Thread: 97-03 HUD Dimming Repair/Fix
Results 21 to 40 of 41
  1. #21 Re: 97-03 HUD Dimming Repair/Fix
    Nov 2012
    Ohio
    I'm gonna have to do this in mine I think. Mine goes dark (or doesn't even light up) until I hit a bump, then it gets bright. Possible loose wire but I need to change the bulbs behind my trac, oil, etc lights anyway so may as well go full force. Thanks for the write up, saves me from having to ask how to do it lol
  2. #22 Re: 97-03 HUD Dimming Repair/Fix
    Nov 2012
    Fort Worth Texas
    Vishay / Small Signal & Opto Products (SSP) - BPW21R - Emitters and Detectors - Photodiodes - Allied Electronics website and part for photoeye diode if the solder fix did not work. I replaced mine and it worked great
  3. #23 Re: 97-03 HUD Dimming Repair/Fix
    SE Level Member jamez74's Avatar
    Jan 2013
    Medicine Hat, Alberta
    Thanks for this. Mine did not work at all when I got the car and this fixed it!
  4. #24 Re: 97-03 HUD Dimming Repair/Fix
    Aug 2012
    Oklahoma
    I'm going to give this a try tomorrow. If it's dark outside the HUD is visible. Invisible in daylight. The adjustment works ok so it's not a spring issue, just a dim HUD. Must be the solder joints on the photocell.
  5. #25 Re: 97-03 HUD Dimming Repair/Fix
    Apr 2013
    United States
    Hey how'd you guys get the screws off? I can't reach the screws on mine with a screwdriver, windshield gets in the way, and the trim piece won't come off fully.
  6. #26 Re: 97-03 HUD Dimming Repair/Fix
    First..get the trim off
    Then use a screwdriver.. I used a 7mm nutdriver, which is basically the same thing.
  7. #27 Re: 97-03 HUD Dimming Repair/Fix
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Quote Originally Posted by grdn24 View Post
    I had this issue and the heater-blower motor and a few other things were out of whack! I replaced the ignition module - wiring, which is a common prob on these cars and it literally fixed all of my issues..including the heads up display issue. Just a little fyi for all of you out there. My sunroof started working again and rear windows, blower motor worked on all 5 settings, as well as the hud dimming issue.
    2003 gtp btw, bought it brand new in may of 03 so I know it hasnt been jacked around with other than what ive done. lol
    Is this just repairing the wiring connector??
    http://shop.advanceautoparts.com/web...dule+connector
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  8. #28 Re: 97-03 HUD Dimming Repair/Fix
    Sep 2013
    GTA canada
    I know this is a olllllllld post but it worked for me so thanks! signed up to the forum just to say thanks
  9. #29 Re: 97-03 HUD Dimming Repair/Fix
    Feb 2014
    Grand Forks, North Dakota
    When I took my HUD out all the solder joints looked good so i didnt remelt it. I cleaned the photocell off because of a little dust. I then put it back in and it was still dim but not as much as before. Did the solder joints look perfect before remelting the solder?
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  10. #30 Re: 97-03 HUD Dimming Repair/Fix
    This thread needs to be updated with better pictures that weren't taken on a potato.
  11. #31 Re: 97-03 HUD Dimming Repair/Fix
    Nov 2010
    il
    The ignition harness fixed mine. Now I have no sound from front speakers??? Could that be ignition harness as well? Who knows, it's like the whole brain of the car passes through that thing
  12. #32 Re: 97-03 HUD Dimming Repair/Fix
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    yes they look perfect. you need to melt it up and add additional solder to the 3(?) solder points.
  13. #33 Re: 97-03 HUD Dimming Repair/Fix
    Mar 2014
    San Diego / Las Vegas
    Tree-huggers are important. Who in the hell wants to live on a trashed out planet?
  14. #34 Re: 97-03 HUD Dimming Repair/Fix
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    http://www.youtube.com/watch?v=8mXkoU4AJz8
    I've had this link saved for a good long while. It might be a useful addition to this thread on the HUD repair
  15. #35 Re: 97-03 HUD Dimming Repair/Fix
    GT Level Member Jtiger360's Avatar
    Nov 2012
    United States
    I'm a noob, u just put new solder at the tip (on the bottom of the round connector looking thing)? never solder before, a little confused. I do not have this issue but, would like to know how to do it just in case.
  16. #36 Re: 97-03 HUD Dimming Repair/Fix
    SE Level Member LHRxXD3adXx's Avatar
    Oct 2014
    What if mine works but dosent give me any info its just on and u see random lines?
  17. #37 Re: 97-03 HUD Dimming Repair/Fix
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    doing this tomorrow after I attack a molded out bathroom job. the light at the end of my day is my only thoughts...
  18. #38 Re: 97-03 HUD Dimming Repair/Fix
    Sep 2013
    Goldsboro, NC
    Would the HUD out of a 04+ work on the 97-03s?
    Tate
  19. #39 Re: 97-03 HUD Dimming Repair/Fix
    Quote Originally Posted by Tate View Post
    Tate
    I want to say no.
    Sent from my Galaxy Far Far Away
  20. #40 Re: 97-03 HUD Dimming Repair/Fix
    SE Level Member Stoenr's Avatar
    Aug 2015
    Chicago Burbs
    Quote Originally Posted by Slick2500 View Post
    Haha, will be attempting my sons HUD repair today. Ill snap some better pics. I assume people would be just looking for the actual points that need to be re-soldered.
    Ford Guy, Kids the GP guy.
  1. Lights and power issues / Dimming and slow
    By zeppelinrocks18 in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2012, 04:04 AM
  2. Compass/Auto dimming mirrior...
    By Iron Indian in forum Audio, Security & Visual Electronics
    Last Post: 05-22-2009, 10:37 AM
  3. OverHead Display Dimming Prob.
    By SuperChargedMook in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2009, 10:32 PM
  4. Dimming issue
    By dpaul007 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 03:38 PM
