Thread: How to install headers: The easy method
Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 183
  1. #101 Re: How to install headers: The easy method
    Banned
    Jan 2013
    maryland
    Did you tighten all the bolts on the front manifold? Is your header and crossover pipe aligned with no space between? Had the same issue but tighten the bolts and it fits wit no fan rubbing
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #102 Re: How to install headers: The easy method
    Did you try removing the metal fan shroud sometimes that gives you a bit more clearance and also check the condition of your mounts so that the engine is moving back and forth causing the header to continue to touch.
    04 Comp G.
  3. #103 Re: How to install headers: The easy method
    Oct 2011
    Puyallup WA
    I had to remove metal shroud on fan motor with my sd headers
    08 G8 GT - exhaust Tune
  4. #104 Re: How to install headers: The easy method
    Nov 2013
    Boulder Hill, Illinois
    I'll double check on the tightness of the bolts. Metal shroud is off at the moment. Guess I'll have to double check everything. Thanks!!
  5. #105 Re: How to install headers: The easy method
    Yeah 97-98 fans are bigger than the 99+ fans mine were very close to the fans, I couldn't even get a finger in there.
    Sent from A Galaxy Far Far Away........
  6. #106 Re: How to install headers: The easy method
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Lose the dog bones and rock the motor. I literally used a long pipe to rock the engine back and forth to make it work.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  7. #107 Re: How to install headers: The easy method
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Quote Originally Posted by h0wl0ngcanitbe View Post
    x2.....but use ratchet straps....much easier....
  8. #108 Re: How to install headers: The easy method
    Marysville WA
    Quote Originally Posted by rodguezsciii View Post
    Yeah but for the front header ya gotta lose the straps and rock the motor towards the firewall with a pry bar or at least thats what I did.
  9. #109 Re: How to install headers: The easy method
    Odd you guys mention that.. I haven't had to rock, except I think one car. Fans seemed huge
  10. #110 Re: How to install headers: The easy method
    Marysville WA
    If I had a second set of hands and had removed the studs I most likely could have but as I had it I could not on my own without ricking the motor a bit. I was a bit apprehensive at first but then realized it was a GM motor so went at it. Worked for me and then I had a big smile on my face.
  11. #111 Re: How to install headers: The easy method
    Well.. I remove the studs, so yeah.. lol
  12. #112 Re: How to install headers: The easy method
    Oct 2011
    Toledo, OH
    Thanks Bill! Your guide made installing the headers a breeze. The hardest part was the stud under the EGR, and the #2 boot, I couldn't get leverage on either.
    7"
  13. #113 Re: How to install headers: The easy method
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Does this take about 5 hours? I plan on ordering my Speed Daddy headers here within a couple weeks and I have to have them installed within a two day window so hopefully it wont take that long. Also, this write up says to pull rear manifold through the bottom but recently I have seen alot of things that say its easier to do pull it from the top. Any opinions on here?
  14. #114 Re: How to install headers: The easy method
    Oct 2011
    Toledo, OH
    Unmodified Speed Daddy rear will not fit through the top. You can remove the stock manifold without dropping the sub frame, but you'll have to drop it to put the header in so why struggle trying to pull it through the top?
    You could probably do it in 5 hours of you know what you are doing and don't hit any snags. For instance, the #2 plug wire being fused to the spark plug.
    7"
  15. #115 Re: How to install headers: The easy method
    Apr 2012
    Indiana
    Okay, gotcha. That sucks I havent heard of anyone that had the wire fused to the plug haha wow
  16. #116 Re: How to install headers: The easy method
    Oct 2011
    Toledo, OH
    No dielectric grease + 95k miles = PITA
    7"
  17. #117 Re: How to install headers: The easy method
    Apr 2012
    Indiana
    Hopefully I dont have that to look forward to...Im at 101k so its a good possibility
  18. #118 Re: How to install headers: The easy method
    Quote Originally Posted by 2FASTGTP View Post
    the hard part was getting the stock crap off, putting the headers on is cake really. get a 13 mm ratcheting wrench too, you can thank me later on.
    plan on it taking most of the day if working solo.
  19. #119 Re: How to install headers: The easy method
    Aug 2013
    McDonald PA
    Ratcheting wrenches are gods gift to man. Just saying
  20. #120 Re: How to install headers: The easy method
    the middle header bolts dont really let a ratchet fit square on the bolts, the two stud bolts on the end a deep 13 mm and ratchet work fine. same for the back manny bolts.
  1. Easy way to install a new wheel stud?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 08-12-2010, 05:44 PM
  2. SD Headers install question
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 12:51 PM
  3. how to install headers
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 02-15-2010, 02:08 PM
  4. Anyone around KC, MO install headers?
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 05:28 PM
  5. anyone know how to install headers?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 05:54 AM
