Thread: General Info: Swap your steel oil pan for an aluminum one
Results 21 to 40 of 69
  1. #21 Re: General Info: Swap your steel oil pan for an aluminum one
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    I have a aluminum sub frame and a steel oil pan. I want to do the aluminum pan. but everything I read talk about a steel sub frame.
  2. #22 Re: General Info: Swap your steel oil pan for an aluminum one
    The year after yours, GM used an aluminum pan in the aluminum frame. I have the aluminum frame and aluminum pan. It's a great combo.
  3. #23 Re: General Info: Swap your steel oil pan for an aluminum one
    Jun 2012
    Coral Spring, Fl
    05 and up. and I order gasket, mount, and pan tonight. anything more
  4. #24 Re: General Info: Swap your steel oil pan for an aluminum one
    Jul 2014
    Phoenix, AZ
    This is so much for me to take in lol but I hope this doesnt get on your nerves. Im just trying to be extra sure here. I have 98 GP GT, im not sure if it has the aluminum sub frame but I think it does. If I were to do this aluminum swap, I need the 7th gen L26 pick up tube and the 7th gen L26 pan? And thats it? No bracket or oil filter adapter?
  5. #25 Re: General Info: Swap your steel oil pan for an aluminum one
    Hey Kyle.... learn how to search sucker!
  6. #26 Re: General Info: Swap your steel oil pan for an aluminum one
    GT Level Member aligater's Avatar
    london ontario canada
    04 and older - steel oil pan
    05 and newer - aluminum oil pan
    03 and older - steel subframe
    04 and newer - aluminum subframe
    Each oil pan needs the matching pick up and motor mount brackets
    Use either pan with either subframe, but only need to grind steel subframe to work with aluminum pan.
  7. #27 Re: General Info: Swap your steel oil pan for an aluminum one
    Nov 2014
    FORT WORTH TEXAS
    help please torque settings for bracket to aluminum oil pan and motor mount
  8. #28 Re: General Info: Swap your steel oil pan for an aluminum one
    I've never looked them up. They are hefty bolts and you can give them a good amount.. Say 25 ft lbs
  9. #29 Re: General Info: Swap your steel oil pan for an aluminum one
    Nov 2014
    FORT WORTH TEXAS
    OMG your like meeting KISS in person have been looking for what happen to you
    from GM Forums
    I Think I know why you left there my self I get picked on by one of the guys there
    IF you ask a question like will a aluminum pan fit a steel sub frame they ask
    {why do you want to do that when as one person said just take off old steel pan and use silicone on both sides of the molded rubber gasket TSB from GM so they say}
    I went to 20lbs but was worried of striping out the aluminum pan threads
    SIR do you still have the white buick regal what a car wow
  10. #30 Re: General Info: Swap your steel oil pan for an aluminum one
    I honestly don't torque it.. I hit it pretty hard with a wrench and it's good.
    I didn't leave there.. just can't be online there as much as I used to be.
    And .. yes on the Regal. Currently I'm still driving it. Will be rolling 250k this afternoon.
  11. #31 Re: General Info: Swap your steel oil pan for an aluminum one
    Nov 2014
    FORT WORTH TEXAS
    did you put a gen 3 in there?
    if you did did you change the throttle body or have a write up doing it?
  12. #32 Re: General Info: Swap your steel oil pan for an aluminum one
    Kinda the wrong thread for it..
    But.. I first tossed a Gen V on and did the TB adapter. Now the car is running with an NA L26
  13. #33 Re: General Info: Swap your steel oil pan for an aluminum one
    hangover park IL
    Quote Originally Posted by aligater View Post
    nope
    03.5 and older steel pan
    03-04.5 steel or alum pan, alum pan is not a good indicator of a SIII (PM rod) engine, both were used as parts inventory ran out of the old design. ive seen cast rod alum pan engines as well as PM rod engines with the steel pan
    04.5+ alum pan
    alum subframe is far more convoluted, 3 different designs, the best being the second, the third design modified to crumple easier for new crash standards. 01+ dep on model of car.
    steel subframe was pretty much done by 02/03
    the only time ive had to grind with an alum pan is when using the earlier Horseshoe motor mount bracket instead of the integral pan bracket. and thats in 2 small area's of the horseshoe where it runs next to the alum pan.
    PS the alum pan sucks donkey dick, ****ty windage tray, no weight savings, brittle as ****.
    Dorman single layer steel pans FTW
    ~James~ Psychotic Gearhead
  14. #34 Re: General Info: Swap your steel oil pan for an aluminum one
    What in the heck are you doing to the pan that would make it brittle, oh wait.. you put a billion HP to these things. I could see where the steel horseshoe could be a better mount setup in higher HP cases.
    James... I am interested in the windage differences, would you please explain them a bit further? Difference of the plascraptic vs aluminum with built in. Thanks
  15. #35 Re: General Info: Swap your steel oil pan for an aluminum one
    hangover park IL
    H body pan
    while the alum pan and steel windage tray have some upsides (narrower louvers, steel windage tray, rigidity/NVH) it has quite the downside....
    its mounted farther from the rotating assembly, and while cyl 4 is slightly better at stripping oil....the perimeter of the tray is open.
    while far from ideal the steel/plastic setup is easier to mod into a good setup, the windage tray is opened up and knife edged, cyl 4 scraper welded to pan (the nicer single layer Dorman pans are far nicer than OEM)
    the alum pan has a harder to modify windage tray. will crack instead of bend, plus the integral W body mount bracket makes getting to the mount bolts a real pita over the horseshoe.
    on the Riv we tried the best of both worlds using the plastic tray with the alum pan...the gasket put the pan lower (moved oil level down away from crank) increased pickup clearance to nearly 1/2".
    but then you lose the rigidity of the alum pan.... which is arguably the best reason to swap it in aside from slightly better oil cooling
  16. #36 Re: General Info: Swap your steel oil pan for an aluminum one
    Feb 2013
    Missouri
    So what's the verdict on this, good idea or bad idea? I need a new oil pan, so it's now or never...
  17. #37 Re: General Info: Swap your steel oil pan for an aluminum one
    For me it's a no brainer. Aluminum.
    The con's that James mentions will never effect most of us. And on the mount/bracket. It's not an issue because you pop three bolts and it's in your hand
  18. #38 Re: General Info: Swap your steel oil pan for an aluminum one
    Feb 2013
    Missouri
    I may just have to swap it then, it's all of $20 for the oil pan at the JY.
  19. #39 Re: General Info: Swap your steel oil pan for an aluminum one
    Enfield, CT
    I did. I read this thread a long time ago and just wanted clarification. I'll be looking for this stuff at the JY this weekend and you're going as well. If you don't I'll hit you for real this time lol..
  20. #40 Re: General Info: Swap your steel oil pan for an aluminum one
    Quote Originally Posted by Booba5185 View Post
    Make sure you get the pick up tube as well. They are different
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 4 Weeks Ago, 11:56 PM
  2. Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    By LowlyfeGTP in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:14 AM
  3. Top swap and general question
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2010, 08:28 PM
  4. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
  5. General Gen. V blower swap questions
    By GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 06:38 PM
