This writeup on Engine Motor Mount Replacement has been added to the How To section and can be found HERE.
BTW, before anyone says anything, I did fix my supercharger belt while I was in here. I got the cover off and noticed it was one rib off on the balancer pulley, you can see the one rib on the outside of the pulley in these pics. Probably been that way since my coolant elbow fiasco (which is still on the to do list to fix). Luckily, it didn't damage the belt or worse, shred it on the Power Tour.
VERY VERY nice write up. Should most definitely be put in the How To section. Thanks for taking the time to write this up. 5 star vote and rep points for you my friend.
Good write-up, I may do this when I have my heads off for the top swap(motor will be much much lighter)....
Oh and + rep for you
Yeah Yeah... filter is getting swapped on the next oil change. If it makes it long enough. LOL!
Give me a recommendation that I don't have to go out of my way to find.
Well done indeed!!!!
Got pics of how your dogbones are aligned? Noticed any difference? My Napa mount was a hair shorter than the stocker apparently because my passenger side is a little lower than the other side making my dog bones slightly crooked. I spaced out the motor mount a little, it still ain't right though IMO.
I've been thinking about just paying the $$$ and getting OEM GM lower motor mounts (I should of done this in the first place!).
to add another tip for getting the studs seated in the holes top and bottom-- when i changed mine, i ended up starting the nuts on the top threads, in an unequal rate, so as to change the position of the bottom two studs. (needed to angle them a bit to get them to line up)
Mine came out straight, they slid right in when I was finished. I can get a pic if needed. Did you replace the trans mount too? I haven't done it yet on mine yet. I haven't even looked at it, but if it is bad too and a new one raises that side, I can see where I might get what you're talking about.
yeah, mobil1 filters and purolators come from the same place right? champion industries or somehting. i always thought fram was the best....until i found good sites saying otherwise...this is one of them...i switched to mobil 1 ep filter as stated above and found idle improved cold and hot...put an ep on my chysler van and the knocking sound it made with stock mopar filter (also a FRAM...GONE!!!) is not to be heard...its worth the extra 5 bucks every 3 months or so...get a better filter!!!
Good news, that was the one and only FRAM filter ever on the car. Been using AC Delco ever since.
Wow - thanks. I might attempt this later this winter. I should crawl under and see if I am leaking hydraulic fluid out.
Dumb question: is there one of these mounts on each side, or is it just a tranny mount on the other side?
