Thread: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 85
  1. #41 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    SE Level Member rodneypierce's Avatar
    Jan 2012
    Cedar rapids, IA
    Thanks for relinking the video! I have to do the LIM and Valve cover gaskets on my 98 GTP here this spring. Doesnt looks to bad at all.
  2. #42 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    SE Level Member fastmvr's Avatar
    Jan 2012
    Fate, TX (DFW Area)
    Unbelievable Help! I feel empowered now....thanks!
  3. #43 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Mar 2012
    Florida
    I still cant get this link to work. I click it and it opens up a google site but no video. What am i missing?
  4. #44 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Jan 2012
    Fate, TX (DFW Area)
    Quote Originally Posted by keadams View Post
    Must be something with your browser.....I just opened it again. I am using Explorer version 8.......the link (second one listed as most current on the initial post) is working.
  5. #45 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Pennsylvania
    You need Adobe Flash Player, homie. It's a free download.
  6. #46 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Mar 2012
    Florida
    I have all this taken apart now and was wondering what everyone uses to clean the lifter and crank area and such of all the old oil and such? Thanks
  7. #47 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    more oil.
    Take a quart or 2 and dump it all over the vally to wash away any coolant or debris.
    Then once done, drain the oil. Fill with some cheap stuff, run for 10-15 min and change it again with a new filter, you dont want to chance it buy only changing the oil once.
  8. #48 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Mar 2012
    Florida
    Is the temp sensor that threads into the LIM for coolant or oil? I want to replace it while I have it all down but the part number listed on the earlier pages would not come up at our local parts house. Thanks again for all your help.
  9. #49 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Jan 2012
    Fate, TX (DFW Area)
    It is for the coolant....replace your t-stat while you are at it and you will see the temp sensor just inside the opening once you remove the t-stat. NAPA part number TS4052.......for my '04 GTP. Good luck, I am replacing fluids in the next few minutes and testing out my LIM gasket, valve cover gaskets, waterpump, t-stat, coolant temp sensor, injector o-rings, and anything else I broke in the process.....
  10. #50 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Mar 2012
    Florida
    Guys, I completed this and as everyone said it was not really all that bad. I have a few questions though. My temp gauge is pegged out even though I changed the temp sensor on the intake. Why or what would cause that? Also, the supercharger seems to be louder when idling than normal. Should i check the oil on it and if so how. I have owned the car for 10 years and never checked or changed. Thanks again for all the help.
    Jan 2012
    Fate, TX (DFW Area)
    Did you bleed out your coolant when you were done? Took several times to get all of the air out of mine. Idk about the SC but would believe that the oil should be changed. I know there is a good thread somewhere on this site regarding that subject.
  12. #52 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Nov 2011
    Virginia
    Do I need to have the engine at TDC when I tighten the rocker bolts? Some sites say I do and others say I don't. If I do how exactly do I find TDC? I know it involves turning the camshaft but thats about it
  13. #53 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    man ive got to do this soon and im not looking forward to this.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  14. #54 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Vail, CO
    i dont understand how this much work is done so quickly. i just changed my coupler and it took me 2 days, and it also was the most frustrating thing ive ever done. and that was supposed to be easy. i dont know how you mechanic guys do this crap
  15. #55 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Sep 2011
    palm harbor florida
    im 17 and it took me about 2 hours you just gotta be paitenet and if you get mad just walk away before your break something.
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Bringing this thread up to let you guys know this video was just posted on YouTube thanks to Allen K. Enjoy
    http://www.youtube.com/watch?v=-2ZbF...e_gdata_player
    Sent from my SGH-T679 using Tapatalk 2
  17. #57 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Pennsylvania
    Good to know that cat's still around.
  18. #58 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Aug 2012
    Cedar Rapids, Iowa
    Soooo. I just did this and put headers and exhaust on all at once... Now I gotta know, what happens if you forgot to put sealant on the lower intake bolts?
  19. #59 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    the bolts will leak coolant over time.
  20. #60 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Aug 2012
    Cedar Rapids, Iowa
    GREAT!! I should have known too, just like any SBF or SBC need sealant.. I just got it running yesterday too, well I might as well rip the blower off it again. Too many beers and in a hurry
  1. Upper Intake Manifold Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 01-06-2012, 10:34 AM
  2. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
  3. Lower Control Arms
    By SyntheticShield in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:55 PM
