Thread: The Ultimate Cheap Mod Thread (Free to $50)
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 88
  1. #61 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Bunnell, FL
    Quote Originally Posted by TeeWX View Post
    Only on grandprixforums are any of those things considered actual mods.
    i'd hate to see your car debadged and have hid's or painted shiny ****
    I'm a Sex Offender
  2. #62 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GTP Level Member
    Nov 2011
    Kansas
    Quote Originally Posted by E IN v Y View Post
    Gut out airbox - Free
    Did this today and slapped a big filter on it... so much better. The stock airbox had leaves and all kinds of stuff in it.
  3. #63 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    Quote Originally Posted by z3r0 View Post
    What in the eff did you just attempt to say?
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  4. #64 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Oct 2011
    Toledo, OH
    Quote Originally Posted by develand View Post
    Ya know, I couldn't believe how many leaves were in my airbox when I took it out. And it wasn't even fall yet.
    7"
  5. #65 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    getting a pin stripe on your car is a nice easy mod. if you like to do it yourself and trust it to be straight its about $20-30 for a roll of pin stripe. i took my car to the shop today to see about getting the one i have redone (its got a lot of oxidation. and i dont trust myself to do it straight) but they said itd only be about $50 which i thought was amazingly cheap
    more info on this dogbone flipping would be awesome
  6. #66 Re: The Ultimate Cheap Mod Thread (Free to $50)
    But pinstriping looks horrible on almost every single car i've ever seen.
  7. #67 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Nov 2011
    Decatur
    then i guess youve never seen my car. or you just have bad taste! =P
  8. #68 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    It added 3hp to my 1978 Station wagon!
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  9. #69 Re: The Ultimate Cheap Mod Thread (Free to $50)
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    shift kit did this recently tot he GTP when i changed the fluid. cost was $13 before trans fluid i just got normal dex III as there is not need for any thing higher in are tranmissions they where not designed for it
    Credits: ReaglGS
    Synopsis: Install a shift kit utilizing shims in the transaxle shift pressure accumulator.
    Difficulty: 3/5. Requires dropping the bottom transaxle pan, removing the shift pressure accumulator, changing the transaxle filter, and refilling the transaxle with fluid.
    Parts required:
    The parts you need are determined by whether you want to do the medium (light street/strip) or hard (heavy street/strip) shift kit. There's also an optional spring used to firm up the 1-2 shift (usable with either medium or hard). The shims used are available from McMaster-Carr online.
    Medium Shift Kit
    (2) 92415A865 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 1/2" Length, 1/4" Screw Size
    (2) 92415A867 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 3/4" Length, 1/4" Screw Size
    Hard Shift Kit
    (2) 92415A869 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 1" Length, 1/4" Screw Size
    Required for both kits
    8-10 quarts of Dexron III or Dexron VI transmission fluid
    Transmission filter
    Optional for either kit
    2-3 shift accumulator spring (used to replace the stock 1-2 shift spring). GM part number 24203977.
    Directions:
    1. Raise the front of the car and begin loosening the 10mm bolts on the transmission pan. Loosen the ones toward the back of the car more than the front so the fluid drips toward the long end of the pan. Allow it to nearly fully drain to avoid a huge mess (which is going to happen anyway, it's just saving you at least a little bit of a headache). Remove the pan and clean it off along with the magnet and gasket.
    2. With the pan removed we can now access the filter. Pull it straight down firmly, twisting it side to side to break it loose. Change the filter neck gasket if required.
    3. Now that the filter is removed, we can now take out the accumulator itself. It's seen below in color, along with the bolts that need to be removed numbered for easy reference. Once these bolts are removed, the accumulator will want to drop down and spill transmission fluid everywhere. Use one hand to hold up the accumulator and another to remove the bolts by hand once they're broken loose. Pull the hard metal lines out of the accumulator using care as not to bend them. Note the location of each metal line.
