Thread: Custom Intake and PCM Mount (pictures)
Results 21 to 40 of 50
  1. #21 Re: Custom Intake and PCM Mount (pictures)
    Bunnell, FL
    and i did the tray on my last gtp 4 or so years ago
    I'm a Sex Offender
  2. #22 Re: Custom Intake and PCM Mount (pictures)
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Quote Originally Posted by z3r0 View Post
    make a slit in the rubber w/. a razor blade and shove that **** in there
    This pic/post should be moved to a open cone sticky becuase holy hell my **** was wayyy different
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  3. #23 Re: Custom Intake and PCM Mount (pictures)
    SE Level Member soccerboi11's Avatar
    Oct 2011
    Virginia
    Instead of getting the tray from the s10. I just took the stock air box and cut it to fit it looks like that tray now but my pcm is a lot more snug in it, plus my intake fits also
  4. #24 Re: Custom Intake and PCM Mount (pictures)
    Nov 2011
    NY
    Did my set-up yesterday... info from here and other threads.
    Drilled the 7/16 hole for the sensor into the rubber coupling attaching the elbow to the TB, then cleaned the hole with an exacto knife. Sensor is nice and tight in there and it's all done.
    Custom Intake and PCM Mount (pictures) Attached Images
  5. #25 Re: Custom Intake and PCM Mount (pictures)
    Jan 2012
    At home
    Does the S10 tray work on the 97 GTPs? I believe that spot is a little different in the front (radiator overflow bottle), etc..
  6. #26 Re: Custom Intake and PCM Mount (pictures)
    Jul 2011
    Midwest
    I honestly don't know, hopefully somebody with a 97 can provide some insight...
  7. #27 Re: Custom Intake and PCM Mount (pictures)
    Jan 2012
    At home
    I thought I read somewhere that the PCN for the 97's are larger so, I would assume this won't work..
  8. #28 Re: Custom Intake and PCM Mount (pictures)
    Jan 2012
    At home
    z3r0 - I like your intake. Care to share exactly what parts you got???
    SE Level Member GiAnT4LYFE's Avatar
    Apr 2009
    Delaware
    Quote Originally Posted by coolone View Post
    What size rubber coupler and elbow did you use coming off the engine?
  10. #30 Re: Custom Intake and PCM Mount (pictures)
    Aug 2011
    Birmingham, AL
    Here's how I did mine. Just need to move my coolant bottle and find a way to fit my PCM and I'm good. Not too bad for a first mod if I say so myself. Throttle response and fuel economy have shown a little improvement, plus...it sounds cool!
  11. #31 Re: Custom Intake and PCM Mount (pictures)
    Nov 2011
    NY
    Sorry I missed this thread updates. I will post the part #'s and such later, I don't have them handy right now.
  12. #32 Re: Custom Intake and PCM Mount (pictures)
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Ok just finished with my open cone install on my 04+ GTP . Spectre # 9732 $40 at auto zone ( uninstalled the stock box and hooked up the cone filter directly to the MAF adapter). Cut my stock box in half with a skillsaw (the box has a line guide where it was glued together) cleaned it ziptied it and installed the PCM , I also ziptied the cone to the body .
    Before
    After
    Took about 1 hour to install, cut box and put together with zipties
  13. #33 Re: Custom Intake and PCM Mount (pictures)
    Needs the entire tag, not the .jpg code.
  14. #34 Re: Custom Intake and PCM Mount (pictures)
    Jan 2009
    Thanks bluegtp91, still excited about my cone
  15. #35 Re: Custom Intake and PCM Mount (pictures)
    Jan 2009
    Here is the pick the stock box getting cut in half
    Used the bottom half to install PCM (zipties to body)
  16. #36 Re: Custom Intake and PCM Mount (pictures)
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Thinks that's a reciprocating saw ("Sawzall"), boss.
    The evil LG8 still refuses to die.
  17. #37 Re: Custom Intake and PCM Mount (pictures)
    Jan 2009
    Quote Originally Posted by Steel Armadillo View Post
    That's correct! had just finished the install when i put the info here , dont know why I put skillsaw LOL
  18. #38 Re: Custom Intake and PCM Mount (pictures)
    Sep 2013
    Dayton Oh
    Where did you get the aluminum for the intake?
  19. #39 Re: Custom Intake and PCM Mount (pictures)
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    What technique did you use when drilling the hole in the 4" mandrel pipe?
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SKĀ® 4T65E Transmission Shift Kit, 180* Thermostat
  20. #40 Re: Custom Intake and PCM Mount (pictures)
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    probably used a drill... LOL
    04 GTP -HAI, 1.9 rockers.
  1. Custom FWI Pictures
    By Taz Magister in forum How To Write-Ups/Tech Tips
    Last Post: 05-12-2011, 11:56 AM
  2. Custom phone mount in small console compartment
    By Dzebold in forum Visual/Body Modifications
    Last Post: 04-12-2011, 04:06 PM
  3. Pictures of my custom made CAI
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2009, 12:06 AM
  4. Custom Airbrushing (Pictures)
    By Street Wolf in forum Visual/Body Modifications
    Last Post: 03-12-2008, 07:06 PM
  5. custom ipod mount for the 97-03 guys
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2008, 08:01 PM
