Thread: How to change coolant elbows
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 93
  1. #1 How to change coolant elbows
    Tools required:
    Rachet
    8mm wrench
    10mm deep socket
    13mm deep socket
    15mm shallow socket
    15mm Deep socket
    Piece of steel wool
    Small amount of lubricant (oil/vasoline/grease)
    Catch basin for coolant
    Dorman 47065/Napa 660-1736/GM Dealer (Coolant Elbows)
    This is written for a 99+ W body or 00+ C/H/G body, if your car is a Series II motor and before these years, please see the note at bottom of writeup.
    Unhook the negative terminal of the battery 8mm
    Untension the accessory belt shallow 15mm
    Move the coolant overflow and lay it on the front of the motor.
    Remove the alternator from the tensioner bracket 13mm/15mm
    Remove three bolts holding the tensioner bracket to the cylinder head (see picture)
    Wiggle the bracket and it will come off. (See note if you have an earlier year, this is important)
    Remove any pieces of elbow stuck in the LIM, timing cover or the tensioner bracket.
    Use the steel wool to clean the old elbow's ridge out of those areas.
    Lubricate all o-rings on the new elbows
    Install the elbow with equal sized ends in the top hole of the tensioner and the other into the bottom hole.
    Line up the elbows and wiggle the tensioner into place
    Start all three bolts to hold the tensioner to the head
    Tighten the bolts a little at a time and gently wiggle the upper elbow as you do this until the bolts are tight and the upper elbow still wiggle slightly.
    Reinstall the alternator
    Reinstall the belt
    Reinstall coolant overflow
    Hook up battery
    Fill with coolant and bleed system.
    Note: If your car is 96-99 for the bodies listed in the important note, then your alternator bracket has a metal lower coolant elbow cast as part of the assembly. This is important because you can break the timing cover if you pull it from driver side to passenger side. To remove the alt bracket you want to wiggle it front to back in the engine bay only. This will feel like it takes forever. Do not give up and if your upper coolant elbow (plastic) breaks, that is fine. Wiggle and remove as gently as possible. This will keep you from breaking a timing cover.
    Easy
  2. #2 Re: How to change coolant elbows
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    What can I do if my motor keeps blowing them out?
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  3. #3 Re: How to change coolant elbows
    Kansas
    What do you mean blowing them out? They are plastic and crack/break after time.
  4. #4 Re: How to change coolant elbows
    Jun 2011
    Watertown, SD
    Every new set I put in the pop out after couple 100 miles
  5. #5 Re: How to change coolant elbows
    When you say it pops out.. your cooling system should have ~16psi of pressure based on the cap. The tensioner should hold the elbow from popping out of the lim and the lim holds it from popping out of the tensioner.
    I'd check for an overpressurized issue.
  6. #6 Re: How to change coolant elbows
    Jun 2011
    Watertown, SD
    I had it tested and at idle its around 15psi and when i rev it to 4k its jumps to 30psi. So cap must be bad?
  7. #7 Re: How to change coolant elbows
    Jan 2012
    Philadelphia
    i just blew one out today during WOT i replaced the last one a while back maybe 5 months ago or so but mine snapped it didn't pop out do you think ill be okay with the new one? and how can i do a pressure test? and if i put a new cap on would the pressure be normal? i also blew out a rear heater hose back in September or November but they looked like they needed to be replaced any way
    i have a 97 GTP i just replaced the coolant elbow today
  8. #8 Re: How to change coolant elbows
    Saratoga NY
    Quote Originally Posted by grandamle91 View Post
    More than likely
    Good write up Bill!!
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  9. #9 Re: How to change coolant elbows
    May 2012
    West Haven
    i cant get the belt off. i loosened the nut holding the idler pully but the belt wont budge.
  10. #10 Re: How to change coolant elbows
    The nut on the alternator bracket/tensioner when pushed counter clockwise should move the pulley and release tension.
  11. #11 Re: How to change coolant elbows
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    in other words tighten it back up and keep tightening till the pulley starts to move lol
  12. #12 Re: How to change coolant elbows
    Quote Originally Posted by bps02gtp View Post
    Not necessarily.
