Thread: Wiring an Aeroforce Interceptor Scangauge
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Wiring an Aeroforce Interceptor Scangauge
    Donating Users Warbeaver's Avatar
    St. Louis
    Lets wire an Aeroforce Reason I am doing this simple writeup is because of the frequency of questions that have been asked recently about how to wire one of these up. It is very simple, but here is how to do it, with pictures!
    *note* I do not know specifically what year grand prixs need the power wire or not. Mine was a 2002 and it needed it. A guy I know has a 98 and it didnt need the power. Way to tell is plug the obd2 plug into the obd2 port, and turn the car on. It will power on. Turn the car off, take the key out, then put the key back in to restart the car. If the aeroforce will not display correctly, you need the power wire. It should be a blank screen and the red annunciator lights will come on.
    Start by removing the jumper on the back of the gauge. It is a little red or black thing that looks like this:
    Next, you will need these to things: a wire terminal/splice and 16 gauge wire. You can use a wire that is bigger than the wire going to the aeroforce but do not use anything smaller. 16-18 should be about right.
    Now, feed the gray obd2 wire (feed it using the end that plugs into the gauge) from the floorboard, up through the side panel, and then finally up through the side of the dash where the gauge pod is. Feed this through the hole in the gauge pod where the gauge will sit and plug the wire into the gauge. (*Note: do not connect the obd2 plug yet)
    Now, Take the red power wire that comes with the gauge and splice the exension wire to it. Run the wire through the hole of the gauge pod first and connect it to the gauge. Run the wire down to the floorboard instead of up like i did with the obd2.
    *ignore the white wire, that is for my voltmeter gauge. See the red wire and the gray obd2 plug at the top of the picture.
    *again, notice the gray obd2 and the red power
    Run the power wire over towards the glovebox. You are aiming for the fusebox in the glove compartment. (never mind the white wire)
    There should be some space under the glovebox, near the fuses where the wire can come up. Run the wire up and give yourself some working room to connect the wire to the Little Fuse Add-A-Circuit. These run about $8-10 at your autoparts store. I found mine at Autozone. Reason I use these as much as possible is it saves you the trouble of having to tap into factory ignition wires.
    It is just like splicing any other wire with a terminal. Just put the wire in the terminal, and pinch closed. Take out your PGM, Mall PGM, or IGN fuse, and place that fuse into the Add-A-Circuit. (i used the PGM). Add another 10A fuse into the other slot on the Add-a Circuit. (you should have two fuses connected to it. Then plug the Add-a-Circuit back into the fuse block where you removed the fuse from.
    (* I actually have both gauges wired this way for power, but i removed one in the picture. Aeroforce is in the PGM slot and my voltmeter is in the IGN slot)
    Now, you may connect the obd2 plug.
    Start the car and enjoy!
    There are directions that come with the aeroforce. Make sure you read those as well for proper startup and programming.
  2. #2 Re: Wiring an Aeroforce Interceptor Scangauge
    You didn't say what to do on the other side of the wire.
  3. #3 Re: Wiring an Aeroforce Interceptor Scangauge
    St. Louis
    sorry fixed.
  4. #4 Re: Wiring an Aeroforce Interceptor Scangauge
    Banned
    CT
    Nice writeup THANKS!!!
  5. #5 Re: Wiring an Aeroforce Interceptor Scangauge
    Apr 2009
    stockton ca
    i bought it used it didnt have the little red jumper
    it has 2 wires coming off the main harness and a spade connector coming off it i could show pics if needed
  6. #6 Re: Wiring an Aeroforce Interceptor Scangauge
    GT Level Member Joe m's Avatar
    mesa,az
    mine didnt have a jumper either. it doesnt matter cuz you gotta take the jumper off anyway.
    mods - ssac headers,custom intake,ported blower, cut lim for i/c, al104's,180*t-stat,3.4.
  7. #7 Re: Wiring an Aeroforce Interceptor Scangauge
    St. Louis
    for those of you wondering what all an aeroforce does, follow this link:
    Aeroforce Technology Inc | Products - Interceptor
    hopefully this answers all of your questions
  8. #8 Re: Wiring an Aeroforce Interceptor Scangauge
    WI
    Just got an interceptor used and all i have is the OBD2 plug/wire harness, theres the 3 connetor points above where it plugs in on the back of the gauge, I guess where do have the 12 volt power wire go to on the back of the gauge? pic would be awesome, mines an 04
    i have no power on the gauge when i start my car...
  9. #9 Re: Wiring an Aeroforce Interceptor Scangauge
    Minnesota
    Has anyone hard wired this into the OBDII plug instead of just plugging it in or is that not possible?
  10. #10 Re: Wiring an Aeroforce Interceptor Scangauge
    Waukesha, WI
    i think that wouldnt be wortht the hassle, plus you can just sell it if you demod ever
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  11. #11 Re: Wiring an Aeroforce Interceptor Scangauge
    Grand Island, Nebraska
    I think you can buy the power adapter thing separate from the aeroforce sight. I also have the power issue but I also just unplug it and plug it back in until it works. Its annoying but oh well.
  12. #12 Re: Wiring an Aeroforce Interceptor Scangauge
    Wichita
    I just got mine today. It turns on and says 'annunciator not setup' then it turns back off. Its the correct model scan gauge PT401. Idk how to fix it the manual at aeroforce.com wasnt helpful about this issue.
  13. #13 Re: Wiring an Aeroforce Interceptor Scangauge
    Houston
    The annunciator is just the warning lights. It will say that until you set them up, but wont cause it not to work. Is is hard wired and did you remove the jumper?
  14. #14 Re: Wiring an Aeroforce Interceptor Scangauge
    Wichita
    Nvm I got it. Took me a minute.
  15. #15 Re: Wiring an Aeroforce Interceptor Scangauge
    SE Level Member KadenGT's Avatar
    Jul 2011
    wisconsin
    sorry to bring up a dead thread, but i don't fully understand what the point of this gauge is or does
  16. #16 Re: Wiring an Aeroforce Interceptor Scangauge
    Waukesha, WI
    scan your iats, knock retard, coolant temps, commanded timing, fuel trims, etc.
    RayRay
    92 Turbo miata
    02 lexus is300
  17. #17 Re: Wiring an Aeroforce Interceptor Scangauge
    Basically its downsized version of an obd2 hand held scanner..... Its a very very useful gauge and in my opinion is one of the best after market gauges you can have in your car.
    Snorlax strikes again.
  18. #18 Re: Wiring an Aeroforce Interceptor Scangauge
    May 2011
    Waterford Michigan
    My add a circuit does not fit into where my fuses go and do I have to do anything with the other two wires coming off the gauge ( green and white wires)??
  19. #19 Re: Wiring an Aeroforce Interceptor Scangauge
    How does it not fit?
    You take 1 one fuse out, stick it in its place and add it to the side and thats it.
    green and white wires you wont do anything with.
  20. #20 Re: Wiring an Aeroforce Interceptor Scangauge
    May 2011
    Waterford Michigan
    The add a fuses plugs into where I took the 10amp fuse out?
  1. Aeroforce Interceptor-where to purchase?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-16-2009, 12:30 AM
  2. scangauge II vs. aeroforce interceptor
    By kyle99gtp in forum General Tech Discussion
    Last Post: 06-25-2008, 09:48 PM
