Thread: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
Results 21 to 40 of 76
  1. #21 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    are you modded?
    If yes, 3.4 is a good start.
    If its just bolt ons, start with the 3.8.
  2. #22 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mar 2012
    Hays, KS
    Since the gen v snout is shorter than a gen lll, is there an issue with the belt lining up straight?
  3. #23 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    no.
    everything will be the same.
  4. #24 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    The body of the charger is longer, therefore the snout is shorter. This makes the belt placement the same as a Gen 3
  5. #25 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mar 2012
    Hays, KS
    What is the pcv and the purpose of it?
    Mercer, Pa
    It is positive crankcase ventilation. Its purpose is to reduce emissions, and reduce sludge.
    When the engine has high vacuum some air is routed through the crankcase and then sucked into the intake manifold. These air is metered (measured by the mass air flow) so that all air going into intake is accounted for an the proper fuel is delivered.
    This helps reduce moisture from accumulating in the crankcase. It also keeps the engine from smoking a little bit like the pre PCV cars did.
    Emmisions are reduced because that smoke or vapor has some hydrocarbons in it that is now sucked into the intake and burned.
  7. #27 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Jan 2012
    Philadelphia
    im converting over to a gen 5 i just bought the blower yesterday, i have a few questions though i see in the thread it says you can just machine your gen 3 intake manifold i would rather do this to save money instead of buying a gen 5 intake manifold. but are the manifolds almost the same besides the air inlet area? so where the red arrow is i have to machine that to match the gasket right? and where the blue arrow is pointing it looks like on the gen 5 intake there was something else that goes there like a more elongated hole? and where the yellow circles are is that where the fuel rails bolt up? is it basically the same manifolds besides the air inlet? should i just machine mine i want to save money if i have the option.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I did this write up quite a few years ago when the Gen V and L32 manifolds were kinda hard to come by. These days, the cost of machining will probably be more than u would pay for an l32 manifold.
    Sent from my DROID RAZR using Tapatalk 2
    For all your 3800 needs:
    Mercer, Pa
    Same manifold just machine the air inlet bigger. (red arrow)
  10. #30 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Jan 2012
    Philadelphia
    true but i have a friend who could machine mine while its off he's helping me do the swap is it worth it or should i just buy a L32 manifold? did you machine yours or do you have the L32 manifold
    Mercer, Pa
    Note once machined bigger for gen 5 the air inlet is to big for gen 3 to seal. so it is not backwards compatible.
    Mercer, Pa
    I machine mine bigger. About 15 minute job on manual milling machine.
  13. #33 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Jan 2012
    Philadelphia
    Quote Originally Posted by sseilmnop View Post
    so what your saying is once machined bigger you cant go back to a gen 3 right
    Mercer, Pa
    Quote Originally Posted by gtpeddie View Post
    Yes
  15. #35 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Jan 2012
    Philadelphia
    thanks for the help guys
    i started cleaning it up a bit today
  16. #36 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Jul 2008
    Tampa, FL
    dang, that looks good. i sure need to get one of them there supercharger thingymabobs.
  17. #37 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Oh man this is exactly what I was looking for, I really want to do this and I think I can. A year down the line or maybe this winter will see! Awesome write up.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  18. #38 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    GTP Level Member joe0813's Avatar
    Boston, MA
    awesomeee
  19. #39 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Kemmerer, Wyoming
    what would happen if you didnt install a breather on the valve cover or run a vacuum line from the evap on the gen 5 to the L67 throttle body?
  20. #40 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    nice write up im i got to make a commet to tag this for later!
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  1. Replies: 716
    Last Post: 01-06-2018, 05:44 PM
  2. Eaton M90 Gen V supercharger problems
    By 05GTPcmpg in forum Off Topic Discussion
    Last Post: 06-04-2011, 11:20 PM
  3. Need pcv help for IC'd GenV swap
    By 00gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 04:44 PM
  4. Can I install eaton m62 supercharger on L36 engine?
    By SBB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 01:15 PM
