Thread: The Ultimate Cheap Mod Thread (Free to $50)
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 88
  1. #21 Re: The Ultimate Cheap Mod Thread (Free to $50)
    SE Level Member 97PAGTP's Avatar
    May 2011
    Williamsport, PA
    Quote Originally Posted by SilvaMan61 View Post
    black housed headlights. take em off open them up and paint them. cost ~$5 just the cost of spray paint and masking tape.
    Pics of this done and/or a link to a how-to? I am interested in seeing how you did this and what it looks like when finished.
    Thanks
    1997 Dark Teal GTP coupe, Magnaflow highflow cat, Borla mufflers w/ Magnaflow tips, Wizaired, LS1 crossed drilled/slotted fronts, stock crossed drilled/slotted rears, tinted tails, clear corners, triple pod w/ Glowshift gauges, STB, chrome grilles, junk transmission, 200k+ miles...
  2. #22 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Bunnell, FL
    Quote Originally Posted by 97PAGTP View Post
    Thanks
    take headlights off car, bake at 250 for 15 mins
    open headlight, tape off and paint rebake same specs put lights back together
    (you may need to polish your lenses depending on age reinstall enjoy
    use black rtv if needed
    I'm a Sex Offender
  3. #23 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Sanding the exhuast tips. Under $30 if you want to really want to slowly change the grit.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  4. #24 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Omaha, NE
    Does anybody else see this thread leading to more ricers in GPs than we already have?
    I made gutter guard grills for my first grand prix... It took under $10 in gutter guard and a couple zipties. I used snips to trim the gutter guard and cut the hell outta my hands so wear gloves if you're going to attempt this.
  5. #25 Re: The Ultimate Cheap Mod Thread (Free to $50)
    TYSir
  6. #26 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Cheap mod?
    Fuzzy dice hanging on rear view mirror
  7. #27 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Pennsylvania
    Doesn't an EGR delete require a tune? So... $150, at the cheapest?
  8. #28 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Omaha, NE
    You don't have to do a tune for egr delete as long as you can live with the CEL.
    LED interior lights for the floor board ~$25 to do the whole interior and a switch. Parts can be acquired at autozone/walmart...
  9. #29 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Disable drl's
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  10. #30 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Donating User Odi's Avatar
    Chicago South Suburbs
    Interior LED's. If you ebay the parts, its around $50 + i had a spare led for my license plate light. And its so bright inside.
  11. #31 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Pennsylvania
    Does that pass emissions in most states?
  12. #32 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Omaha, NE
    My state doesn't have emissions, so I don't know.
    If you know someone with DHP, they could remove the code for you for free, and you should be good to go.
  13. #33 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Odessa, MO
  14. #34 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Bunnell, FL
    contradicting much?
    I'm a Sex Offender
  15. #35 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Weight reduction
  16. #36 Re: The Ultimate Cheap Mod Thread (Free to $50)
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Quote Originally Posted by Taz Magister View Post
    remove the onstar antenna if you have it...free
    How do you do this? Or the better question is what is the easiest way to do this?
  17. #37 Re: The Ultimate Cheap Mod Thread (Free to $50)
    pry it off.
  18. #38 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Nov 2010
    With a putty knife or something?
  19. #39 Re: The Ultimate Cheap Mod Thread (Free to $50)
    sure.
    I pulled it off with my hands.
  20. #40 Re: The Ultimate Cheap Mod Thread (Free to $50)
    Nov 2010
    Oh ok, so its that easy. Thanks
  1. *** Ultimate HID thread ***
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 04-07-2017, 09:59 AM
  2. .
    By Leon in forum Audio, Security & Visual Electronics
    Last Post: 10-13-2009, 05:54 AM
