Thread: General Info: Swap your steel oil pan for an aluminum one
Results 41 to 60 of 69
  1. #41 Re: General Info: Swap your steel oil pan for an aluminum one
    Feb 2013
    Missouri
    Will do. The mount itself is the same, right?
  2. #42 Re: General Info: Swap your steel oil pan for an aluminum one
    Mount.. no . The aluminum pan has a small bracket that bolts to it and the mount. The mount appears to be 3/8" taller
  3. #43 Re: General Info: Swap your steel oil pan for an aluminum one
    Besides most 06-08 Grand Prix which other cars and years should I look for in the JY to snag a pan Bill?
    04 Comp G.
  4. #44 Re: General Info: Swap your steel oil pan for an aluminum one
    Nov 2014
    FORT WORTH TEXAS
    that's the pan you need other ones don't have the motor mount provision and you need the oil pump pick up tube or you will find out
    after you have it all on
    And your about done with it when you go to put in the oil level sensor
    it hits the oil pick up tube
    other information you use no gasket oil baffle made in pan factory used gray RTV only
    hope this helps I did the swap still have the steel sub frame at this time
  5. #45 Re: General Info: Swap your steel oil pan for an aluminum one
    Aaron 05-08 GP, that's a gazillion cars.
  6. #46 Re: General Info: Swap your steel oil pan for an aluminum one
    May 2015
    United States
    Billboost37 I recently purchased the aluminum setup mount, pick up and pan off 05 GP there is a bracket on the back that connects to the pan using 1 bolt and connects to engine do you use that along with the engine mount or Is the engine mount OK to run ?
  7. #47 Re: General Info: Swap your steel oil pan for an aluminum one
    You don't need that bracket to the trans.. it's an extra.
  8. #48 Re: General Info: Swap your steel oil pan for an aluminum one
    hangover park IL
    that pan to transmission bracket is the primary reason they went to the aluminum pan... was better structural rigidity and less noise and vibration.
    you don't need it. but without it the aluminum pan does not add very much to the pie.
    ~James~ Psychotic Gearhead
  9. #49 Re: General Info: Swap your steel oil pan for an aluminum one
    May 2015
    United States
    Thanks guys I had to know before I went forward.
  10. #50 Re: General Info: Swap your steel oil pan for an aluminum one
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I think I get this but a few questions guys. Working on 2001 Buick regal supercharged motor (steel frame I'm sure) for a friend who messed up the oil pan. He Ruined the pan and pick up tube.
    So after getting the regal apart I remembered my brother had a motor from what he said was from a series 3 motor. I already grabbed pick up tube and oil pan with mount still attached (the motor was modded to fit in a W body (97 cutlass supreme)......
    Other thing I noticed was the pan has a gasket and not a built in windage tray ( it was removed i guess, I'm not sure why considering these pans didn't need a gasket right? I hope this is not to confusing.
    I'm just trying to see what I may need to do before I try to install it on the 01 regal. grind the frame, cut bracket lip ? etc?
  11. #51 Re: General Info: Swap your steel oil pan for an aluminum one
    May 2015
    United States
    You have the correct pan setup but just missing the windage tray
  12. #52 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2012
    Chicago
    You think I could just use a gasket, seeing how I have a new one already... It had a gasket on it when it came off the series 3
  13. #53 Re: General Info: Swap your steel oil pan for an aluminum one
    Buffalo
    No gasket on mine just rtv
    modify the bracket
  14. #54 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2012
    Chicago
    OK modify as in grind down part of the bracket? Why? I ask why so I'll know exactly what part to modify, does it hit subframe etc its 27 degrees here so just want to as much as possible lol.
    I know that you don't use a gasket on this pan just rtv... but there is no windage tray. The car it came from had a gasket instead...does it matter..prob not I guess
  15. #55 Re: General Info: Swap your steel oil pan for an aluminum one
    Buffalo
  16. #56 Re: General Info: Swap your steel oil pan for an aluminum one
    Buffalo
    Tray and no tray
    No tray
  17. #57 Re: General Info: Swap your steel oil pan for an aluminum one
    Buffalo
  18. #58 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2012
    Chicago
    Thanks for the pics and I checked out your other thread, I see that you modified the old mount and made it fit, I was under the impression I could use the original mount attached to the aluminum pan.
    I can order or try to find a windage tray but ill prob just use a plastic gasket since I don't have the tray.
  19. #59 Re: General Info: Swap your steel oil pan for an aluminum one
    hangover park IL
    this is the correct engine to diff to pan brace for the alum pan equipped W bodies, it ties the pan near the mount into the block/trans, along with another bracket below the starter from the pan to the bellhousing
    http://www.ebay.com/itm/VG012-BRACKE...dVvU8A&vxp=mtr
  20. #60 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2012
    Chicago
    I guess I'm a little confused but that does makes since, that the engine mount bracket alone may not be sufficient enough to hold the engine in the cradle. I see that bill didn't use it? But glad you clarified that in case I wanted to do it exactly how it should be done.
    I may just tell my friend to go ahead and grab the parts especially for the car and leave it factory...
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    By LowlyfeGTP in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:14 AM
  3. Top swap and general question
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2010, 08:28 PM
  4. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
  5. General Gen. V blower swap questions
    By GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 06:38 PM
