Thread: How to: LED turn signal mirrors
Results 21 to 40 of 51
  1. #21 Re: How to: LED turn signal mirrors
    FWIW, when you do this..consider doing puddle lights. It's such a great thing and you are already in the mirror housing.
  2. #22 Re: How to: LED turn signal mirrors
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Yeah thats a good idea Bill. Thanks for the info!
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  3. #23 Re: How to: LED turn signal mirrors
    Dec 2008
    Bill, how will this work for a 2000 GP? I can probably try and get LED pods from a junkyard or something, but do you know if GP mirrors have the good heating elements?
    Also, what do you reckon is the best course of action with puddle lights?
  4. #24 Re: How to: LED turn signal mirrors
    I think it's doable. GP's don't appear to have heating elements in all years/models.
    On puddle lights, do what I did.
  5. #25 Re: How to: LED turn signal mirrors
    Jul 2011
    Chicago
    First post, but a long time reader.
    I have a 2001 SE and my son has a 97 GTP. I’m always visiting the
    write-up section for tips and I’ve wanted to do this mod for months
    now. I’ve contacted various junk yards to inquire about the mirrors
    with the pods, but they always want to sell the complete housings.
    The prices I got were close to what the Muth kits go for. I wanted
    to keep the oem housings so aftermarkets were out of the question
    and Muth doesn’t make a kit for heated mirrors. My son is adamant
    about keeping them functioning on his GTP. Mine aren't heated.
    I found this website below and wondered if anyone has dealt with them.
    I can’t seem to find any info on Shark Racing, other than they specialize
    in imports and are based in South Korea. At $33 a kit shipped, it looks
    almost too good to be true. I’m on a limited income and I’m not real
    keen on buying something from outside the US.
    Shark Racing
    I would use Bill’s idea to mount them on my son’s GTP and cut out the
    backs on both so the mirrors sit flush.
  6. #26 Re: How to: LED turn signal mirrors
    Quincy, Mass
    those would probably work better, the ones bills uses are really are to find. i found them using his guys but he doubled the price on me.
    No more GP 04 Impala SS Indy:
  7. #27 Re: How to: LED turn signal mirrors
    bill, i have a question regarding dis-assembly of the side view regal mirror.
    my stock mirror got hit and the glass broke. my housing is black. i picked up a junk yard replacement but its blue, now ive taken the black one apart as its dead and i like to tear into stuff when i have a idea, and well the guts are trash anyways, but i figured out how to pull it all apart, but was wondering if you had any tips or ways you would go about popping the glass off the power mirror motor with out breaking the glass, and then removing the glass off the plastic part with out breaking it. and what is goop? is that a name brand you used to glue stuff in with?
    and it would seem upon re assembly, you need to snap the plastic part that the glass is glued to on to the motor, then screw the motor in, then glue the glass on. correct me if im wrong on this one.
    thanks for your time.
  8. #28 Re: How to: LED turn signal mirrors
    To replace only a mirror and not the housing. You get your fingers around the black backing of the mirror and pull quick to pop the clips that hold the mirror/backing to the motor. You have a chance of breaking it. You line up the backing with the motor to reassemble and push until it clicks and holds on both axis's and the center pivot point. There is a chance to break the glass, try and be careful.
    I pushed the glass gently through the couple of holes in teh backing to get the glass off the backing. Then yes.. used one of the "Goop" products to hold it together when done.
  9. #29 Re: How to: LED turn signal mirrors
    Kansas
    AG Automotive Product Information 0709
    They also have like All Purpose that would work... practically any Goop would work.
  10. #30 Re: How to: LED turn signal mirrors
    thanks bill, that's how i took the broken one apart, but with broken glass its hard to tell if there's a better way. i was hopping there was a safe way to get it all apart. looks like slow and steady might win this race.
  11. #31 Re: How to: LED turn signal mirrors
    got it all back together, the glass popped out while trying to get the mount off the motor, was very happy it came off in one piece.
    put all the parts on first and glued the mirror back on it last. glued it with 4 small dabs of gorilla glue. its setting up now.
    i love it when a plan come together!
  12. #32 Re: How to: LED turn signal mirrors
    Donating User Odi's Avatar
    Chicago South Suburbs
    already got the parts for teh prix.
  13. #33 Re: How to: LED turn signal mirrors
    SE Level Member sandobar's Avatar
    Dec 2011
    NY
    I have peeled the heater sticker not to loose the heated mirror hit it with a heat gun and it peels right off
  14. #34 Re: How to: LED turn signal mirrors
    GT Level Member 7801MonteMan's Avatar
    S.E Michigan
    Over a year later I was able to pull a set for free. Can't wait to get this what seems to be a easy project.
    ASE Certified and I-Car Auto Refinishing Paint Technician
    -78 Monte Carlo -01 Monte Carlo LSX
  15. #35 Re: How to: LED turn signal mirrors
    Donating Users crock's Avatar
    Traverse City, Michigan
    So the caddy mirror will fit into the GP housing?
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  16. #36 Re: How to: LED turn signal mirrors
    May 2012
    mn
    what are the chances that the led colors could be switched out?
  17. #37 Re: How to: LED turn signal mirrors
    What are the chances you buy the color you want, and keep in mind law enforcement may not like some colors.
  18. #38 Re: How to: LED turn signal mirrors
    Oct 2012
    Illinois
    BillBoost37,
    JMI, your only scraping away the backing material on the mirror so the led can see through right? That one pic makes it look like holes are cleanly punched through the mirror. Btw what size punch did you use?
    Really nice mod I must say, and I'd like to do this to my car to any way mitigate stupid from running in to me when changing lanes.
    I see some LED's on eYay for like $15 bucks, look similar to the caddy ones you got.
    Where did you get the puddle lights?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    When I did the led mirrors on my 04 gtp I took a set of the strip leds 3" long had 3 leds in each.
    I simply cut away some of the black plastic backing with a razor and without modifying the mirror Itself at all they shined through bright enough for me to be to satisfied. Here's a picture of them before I moved the leds to behind the mirror and from horIzontal to vertIcal. I can't seem to find a picture of the final.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
    Oct 2011
    MI
    Oh and btw the 04+ have positive output off the bcm for the front turn signals. So it's a simple ground and left, right trigger. I can pull a diagram if someone needs it.
    I plan to do the same thing with my new comp g as soon as i get down the list of to do's.
  1. Car dies when using turn signal
    By 4boostin in forum General Tech Discussion
    Last Post: 07-28-2010, 05:57 PM
  2. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  3. Turn Signal Indicator On
    By vega in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2010, 08:43 PM
  4. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
  5. Turn signal Issues
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 10:39 AM
