Thread: How To: Install 1.8 Roller Rockers on L67
Results 21 to 40 of 60
  1. #21 Re: How To: Install 1.8 Roller Rockers on L67
    Minnesota
    I plan on going with rockers once I can save up the money, I would go with a cam but Im not paying a shop to do it lol And not to sure if i can do it lol did you notice the gain in performance or at idle or anything noticable
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  2. #22 Re: How To: Install 1.8 Roller Rockers on L67
    You dont need to pull the s/c and lim to change the springs.
  3. #23 Re: How To: Install 1.8 Roller Rockers on L67
    GT Level Member Mitchstrp's Avatar
    Missouri
    ACTUALLY my car hasnt started since the install lol, i had a crank postion sensor go out and i knew it was going out but thought id be okay and my car hasnt started since lol. But idle will not sound any different and the only gains youll really see are from IIRC 5000-6200 rpms.
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  4. #24 Re: How To: Install 1.8 Roller Rockers on L67
    Missouri
    then i must have read wrong, because from what i read thats a must so you dont drop a valve... you have to pull the LIM to get to top of the heads and put air through them to keep the valves from dropping.. Then how do you do it?
  5. #25 Re: How To: Install 1.8 Roller Rockers on L67
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    its one of those things to be safe than sorry plus youll gain a little more powere doing the springs thats y i did them plus i had a **** ton of money so i just ordered everything haha
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  6. #26 Re: How To: Install 1.8 Roller Rockers on L67
    Missouri
    haha^ theres the way to go
  7. #27 Re: How To: Install 1.8 Roller Rockers on L67
    Minnesota
    Quote Originally Posted by Mitchstrp View Post
    I may be wrong but cant you turn the motor to top dea center to stop the valves from falling?
  8. #28 Re: How To: Install 1.8 Roller Rockers on L67
    Missouri
    Quote Originally Posted by Ricky21 View Post
    to be honest with you, idk lol. this is my first expierence with valve train.
  9. #29 Re: How To: Install 1.8 Roller Rockers on L67
    turn motor to TDC then put air in via the spark plug holes with an adapter.
    Air compressor helps.
    or you could do the string trick.
  10. #30 Re: How To: Install 1.8 Roller Rockers on L67
    Missouri
    oh i see well thats good to know i may go back in sometime and put in bigger springs.
  11. #31 Re: How To: Install 1.8 Roller Rockers on L67
    Donating Users
    South Deerfield, MA
    I wanted to add to this that you don't need to get the motor to top dead center. When I did my cam, I only pressurized the cylinders with air to hold the valves and didn't have any trouble. I bled the pressure into the cylinder slowly since it will push the piston to the bottom of the cylinder. After that it was just a few minutes to compress the spring, pop the locks out, remove the spring and retainer, replace the valve seal, and reassemble.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  12. #32 Re: How To: Install 1.8 Roller Rockers on L67
    that works as well.
    Probably safer actually.
  13. #33 Re: How To: Install 1.8 Roller Rockers on L67
    Minnesota
    yea I heard something about that, probly be the easiest way. Whats the string trick?
  14. #34 Re: How To: Install 1.8 Roller Rockers on L67
    The string trick is a nightmare if it goes bad. It's filling the cylinder with string and then turning it to hold the valve up with the string/piston.
    To hold a valve closed, you simply have to add air via the right adapter (compression tester) to the cylinder through the plug hole. The top end coming off would not help hold exhaust valves. Once you've removed the rocker, the valve is basically held up and sealing the cylinder. Add air and it holds them closed.
    To do rockers, say you don't want to hurt your DD and not do springs only because it's too cold. (wink, wink)... I'll leave it at that. With 1.8's you "should" be ok on stock springs.
  15. #35 Re: How To: Install 1.8 Roller Rockers on L67
    Missouri
    well thanks for the input. ill consider upgrading spring.
  16. #36 Re: How To: Install 1.8 Roller Rockers on L67
    Wichita
    I got a set of rocker arms from 3800Performance. They came with Comp Cams Replacement bolts. The instructions say to tighten the bolts to 11lbs & then an additional 25 degrees. Now I'm wondering, is that right??
  17. #37 Re: How To: Install 1.8 Roller Rockers on L67
    Donating Users
    South Deerfield, MA
    Intense recommends 25 ft-lbs on their re-usable rocker bolts.
  18. #38 Re: How To: Install 1.8 Roller Rockers on L67
    SE Level Member Lacboi's Avatar
    Jun 2010
    Atlanta
    i looked at this vid 2 times and wonder do i have to turn the pushrods like he did
    YouTube - Installing Lifters, Pushrods & Roller Rockers
  19. #39 Re: How To: Install 1.8 Roller Rockers on L67
    no.
    for our engines just torque to 25 ft lbs with re-usable bolts (they're only a dollar more than TTY ones from ZZP) and move forward.
    For those engines you could just do it while its running. Might make a little mess but its simpler. Loosen till noise, tighten till no noise, 1/2 turn and move on.
  20. #40 Re: How To: Install 1.8 Roller Rockers on L67
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    wheres the sticky on this
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  1. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
  2. Roller Rockers
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 05:49 PM
