Thread: Simple Intake (pictures)
Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 201 to 220 of 419
  1. #201 Re: Simple Intake (pictures)
    michigan
    I seriously laughed when reading some of these posts with all of the easy questions. Im not a master mechanic by ANY means but some questions were just ridiculous! Lol. Btw, nice method of open cone.
  2. #202 Re: Simple Intake (pictures)
    West Side Michigan
    Eh, we were all noobs at one point of our modding careers.
    By the way, this isn't an open cone. Open cone is just sticking the filter onto the throttle body.
  3. #203 Re: Simple Intake (pictures)
    michigan
    I know, I thought ppl were calling this one tho. ;-) my poor attempt at sarcasm. Lol
  4. #204 Re: Simple Intake (pictures)
    Florida
    my feeling is if the cone doesn't have an enclosure or is not in a fender it is an open cone?.....
    when i get my blower on, i want to use an extra map sensor to do a test of pressure between an open cone right on the TB/MAF vs a FWI. Dyno data is great but if you can see the pressure difference then that should resolve this too. along with temp data
  5. #205 Re: Simple Intake (pictures)
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by neyel8r View Post
    well, weirdly enough, it stopped bothering me after a while & i never got around to sealing it up like i was going to. the "rattlesnake" sounded kinda intimidating or something... so i left it alone.
    but it started bothering me again today so i just popped the hood & made some adjustments. gonna go pick up a burger & test it out.
    btw, although i never got to it myself, i'm glad i could help you with the idea!
    i believe you because i've heard elsewhere of that being a problem...... i would suggest removing & cleaning it, followed by replacing your intake with a dry one. search the forums about how to clean the MAF.
    Yeah I did... Took the TB apart and cleaned everything including getting some MAF cleaner and sprayed the crap outta my MAF. Cleared everything then about a week later, light came back on. Guess Ill just be one of the many poor souls out there driving around a GP with with Check Engine light on.
    FYI: I have seen no discernible issue in power or throttle response since i received the code. So, oh well.
    Infinity all around.
  6. #206 Re: Simple Intake (pictures)
    Sartell, mn
    Pairs, that is an AWESOME looking intake setup you have put together there... I have an 06 GT 3800 series III supercharged and I am hoping that the setup shown here will fit on my car. Any differences you know of ? Again, really a clean looking setup!
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    :thumbup::thumbup:
    sent from my galaxy....
  8. #208 Re: Simple Intake (pictures)
    Jan 2012
    Abilene, KS
    i decided to do this. i was in menards and i remembered about this but couldn't remember if it said 3 inch or 4 inch pipe but i knew that the maf was 3 and my cone was 4 inches so i bought a 4 inch pipe with the bigger end and just cut it off and got a 3" to 4" rubber coupler. now im just waiting on my filter
  9. #209 Re: Simple Intake (pictures)
    GT Level Member RideWithPride's Avatar
    Oct 2011
    just saying can't the plastic melt? Wouldn't it be safer to go with metal tubing instead of plastic?
  10. #210 Re: Simple Intake (pictures)
    Jan 2012
    Philadelphia
    it will be fine the engine doesn't get that hot the plastics not sitting on hot metal, think about all the plastic under the hood that is closer to heat then the intake the factory box is plastic. but wouldn't hurt to go with metal this way is just cheaper
  11. #211 Re: Simple Intake (pictures)
    Sartell, mn
    Pairs, this is surely one of the cleanest intake setups Ive seen on this thread!! :-) I see that it is on an 02 GTP. I would like to order the same parts for my 06 Series III but am wondering what I will have to do with the MAF that currently resides
    just behind the factory airbox Any ideas??
  12. #212 Re: Simple Intake (pictures)
    You'll just have to incorporate it into the intake setup, example: cutting the main piece of pipe in half, setting the MAF in the middle...and getting another set of clamps to secure it there.
    Or, make it super easy...and just bolt a cone filter to the end of the MAF sensor.
  13. #213 Re: Simple Intake (pictures)
    London Ont, Canada
    Quote Originally Posted by Kchase View Post
    check out the link in my signature to my member right, I've got a 05 Gt and i made my own intake reusing the maf. pretty straight forward.
    GT Level Member Erics00LS's Avatar
    Lindenhurst, IL
    Hey OP. Its PVC (polyvinyl chloride) not PCV (positive crankcase ventilation)
    '03 Buick Park Avenue Ultra - a few bolt ons
    http://www.facebook.com/groups/greatlakesareacarenthusiasts
    Lindenhurst, IL
    Dunno if anyone addressed you but roflolol
  16. #216 Re: Simple Intake (pictures)
    SE Level Member LRSLLC's Avatar
    May 2012
    Sandy Hook, CT
    Great idea!! I just purchased a 2000 GTP. I'm loving the car!! I just did mine in about 40 minutes. Just did a test drive and yes... you sure can hear the supercharger now. I spent about $50 on parts. Advanced Auto Parts in my area had several filters and colors to choose from. Got the rest at Lowes and painted the 45 degree street elbow silver using the high temp paint. I will fill it up to see if I have any change in fuel economy. Next will be headers and exhaust work.
  17. #217 Re: Simple Intake (pictures)
    May 2012
    Burlington, Wisconsin
    Finally put mine in and I have to say it surprised me. You can clearly hear it working and the supercharger is a lot louder. Only problem I'm having is finding a way to mount the ECU. So far so good!
  18. #218 Re: Simple Intake (pictures)
    Zip tie the pcm down if it bothers you.
    Mine just sits there.
  19. #219 Re: Simple Intake (pictures)
    May 2012
    I just bungeed it for now. Zip ties are a great idea though. Aren't you worried it'll slide and get screwed up though?
  20. #220 Re: Simple Intake (pictures)
    Nope, its pretty much weather proof and shock proof.
    It hardly moves, unless I hit wash boards on a dirt road.
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
