Thread: Porting Your Supercharger
Results 41 to 60 of 70
  1. #41 Re: Porting Your Supercharger
    SE Level Member pman64's Avatar
    Central Illinois
    What happens if you just cut the entire V out?
  2. #42 Re: Porting Your Supercharger
    Quote Originally Posted by pman64 View Post
    Then the rotors have nothing there to push against...so you wouldn't make any boost at all...and you'd have a 50 pound metal air intake instead.
  3. #43 Re: Porting Your Supercharger
    Central Illinois
    Well, I could understand where your comin from. Got it back together and it puts out a little more boost. Ive got full boost at about half throttle.
  4. #44 Re: Porting Your Supercharger
    michigan
    Sooooo, does doing this make a considerable amount of difference? I haven't heard anybody on this thread sounding all excited to have more power with a newly ported sc. Of course I understand it all depends on what other mods are done to each vehicle. But on a broad spectrum, stock to heavily modded, who's feeling the power?
  5. #45 Re: Porting Your Supercharger
    Minnesota
    Its more of a supporting mod to help air flow and reduce KR
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  6. #46 Re: Porting Your Supercharger
    Charles City, IA
    not much of a diff in power, the whine is nice tho
    SMGPFC Two Nipple General
  7. #47 Re: Porting Your Supercharger
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I haven't ran that gen 3 I ported yet, but my stock gen V which is like a ported out gen 3 and before I did anything it felt a bit faster... Not a whole lot but noticeable.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  8. #48 Re: Porting Your Supercharger
    michigan
    Sounds like too much work for very minimal gains.....to me anyways. I may be wrong though...aaaand im sure someone below will tell me why im wrong. Lol
  9. #49 Re: Porting Your Supercharger
    Mullet Member Wotgtp's Avatar
    Connecticut
    Has anyone done a dyno/benchflow comparision between a gen three ported blower and a gen 5?
  10. #50 Re: Porting Your Supercharger
    Unsure, but compare the inlet side.
    Thats where the gains are made.
    You can't port the Gen III much because of the PCV system.
  11. #51 Re: Porting Your Supercharger
    Connecticut
    That makes sense. I was just wondering.
  12. #52 Re: Porting Your Supercharger
    SE Level Member SMazza's Avatar
    Jun 2011
    Eastern Pennsylvania
    The main difficulty with M90 blowers is getting the air in so the rotor cavity is filled. These particular blowers (GM Gen 3 and Gev 5) have pretty generous inlet ports to begin with, so the main problem is out of the way already.
    If you compare the inlet ports on these blowers to the early M90s as used on the Thunderbird SC, you will see how much the inlet has grown over the years. Aftermarket products like the Magnum Powers MPX case have gone even bigger on the inlet that these blowers ... but those are designed to be spun very fast and give major high-RPM boost. There is a trade-off between minimizing boost leakage at low RPMs and maximizing airflow at high RPMs, and the MPX is skewed toward maximum performance.
    Here is how to tell how far is too far. At the point where the leading rotor opens to the outlet port, the trailing rotor had better not be open to the inlet port. Otherwise, the pressurized air in the LIM will force air back out the inlet port. So that is the key thing to check.
    Don't worry about the two small silencer ports ... they might let a small amount of air bleed back from the LIM, but it is by design, to keep the blower less whiny. Old people buy Regals, you know.
    As for beveling the outlet port: Don't bother beveling the edge facing you. What would it do, help the air make the turn out of the outlet and shoot to the sides of the case? That doesn't make sense. Beveling (or filleting) the edge on the inside of the case is a good idea. It will help the air make the turn out of the case. Removing the bolt bosses (or not) is up to you. At a minimum, remove a little material to smooth out the airflow from the backside of the bosses out of the case.
    The other problem that the early M90 had was control of the rotor clearances. The coated rotors in the second generation helped that issue, and the Gen 3 and Gen5 benefit from it.
  13. #53 Re: Porting Your Supercharger
    Aug 2011
    michigan
    I am looking at porting do you have to tune it?
  14. #54 Re: Porting Your Supercharger
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    1) barely any coolant, dont worry about draining it.
    2) not sure on this one, i used a CNC lathe so it only took me 10 minutes
    3) the throttle body gasket MIGHT need to be replaced. if its new enough it might be okay, but otherwise its a non-reusable gasket.
    How did you do it on a CNC lathe? i was going to do it on a full CNC machine, but a lathe sounds much easier
    Thanks
  15. #55 Re: Porting Your Supercharger
  16. #56 Re: Porting Your Supercharger
    SE Level Member SuperchargedFiero's Avatar
    Jul 2011
    The Netherlands
    One other thing is it true that when closing the two small squares or how u spell it
    The charger will whistle more
    And second how do they close it beqouse when using a welding machine al the heat in the
    Aluminum will bent the charger
    Am I wrong ,
  17. #57 Re: Porting Your Supercharger
    its not worth the risk for doing it. i had mine sealed up and the blower didnt sound much different.
  18. #58 Re: Porting Your Supercharger
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    what is considered OVER PORTING?
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  19. #59 Re: Porting Your Supercharger
    making the triangle of the outlet any bigger towards the inlet side of the blower case.
  20. #60 Re: Porting Your Supercharger
    Nov 2011
    Omaha, NE
    Quote Originally Posted by SuperchargedFiero View Post
    Am I wrong ,
    Some people have talked about blocking those "silencer holes" in previous threads, however no one has come to conclusion on the best way to do so really. All I have heard is to not use JB Weld or anything else that could break up. Those who have said it is very noticeable sound difference and you can even hear the supercharger whistling on idle.
  1. Porting Gen 5 M90
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:38 AM
  2. porting supercharger specs please
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 01:18 AM
  3. TB Porting ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-01-2009, 12:10 AM
  4. Porting the LIM and SC?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2009, 09:41 AM
  5. porting
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2008, 05:29 PM
