Thread: How to get PCV to work instead of valve cover breather!
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 122
  1. #21 Re: How to get PCV to work instead of valve cover breather!
    it doesnt have a provision for rear PCV?
  2. #22 Re: How to get PCV to work instead of valve cover breather!
    Minnesota
    Depending on what kind of IC core you have you either have a funcational rear and non functional front or you don't have either. If you don't have either you can run a front valve cover on the rear head and a catch can off the rear.
  3. #23 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    I didn't do my PCV research before I got or installed my IC so I have no idea what it has PCV wise, I'll just post pics. Right now I just have a breather on front valve cover and a breather on back SC nipple which idk if it even does anything.
    Slowest 'Cooled Gen V ever
  4. #24 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    LIM being used, bottom one
    IC on motor
    I have some more if these don't help.
    Mercer, Pa
    Quote Originally Posted by Pure2sin View Post
    Is the older WBS Intercooler drilled in the back for PCV? Do you have any pictures of the Intercooler?
  6. #26 Re: How to get PCV to work instead of valve cover breather!
    Yeah, it has rear PCV.
  7. #27 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    Matt, does that mean its working though? I'm pretty lost...
    Mercer, Pa
    If it has the back hole and the matching hole in the intake manifold then drilling the port on the L67 throttle body should work.
  9. #29 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    I feel pretty dumb but I don't even know what hole you're talking about lol. I posted my LIM, do you see the hole there? I have a few more IC pics if you need them...
    Mercer, Pa
    I started typing and missed the pictures of the WBS Intercooler. It looks like there current generation Intercooler and intake manifold.
  11. #31 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    Quote Originally Posted by sseilmnop View Post
    So what does that mean? Lol
    Mercer, Pa
    See circled hole in blue.
    How to get PCV to work instead of valve cover breather! Attached Images
    Mercer, Pa
    You have the rear PCV hole.
  14. #34 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    Awesome, thanks for that lol. So what needs to be done to the rear to make it work correctly?
  15. #35 Re: How to get PCV to work instead of valve cover breather!
    Nothing.
    It should be working already.
  16. #36 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    But on a stock L32 the SC nipple connects to the TB between the butterfly and MAFS. My nipple just has a breather on it. Doesn't something need done?
  17. #37 Re: How to get PCV to work instead of valve cover breather!
    Well you can hook it up like an L32 and have metered air.
  18. #38 Re: How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    Drill and tap TB just like the pictures show.
  19. #39 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    So should I tap the TB and then have a split line going off that to the front valve cover and to the back SC nipple?
    Mercer, Pa
    Put a cap on the nipple on back of supercharger, it doesn't go anywhere. Connect just like I show.
  1. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  2. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
  3. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
  4. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
