There's already a fitting on 04+ so I block off the nipple on the gen v supercharger and connect a hose from valve cover to intake between maf and plate? And that's it?
If the PCV is external on the gen V, then that PCV will still have to be hooked up as well as that will provide the PCV for the rear head.
Matt, I thought you only had to run a hose from the front valve cover to the intake like sseilmnop said. Could you explain what you suggest instead?
Most intercooler cores leave the rear PCV function alone.
If his PCV leaves the blower from that nipple on the back, it still has to be connected otherwise there will be no PCV for the rear head unless you tapped both valve covers.
Up to you. I think it'd be cleaner to utilize the existing nipple/system for at least one head.
Hose from rear nipple, hose from front valve cover, into T and single hose to intake
Okay, so what if the PCV is blocked like in sseilmnop's core? Do you need to tap the rear valve cover as well as the front?
Yes, but neils core has rear PCV.
Then you don't have any rear PCV?
Hey sseil i just recently got my hands on a Gen V. My current setup before getting a gen V was a zzp stage 2 intercooler setup with ported gen 3 blower and ported tb. Basically from what ive read.....If i want to replace my gen 3 with my new Gen V and want everything to work correctly,....i should drill a hole and tap my ported L67 Throttle body as you pictured on the first page.....and then run a line from that tapped hole to the nipple on the back of the Gen V? Is that all i have to do? And should i use a L32 supercharger gasket? I was using an l67 supercharger gasket with my gen 3.
ok cool will do thanks again
I connected my N* TB nipple to the back of the Gen V and i think i have full pcv function. How can i tell if i dont? I am getting vacuum from the rear nipple on gen v when i tested.
Your setup.
Gen 5 supercharger
Gen 3 intercooler
Gen 3 LIM W/ zzp tiny groove for PCV
North star TB
You are getting vacuum at the rear nipple on super.
Im not sure that the tiny groove on gen3 LIM works with gen 5 supercharges. And it is pretty easy to get manifold vacuum leaking by the gasket into the PCV passages which would give you vacuum and boost.
What do I do about the evaporate? My gen v to N* adapter doesn't have a fitting for it to plug in so I capped it off earlier and then werytime I went to fill up gas would pour out of the gas tank neck and wouldn't allow me to fill up. Can I add a T and tap into the pcv vacuum line?
Sent from my SGH-T989 using Tapatalk 2
I used the stock location on the back of the gen V under the pcv vacuum nipple and used a gen v evap. You'll need to flip your n* adapter upside down to use which doesnt effect anything as long as your coolant holes in the lim are plugged.
does the l67 okay cool.