    4. Once the accumulator is removed, place it face-up and remove the remaining bolts. Remove the cover. Inside you'll find two cylinders, both with visible springs. Do one side at a time. Pull up on a spring and remove it. Try to take out only the small spring and the metal plate it sits on, leaving behind the rod and large spring. Put one of the longer shims at the bottom of the rod. If you're using the optional 2-3 spring, and you're working on the 1-2 accumulator, remove the small spring from it's base, and press the new spring onto it. Reinstall the small spring and base onto the rod. Add a short shim in the middle of the spring. Repeat for the other side.
    5. Reinstall the cover to the accumulator. Bolt it back into the transmission, using extreme care to reinstall and reseat the hard metal lines. Make absolute certain the lines are reseated properly. If they're not, you'll be left with a slipping transaxle that burns up clutches. In case you forgot where the lines go, here's a picture:
    6. Reinstall the trans axle filter. Put the pan cover back on, and fill the trans axle with approximately 8-10 quarts of ATF, depending on how much fluid you lost. Once you're sure you have the proper fluid level, take the car for a spin and make sure that it's not slipping. If it's all good to go, enjoy your new shift kit! Your wallet will thank you for it!
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  10. #70 Re: The Ultimate Cheap Mod Thread (Free to $50)
    you might want new accumulator seals when you do that.
  11. #71 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Feb 2010
    my house
    only if they are torn if not they should be fine. either way they are not expensive the trans int he GTP only has 20k on it after a full rebuild so i just reused the seals it had as they where fine
  12. #72 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Ah, that's fairly new still.
  13. #73 Re: The Ultimate Cheap Mod Thread (Free to $50)
    SE Level Member 99gtp3's Avatar
    Apr 2012
    mn/wi
    Mater nicely done.. you buy your auto parts at walmart? If i was your Car id be pissed and break dont use that super tech sh!t..
  14. #74 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Sep 2012
    Ohio
    Quote Originally Posted by Taz Magister View Post
    you can probally get a ubend cutout and pipe welded in for 50 bucks or less
    also polish exhaust tips basicly free if you have a peice of sand paper a few bucks if you don't
    remove the onstar antenna if you have it...free
    make a gt or gtp grill badge...free
    polish engine braces free and they polish in like 2 hours
    paint your dog bones and what not $10 bucks
    egr delete... not sure what that runs but not that much
    port your stock manifolds... if you have a dremel then all you need is some cash for more wheels and tips..
    you could spend a year working on one of these cars and only spend a few 100 just got to know a few things
    How do you make aa grill badge?
  15. #75 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Jan 2012
    Philadelphia
    smooth valve covers (gtpeddie)
    $16-$30 range
  16. #76 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Jan 2012
    Philadelphia
    Quote Originally Posted by 98GTPnoob View Post
    get a "gt" badge and if you have a gtp use the "p" from "grand prix" then super glue it to the grill like this
  17. #77 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GT Level Member Beelzeboul's Avatar
    Racine
    I havn't done it myself but I love the polished look on the supercharger seems like it could get done pretty cheap
    painted dog bones supercharger and braces for 5 bucks one can of engine enamel Flame Proof could have probably got one - two coats on my calipers with the same can of paint but they were already done when I bought the car
    plasti dip rims should be up there too as a pretty cheap appearance mod
    one I really liked was the rear divots in the bumper gettin painted another color to accent
    and last but not least is the door trim deletion although I think it almost makes them look a little bland alot of people like it and it does look nice for pretty cheap
    I'm sorry officer I didnt know I couldn't do that
  18. #78 Re: The Ultimate Cheap Mod Thread (Free to $50)
    antioch ill
    i dont think it would be that cheap to delete that trim because you have to fill the 3 holes and repaint
  19. #79 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    do we have a how to for polishing the stock tips also one for painting headlights and the corners?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by mofford12 View Post
    Stock tips is just sandpaper, or a wire brush drill attachment.
  1. *** Ultimate HID thread ***
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 04-07-2017, 09:59 AM
  2. .
    By Leon in forum Audio, Security & Visual Electronics
    Last Post: 10-13-2009, 05:54 AM
