First of all I probally put this in the wrong place so sorry for that.
Anyways I needed a weekend project and I also needed an intake so I made one and heres some pictures for you all. Feel free to tell me if i did anything wrong.
remove the headlights, there's two screws in the wheel wells for the bumper cover, then thrers the three top push pins and then you MIGHT have some underneath. If not then the whole thing will come right off....you can do it in literally 10 minutes if you know how.
Get that thing on there...it looks awesome...probably the best homeade intake i've seen.
yea I looked at it and thought about it and I think Im just gonna wait til its a little warmer and I the garage picked up a bit more and plenty of time cause I be all ocd about it and start working on other parts that were hidden by the bumper in the meen time I need to figure out what im going to do with the pcm tray so it dosent look retarted
You don't have to remove the bumper to install that thing...just take out the airbox and toss the PCM in there somewhere.
yea its 4" id
if i just put it where the airbox is ill proabally have to remove a few inches but i might do that and then when its warmer maybe put it in the fender more one thin im worried about is water. Do these things stop water from getting in at all cause i doubt they do
Like I've said before...unless your forging the river at Devil's rock...with Typhoid fever...and 2 dead oxen...you don't have to worry about any water in the intake.
K sounds good then ill probally put this thing on today then and just leave it where the airbox used to be cause I see no point in moving 2-3 more inches to see a gain of what .05 hp and maybe half a degree colder air
one other questioun does it matter where I put the IAT sensor or can it just go anywhere on the intake? cause I would like to put it on the bottem side so you cant see it
I'd put it as far away from the exhaust as you can as long as your putting it back in...it basically just does what it is called...it senses the temp of the air coming in your intake tract...so the closer it is to colder air the better reading your gonna get.
