of: Learn me about aluminum engine cradles - TCG Yes that's what I've got in my Imp. The passenger engine mount went into the oval hole on the right side of the picture where the cradle was standing up. How would the Al cradle make the job easier? Plus when searching for possible oil pan replacement, it appeared that Impala/GPs both use the same oil pan.
  3. #43 Re: Oil pan removal: my how-to, my hell
    Salt Lake City
    Not familiar with that thread. I guess I don't exactly know what all of the oil pan setups were. I switched to an AL cradle from an 03 Impala. I got an AL oil pan from an 08 Lacrosse(3800). It's got different motor mount bracket that just bolts to the bottom of the oil pan. I just assumed that the Impala's with the aluminum cradle had this new oil pan and mount setup. Maybe that change came later.
  4. #44 Re: Oil pan removal: my how-to, my hell
    Minnesota
    Quote Originally Posted by QUICKSILVER462 View Post
    I also have a leaking pan gasket, and the steel oil pan has some rust on it, so instead of buying a replacement steel pan and gaskets, I went ahead and aquired the parts for an aluminum pan since I have to replace the pan anyways. For the price of the aluminum pan was not much more than a steel pan and gasket, althouth the extra cost of the bracket and oil pickup tube was not too bad. I also get the benifit of the ease as installation by not having to reinstall the "U" bracket and the 4 hard to get too bolts.
    Also, thanks to those who posted the part numbers for the conversion to the aluminum oil pan!
    Just waiting for some cooler weather to do the swap!
    So there is no gasket for this pan only the sealant or RTV? Why does it look like there is a gasket in this picture?
  5. #45 Re: Oil pan removal: my how-to, my hell
    Cleaned surface thats why.
    Its not "cast" like the pan.
    And yeah they don't use a gasket on the aluminum pan, just a bead of that rtv stuff.
  6. #46 Re: Oil pan removal: my how-to, my hell
    In this segment of "getting to know your aluminum oil pan" we will educate the locals on the details of the aluminum pans.
    Some of the other body's that got the pan in 2000 had a gasket. Most are like the above and GM as a whole from what I've seen on the W body never used a gasket. Below is a pic of a 2000 H body pan, it takes a nice inlaid rubber gasket and like the engine sealant they use on the non gasket pan, it works great.
    Here's what you can do with your oil pan when you launch the bearings and check out the cool gasket.
  7. #47 Re: Oil pan removal: my how-to, my hell
    Minnesota
    I was hoping the W-body pan had the same channel but ooo well.
  8. #48 Re: Oil pan removal: my how-to, my hell
    Honestly, one you put on a pan with the engine sealant, it usually will never need to come off ever again.
  9. #49 Re: Oil pan removal: my how-to, my hell
    Feb 2013
    37.295091, -121.930053
    or untell you:
    A. rust your pan out
    B. Damage it/hitting low curbs
    C. have one huge hole punched in it.
    D. Didn't tighten it up correctly
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  10. #50 Re: Oil pan removal: my how-to, my hell
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Yup, here I go again. Now its time for a new oil gasket this time for the LS. Hopefully it goes much smoother this time, but its not really that bad to begin with. When you take in the consideration that you can save $300-$600 or possibly more, the job becomes relatively easy.....for the most part anyway LOL.
    So you guys think a offset wrench would be better than using a regular 15mm wrench? I think I used a reg wrench last time which now im thinking is why it gave me a lil trouble.
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  11. #51 Re: Oil pan removal: my how-to, my hell
    Jul 2012
    North Philly
    Good thing I have Ratcheting wrenches, Makes it a lil easier. Just ordered some double box indexing ratcheting wrenches for future jobs like this which will work much better for me and maybe you to.
  12. #52 Re: Oil pan removal: my how-to, my hell
    Minnesota
    Ok one more question.
    Other than physically looking different how are the L36 motor mounts different than the L26 mounts?
    I am thinking about just using a L26 mount but noticed that the L26/L36 motor mounts have different part numbers.
  1. What the hell?
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 08-09-2011, 11:46 AM
  2. Hell yes!
    By whitehead in forum Off Topic Discussion
    Last Post: 08-03-2011, 01:20 AM
  3. dtc's from hell
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2011, 05:44 PM
  4. Where the hell did this car go?
    Last Post: 09-09-2008, 09:30 AM
