Thread: How to remove a transmission
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 110
  1. #61 Re: How to remove a transmission
    You'll be fine for a few days. Be gentle to it though. You don't want to load up the tailshaft and break it off.
    We'll pretend that it didn't get missed on my car with a good pile of power more than you are likely running. It wasn't noticed until the next trans swap about a month or two later. And yes.. I beat the piss out of it constantly.
  2. #62 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    Ok ya it's a stock gt na 3.8 and I won't drive it too hard then
  3. #63 Re: How to remove a transmission
    You should be fine.. but .. it's kinda a big piece to have lost.
  4. #64 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    Ya my brother said he remembered trippin on something in the garage last night and I think he kicked it somewhere but it's nowhere to be found now...
  5. #65 Re: How to remove a transmission
    Enfield, CT
    This thread reminds me of a time when friends and I secretly pulled a transmission from a Buick recently. Owner was dicking around for a long time and the car had to go but he didn't pick it up so we decided to keep the recently rebuilt trans. A few days later Scotty asked about the "hot" transmission and, in that moment in time, I had absolutely no fvcking idea what he was talking about. seriously. I couldn't understand why he was asking me about a transmission. A little while later I finally realized what he was talking about and thats when I realized peoples secrets are safe with me lmao
  6. #66 Re: How to remove a transmission
    i didnt know it was a secret lol if its abandoned, its fair game lol
  7. #67 Re: How to remove a transmission
    I thought Scotty was wondering why you threw away a perfectly good engine the day before he found out?
  8. #68 Re: How to remove a transmission
    Enfield, CT
    I had no room otherwise I would've kept it
  9. #69 Re: How to remove a transmission
    Feb 2017
    NH
    I just completed a trans removal & reinstallation following this process. My car isn't a Grand Prix but it has the L67 driveline and a lot of the steps are the same.
    My 2002 Buick Park Avenue Ultra is supposedly set up the same way as a same year Bonneville SSEi.
    The one place I really had some trouble was getting the rear bolt to release the trans from the engine. I just couldn't get a socket on that bolt. It may have been me being a klutz, but I like to blame it on the rear exhaust and the power steering pump bracket. On my car the bracket behind the pump is a good sized chunk of aluminum, and it stymied me at every turn.
    Fortunately I watched a video made by a professional tech who was removing a trans from a Buick Lesabre. He got the back bolt by stacking two wobble extensions and a wobble 18mm. Then he reached up at a 45 degree angle between the trans and the engine to turn the bolt.
    I would have taken that approach but since I also needed to do my oil pan gasket I dropped the pan too. Once my oil pan was down I could see the bolt.
    I reinstalled the trans with a rebuilt torque converter and now I have 4th gear lock up. Fingers crossed that it stays that way.
  10. #70 Re: How to remove a transmission
    Jan 2017
    Washington
    Not sure if you use the forums any more but I followed everything you did but the trans won't separate from the engine
  11. #71 Re: How to remove a transmission
    All flex plate bolts are off and the bell housing bolts right?
  12. #72 Re: How to remove a transmission
    Jan 2017
    Washington
    Here's all the bolts I took off:
    4 bolts from trans to engine
    That one backwards bolt
    The 4 bolts holding that bracket
    The 3 TC bolts on the flywheel
    Subframe is already dropped
    All the bolts/nuts holding any ground wiring to the trans
  13. #73 Re: How to remove a transmission
    either your missing a bolt some where or maybe theres tension with the tranny hanging off the engine? try lifting it up some tap with a hammer and a pry bar to split them.
    mine, i just shook the chain from the hoist to engine and they split.
  14. #74 Re: How to remove a transmission
    Jan 2018
    US
    Hey guys, in the process to attempt to put my rebuilt tranny in tomorrow AM for the first time. Only took a tranny out from the JYard which was cut and pull out by any means necessary ha.... Now I have to take my old one out my car cleanly. BTW, I completely rebuilt the yard tranny......
    Big boy tools that I do have is:
    Floor jack
    4 3ton jack stands
    Engine support bar
    Tranny jack
    All from Harbor Freight
    I think all I have left is the b*itch bolt, 4 bolts holding tranny on engine from the (bell housing) (I think), 3 flywheel bolts and bolts on differential cover (bracket)... Will have to check tomorrow on ground wires and starter stuff.
    My question is, will I be able to drop the subframe naked without the rack and pinion on by leaving it in the steering area?
    And if so, after place tranny jack under before removing what I have left?
    Sent from my SM-N950U using Tapatalk
  15. #75 Re: How to remove a transmission
    un bolt the rack from the sub frame, let it hang there via the steering shaft. thats it.
  16. Thanks showtastiik thanked for this post
    Likes showtastiik liked this post
  17. #76 Re: How to remove a transmission
    Jan 2018
    US
    4 subframe bolts left.... Before I drop it, I wanted to see if this will work. The way I hooked this bar up? Any thoughts?
  18. #77 Re: How to remove a transmission
    if your hooked to the pull brackets thats fine.
    i used my engine hoist to hold the engine up in place. put my pull brackets back on to use them and holding points.
    How to remove a transmission Attached Images
  19. Thanks showtastiik thanked for this post
  20. #78 Re: How to remove a transmission
    You guys know..I like a 4x4 because I don't own a lifting support. All good in the end.
    The bish bolt isn't really a bish if you follow the write up. It's just a matter of having a few longer extensions.
  21. Likes showtastiik liked this post
  22. #79 Re: How to remove a transmission
    Jan 2018
    US
    With the transmission out.. Can I put the subframe back on and take the engine support bar out?
    Will the subframe support the engine by itself without the support bar holding the engine up?
  23. #80 Re: How to remove a transmission
    no. your stuck with the support till the trannys back in.
    id rather have your support then a engine hoist sitting out over night, thats for sure lol
  24. Likes showtastiik liked this post
  1. How To Remove Transmission Help!
    By Hixc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-10-2014, 08:59 AM
  2. how to remove a 97 gp transmission?
    By 1997gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 12:10 AM
  3. how to remove a 97 gp transmission?
    By 1997gp in forum General Tech Discussion
    Last Post: 07-07-2009, 11:26 AM
  4. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
  5. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
