When you arm the alarm system the headlights flash and horn chirps to confirm that it is locked, but short flashes are ont good for both the bulbs and ballasts of HID headlights, but there is a simple solution that doesnt require any wiring changes and can be done in less than five minutes.
1. First, turn the ignition key to LOCK or OFF
2. Remove the MALL PGM fuse found in the glove box
3. Turn ignition key to accesory (counter clockwise) you will hear a couple of chimes if you have done everything correctly so far
4. Press the LOCK key on your key fob, count the number of chimes you hear.
5. Press the LOCK button on the key fob until you hear only one chime
6. Turn key back to where you can remove it and replace the MALL PGM fuse
DONE! now you wont reduce the life of your HID headlights
