Thread: Audi style LED lights.
Results 1 to 20 of 40
  1. #1 Audi style LED lights.
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Okay, I was inspired to do this writeup from the guy over there with the white GXP, so kudos to him.
    This is for 04+ only.
    Anyways I would just like to do this because I think it is a really clean look (opinion, no flaming please) and I know some other people on the forum wanted to do this.
    Okay so first off, materials:
    1. Get these from your local Autozone ONLY! (I checked other places, no luck) Pilot Automotive/12 Volts 18 in. white phantom LED interior and exterior strip (CZ-3009W) | LED Light Bar | AutoZone.com
    2. Wire taps (Radioshack or Autozone)
    3. Razor blade
    4. Wire strippers
    5. Masking or electrical tape
    Step 1: Take your headlight off via one bolt on top. Lift the bracket up and pull the headlight out.
    Step 2: Open up your Phantom 18" lights pull the leads of the battery and cut the power and ground cables off. Strip these two wires and inch or so in. This is the box:
    Step 3: This is the part your going to want to be careful with. I wired these up to my parking lights so they can come on with a switch. The only thing I wish is that they came on with an unlock, but whatever. Okay, rather than stripping an entire section off of the parking light, you want to cut two small ovals about 1/4" long each, just barely showing the copper wiring.
    ^Parking light
    Step 4: Slide the parking light ground wire into a wire tap with the metal thing adjacent to the "oval." Then slide in the other wire and crimp the two together with needle nose pliers. One thing I would suggest is doubling up the LED's ground and power wires because they are REALLY thin and will most likely fall out of the tap if they are not doubled up.
    Do this same exact process for power.
    (Bad pic, sorry)
    Step 5: With everything connected turn on the parking lights and test to see that the LED's turn on.
    Step 6: Put your headlight temporarily back in (don't bolt it back in, just use the bracket to line it up to its original position) With the headlight back in, mark the front of the headlight with tape at the bottom (part touching the front bumper)
    Step 7: Take the headlight back off and lay down the LED strip with the included double sided tape (make sure the surface is clean)
    Step 8: Put the headlight back on and enjoy your unique look
    End results with 6k HIDs and Red/White Switchback LEDs (keep in mind this is GXP.)
    With foglights:
    Enjoy and good luck guys.
  2. #2 Re: Audi style LED lights.
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    not bad
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: Audi style LED lights.
    Windsor (ON) Canada
    I have/had something similar set up on my 01. (iphone really eff's up how it really looks)
    May just go and hook them back up.
    Your's looks really clean.
  4. #4 Re: Audi style LED lights.
    looks sweet! I was thinking on doing this to my 97 sometime... Maybe over the winter or next spring .
    Snorlax strikes again.
  5. #5 Re: Audi style LED lights.
    Those are the worst connectors known to mankind.
  6. #6 Re: Audi style LED lights.
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    Run and tap connectors??? Ewwy
    <MiZzBeCcA>its not rape if you yell suprise
  7. #7 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Yeah, **** kept falling out. Annoying as hell.
    And thanks for all the compliments guys, hope this helps
  8. #8 Re: Audi style LED lights.
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Looks pretty clean, and a lot better than some other attempts I've seen, I might have to try this on my GT. Also, believe it or not before this thread I'd never heard of switchback LEDs. Needless to say I've already placed my order for them haha I absolutely HATE how the lights are amber as I'm driving.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  9. #9 Re: Audi style LED lights.
    MO
    get a bumper level view. then i'll put my opinion in
    <brandonl2000> LMAO D!!
  10. #10 Re: Audi style LED lights.
    SE Level Member lcuthber's Avatar
    Feb 2010
    Kokomo, IN
    looks awesome man! I'm assuming that the guy with the white GXP that you referenced was myself! haha. great job on them, they look great.
  11. #11 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Certainly is my friend and thank ya
  12. #12 Re: Audi style LED lights.
    Nov 2009
    South Boston, MA
    It looks awesome man.... so are they inside the headlight?
  13. #13 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Quote Originally Posted by 05PontiacGP View Post
    Nope you just tape them to the bumper directly below the headlight.
  14. #14 Re: Audi style LED lights.
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    looks good but you messed up using those scotch locks your gonna regret that in a year or so
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  15. #15 Re: Audi style LED lights.
    Willoughby, Ohio
    Quote Originally Posted by Colossus View Post
    i have the same lights under my projectors, i get compliments all the time on them too, bye bye dim LED halos
  16. #16 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Quote Originally Posted by Biohazed View Post
    So I've been told...
    What do you recommend for a fix?
  17. #17 Re: Audi style LED lights.
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Shouda, coulda, woulda bought an Audi...
    Not a fan. It's the new halo... Looks good on German cars, and everything else lookss gayer than aids
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  18. #18 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Quote Originally Posted by ninnyGTP View Post
    Thank you?
  19. #19 Re: Audi style LED lights.
    Jul 2010
    So on my '05 base, half of the bottom lights are DRL's/blinkers and the lower half are the fog lights. I would like these to be on with my DRL's (they'll then also flash with my keyless entry) but I don't want them to blink with my blinkers..any ideas..?
  20. #20 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Hmm, well do your foglights come on with unlock? Because then if you spliced into your fogs, they would come on with unlock, but would not flash as you want. The only thing is I'm not sure the amount of power those fogs supply relative to the LED's.
  1. GTP vs. Audi S4
    By Will5600 in forum Off Topic Discussion
    Last Post: 09-16-2009, 07:55 AM
  2. Lights inside an F1 style hood?
    By FuglyGTP in forum Visual/Body Modifications
    Last Post: 03-14-2009, 03:16 PM
  3. VS Audi TT 3.2 AWD
    By 02CL-TypeS in forum Track Sessions and Kills
    Last Post: 08-03-2008, 06:36 PM
  4. run in with a 2005+ Audi A8L W12
    By fst in forum Track Sessions and Kills
    Last Post: 05-06-2008, 09:00 PM
  5. Audi R8
    By GorillaThumbz in forum Off Topic Discussion
    Last Post: 02-10-2008, 11:12 AM