    I said counter clockwise, which most would consider loosening. However being a tensioner it has a reverse threaded bolt, therefore by telling him the direction....I tried to take the possible confusion out of the equation.
  13. #13 Re: How to change coolant elbows
    Nov 2010
    Illinois
    in order to move the pulley you have to go the same direction as tightening dont you? doesnt matter if its counter clock or regular clock? thats y i told him to just tighten because thats easier to figure out then knowing if its reversed thread or not.
  14. #14 Re: How to change coolant elbows
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Ok kind of old topic but I have a 98 and the cast elbow seems to not be sealing up just right. The O ring from the plastic elbow I don't use was I supposed to? Any little tricks I just used the same O ring since it wasn't old and slid it on. I know you got a tip for me Billy
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  15. #15 Re: How to change coolant elbows
    It's not an old thread..it's a How to ...lol
    Yes, use the big o-ring off the elbow you didn't use. That's the correct ring for your metal elbow.
  16. #16 Re: How to change coolant elbows
    Oct 2008
    IL
    Damn that's what I thought. I just reused what was on there even tho I knew deep deep down it was that O ring I even took it off. Oh well I'll just keep an eye on it. I'm not 100% it's leaking from there since there's well no more leak just may be coolant left over from taking it apart in the first place. Now I know tho
  17. #17 Re: How to change coolant elbows
    GT Level Member 40th GP's Avatar
    Utah
    So I changed my elbows when I did the LIM about 2 years ago. I went with the Dorman replacements, but when I had it all back together coolant would seep out around the upper elbow (nothing major, but just enough to smell the burning coolant on the engine and see a little wetness, and have to add a touch of coolant every other week or so). I am kind of anal and that was not going to work for me, so I went ahead and paid about 5 times more and bough new elbows from the dealer. Put them in and same thing is happening---slight seepage from the upper elbow. Might be worth noting that the original elbows were not leaking, just changed them as a precaution while I was doing the LIM. I also managed to get them out without breaking them, but they are hard and brittle and figured new was the way to go.
    Have I installed it wrong? I can't imagine 2 different sets of new ones being bad. I can push in on the upper elbow and feel it go in just ever so slightly. I am thinking that it is just not seated all the way into the manifold, but the tensioner bracket piece they mount in is tight. Might also be worth noting that when I had the LIM off I had it blasted and steamed at an engine shop, so it looks like brand new and there was no old crap in there that could be causing a leak.
    Any ideas??? It is driving me nuts and I am going to tear back into it this weekend because my power steering has sprung a leak. Thinking I might replace the water pump while in there as well just so when it is all buttoned back up everything will be done, but I need some ideas on this crazy elbow seeping issue...
  18. #18 Re: How to change coolant elbows
    Take steel wool and clean the holes where the elbows are located. Likely there's a ring of crud built up that's causing you to leak. Also check out Rockauto part number 47065HP, aluminum are available now.
  19. #19 Re: How to change coolant elbows
    Utah
    Nice, those look sweet and you get both for less than I paid for one at the dealer. However I would be concerned that I would put those in and have the same problem again. When I did the LIM I had the manifold blasted and steamed at an engine shop and it was basically brand new when I put it back together. I can try the steel wool and clean the holes again, but I highly doubt there was anything in there that could be causing a problem since it was clean as can be when it went together and they leaked from the get-go. Any other ideas?
  20. #20 Re: How to change coolant elbows
    Yes.. magic.
    If the bore of those holes are clean, and have no cracks or flash from the casting etc... then it would have to be an issue with the elbow or the install. Since you changed it again...and these are a very simple install. It's tough to have a different idea about what it could be.
  1. Need to replace coolant elbows
    By Posty101 in forum Engine
    Last Post: 06-02-2011, 02:22 PM
  2. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  3. How do you replace the coolant elbows?
    By Mercenary in forum General Tech Discussion
    Last Post: 07-19-2010, 06:50 PM
  4. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
  5. Coolant Elbows for 2000 GTP
    By nickbuol in forum General Tech Discussion
    Last Post: 07-21-2009, 10:51 PM
