Instructions: Unplug EGR valve from wiring harness. Unbolt EGR inlet tube from exhaust manifold (13mm). Unbolt EGR outlet tube from lower intake manifold (13mm). Unbolt two bolts holding the EGR valve pedestal to the head (13mm or 15mm). Remove entire EGR system from engine bay! Finally, find a way to seal the two holes you have just exposed. You should have something that looks like the picture below. Notice that the inlet tube is cut. That's how I got the collar off (it had a leak next to the inlet, anyway).
You'll have to either make or buy block-off plates or have the holes welded shut. I placed a penny in the old retaining collar to cover the hole from the exhaust manifold and RTV'd it to make sure it would seal, then I bolted it in just like the original EGR inlet tube. Next, I made a block-off plate out of a piece of sheet steel to bolt to the LIM. Put a little RTV around the hole, and bolt 'er down! Of course, now I have the hole blocked in the blower casing, too.
