Thread: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    TDCRacing
    Guest
    Yes, But the results look pretty good so far. I'd do it.
  2. #22 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by blackz34 View Post
    I have a question about the Earl's hard line fitting, they seemed to be good to only 50 PSI, don't we have more than that at WOT ?
    thats my concern. our fuel pressure is between 48-55 psi according to ALLDATA
    COMP G
  3. #23 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by Street Wolf View Post
    Because the lines are slightly smaller between the bottom of the car and there. Makes everything flow better.
    Looks slick by the way.
    no, my lines are the same size all the way through, i have them out.
    i had a few other questions as well. what parts did you use for the lines that connect to the fuel rail itself, did you list those in your parts needed? also why do you need the 90 degree fitting? and why 3 XRP -6 AN straight female hose ends? why not 4?
    your write up or how to seemed very vague to me, i guess i need more details
    i bought all the stuff on your list minus 6 ft of hose because im not going back far, just removing the plastic fitted stuff, but i still wonder where are the fittings that i need for the rail. i found these - http://store.summitracing.com/partde...5&autoview=sku is this what i use?
    COMP G
  4. #24 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Jan 2009
    Berthier, Qc, Canada
    Quote Originally Posted by GTX View Post
    I was looking on McMaster-Carr, they have yor-lok tube fitting that will be good for over 1000 psi. They have brass, steel or stainless steel. I don't know wich one would be the best though, they say that brass will work with brass tubing, steel with steel... In what material are made our lines?
  5. #25 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Apr 2008
    Vallejo,Ca
    well i have all thats needed for my setup that im running, however i made one error and that was buying one 3/8 and one 5/16 fuel rail fitting. the 5/16 on the return side doesnt fit. i thought they were different sizes , i should have went with my gut when i first placed my order for two 3/8's fittings.... oh well, it does look clean though compared to the black plastic sh!t lines ( excuse my verbage but they are crap and the reason why our cars and others burn up, not the front valve cover gasket like GM recalled ) so tomorrow begins my venture into the project, i will be taking pictures
    edit - the 5/16th fitting does fit, just take the clip off first and install on fuel rail and the attach the fitting
    COMP G
  6. #26 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Apr 2008
    Vallejo,Ca
    so the project is about complete, im waiting on one more fitting but everything is all routed and one side is done, the return line is almost done.
    i chose to keep my setup fairly stock looking, utilizing all but one of those gray line connectors due to it being in the way of me feeding my lines upward. i cut off the plastic portions of the fuel lines only and went from there. this keeps it factory looking. i already tested the pressure line for leaking and it was perfect on that end.
    i cant stress enough that when you add these fittings USE small amounts of oil to coat the threads on the aluminum, also do not use teflon tape. tighten down the fittings until they are tight dont overdue it, just until they feel snugged ( using wrenches and not your hands of course )
    this isnt a hard mod to do, the lines themselves if you do it my way can be a bit tricky to maneuver so expect a lot of cussing, but in the end its very worth it for looks and safety issues concerning the factory lines. here are some pics of the procedure.
    i'll upload more later when its completed, just waiting on one last fitting
    COMP G
  7. #27 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Apr 2008
    Vallejo,Ca
    COMP G
  1. Problems with AN fuel line setup, I have leaks, help please...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 05-19-2008, 01:29 PM
  2. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
  5. 04+ fuel return line
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 11:40 PM
