Thread: Fixing your intermittent stalling problem!
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Fixing your intermittent stalling problem! Pump Resistor
    SE Level Member sandobar's Avatar
    Dec 2011
    NY
    What image i don't see anything my car stalls out once in a blue i have had the car about two months now and it stalled out about 3 time since i have had it but then starts back up just if i stop at a light or stop sign but it hasn't done it in a while
  2. #22 Re: Fixing your intermittent stalling problem!
    Anderson, SC
    I'm a newbie to this forum - just joined today. GP GT 2000. Just started having a similar problem to what was discussed in the header.
    As member sandobar mentions in the previous post - where is the image? It would be REAL helpful.
    Thanks in advance!
  3. #23 Re: Fixing your intermittent stalling problem!
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    Not sure if this is what you are looking for but on my 97 GTP I followed this and it worked. I'm not sure if it is the same on a GT or not.
  4. #24 Re: Fixing your intermittent stalling problem!
    Donating Users
    Sod, WV
    I have been using Pittman06's directions for nearly 1 year, and still driving like a champ. Thanks again, Pittman06.
  5. #25 Re: Fixing your intermittent stalling problem!
    SE Level Member mintygp's Avatar
    Mar 2013
    Winterpeg, Canada
    I would like to know if this also applies to a 2001 GT? And, what direction does the tab get bent if I have this? Up or down?
  6. #26 Re: Fixing your intermittent stalling problem!
    Mar 2013
    Winterpeg, Canada
    From what I can see is the tab just flat, would have been a lot easier if it shows the after picture, but hey.
  7. #27 Re: Fixing your intermittent stalling problem!
    Quote Originally Posted by mintygp View Post
    Its only able to work on the 97-00 cars with a the supercharged L67 motor.
  8. #28 Re: Fixing your intermittent stalling problem!
    SE Level Member CRU1Z3R's Avatar
    Apr 2012
    Western, KY
    Any help would be appreciated!!!
  9. #29 Re: Fixing your intermittent stalling problem!
    Apr 2012
    Western, KY
    so here's a scan i recorded with hptuners software, if anyone can make heads or tails of it...
    filehosting.org | Download | gtp.hpl
  10. #30 Re: Fixing your intermittent stalling problem!
    May 2013
    Surprise, AZ
    I have a '97 GTP and it too is suffering from the starts up and dies right away. I cut the pigtail for the old fuel pump resistor and spliced the ends together to bypass it while I was waiting for the part. I drove it last night about 6 miles, sat for a couple of hours, and then it would not start. Same old symptoms, but the resistor was bypassed! I got the resistor this morning, and installed it. Went to take the kid to school, and the car died on me again only 1/2 mile from my house. It always starts right up with the throttle past half, and I finally got it back home. When I got home, it was still running, so I pulled the speed control relay out, and the car did not die. I went for a 10 mile cruise with the relay out, and the car ran fine. I got home and let it idle for 15 minutes with no problems. I turned the car on and off about 10 times. Should the car run with the speed control relay out of the car? I have checked the fuel pressure, 45 at idle, and 52 off idle. Also, at idle, I have 12.6 volts going to the resistor, and 10.2 volts coming out.
  11. #31 Re: Fixing your intermittent stalling problem!
    SE Level Member Konvinced89's Avatar
    Layton, UT
    Just wanna verify, you mean NOT 03s? I wanted to try this bc Im trying to do the CPS and having trouble getting the harm balancer nut off. I just took off the lid, and my fuse box doesnt have a relay there...?
    03 Ivory White GTP: Overkill PCM, MagnaFlow, ubend delete, 3.4/3.8 MPS, AGX/B&G, Buick strut bar, and a big \*/ sticker so they know what just whined by.
  1. Stalling problem
    By 97gp97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2011, 09:28 AM
  2. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  3. Intermittent dying problem with 00 GTP
    By ls6velless454 in forum General Tech Discussion
    Last Post: 04-08-2010, 12:11 PM
  4. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  5. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
