Thread: Repair ABS Issues [*]
Results 1 to 9 of 9
  1. #1 Repair ABS Issues [*]
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    This writeup on Troubleshooting and Repairing the Anti-Lock Brake System (ABS) has been added to the How To Section and can be found Here
    If people are interested about renting SNAP ON SCANNER (reads abs/engine/transmission/airbags) let me know. As I'm thinking about it, not sure yet though.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  2. #2 Re: Repair ABS Issues
    Schaumburg, IL
    How do I make my title stand out more once I already posted it. I like how under write ups they have different areas color coded and I would like to do that with mine.
  3. #3 Re: Repair ABS Issues
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Does this work the same for a 98 regal?
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Repair ABS Issues
    Oklahoma
    Got your title prefix taken care of. If you look to the left of the title box when you first make your post there is a drop down you can select that contains the title prefixes.
  5. #5 Re: Repair ABS Issues
    Saraland Alabama
    very good info
  6. #6 Re: Repair ABS Issues []
    May 2008
    LITH Illinois
    Where would my EBCM be located? I think I found it under the hood behind my intake. When you did a scan what codes did you come up with? I got code P0856. I was told I need a new Control Module, would this be the case?
  7. #7 Re: Repair ABS Issues []
    GT Level Member BackInBlack's Avatar
    Vermont
    Quote Originally Posted by spidamanSS View Post
    EBTCM is under the driver's side dash, just to the right and above of the parking brake pedal. (GP)
    The GPs are long gone...
  8. #8 Re: Repair ABS Issues []
    May 2008
    LITH Illinois
    I have a 2004 Impala SS but I will check, thanks.
  9. #9 Re: Repair ABS Issues []
    Feb 2008
    Awesome information!
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
  3. Supercharged issues?
    By lt1transam in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2008, 02:56 PM
  4. Tire Issues
    By TFBuckeye in forum Tires & Wheels
    Last Post: 04-18-2008, 08:12 PM
