Thread: Blend Door Actuator Replacement
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 90
  1. #61 Re: Blend Door Actuator Replacement
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by GT03 View Post
    Yep, since mine was low, I added a refrigerant that contained a stop-leak. Still working OK after ~year.
    I'm not sure but I think the AC Pro may also have a stop leak in it. You'd think in this day and age all the recgarge kits should have it.
    2002 GT Red, Stock, Work In Progress..........
  2. #62 Re: Blend Door Actuator Replacement
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    when you pump the AC system full of additives, that leaves less room for refrigerant and also lowers its ability to cool the air.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #63 Re: Blend Door Actuator Replacement
    Donating Users
    Jul 2013
    SoCal
    Quote Originally Posted by TEK310 View Post
    my passenger side actuator had a cracked gear, replaced it but im having trouble getting them to close the doors completely. plus im back to air blowing through all vents, its very frustrating, and module does not switch from recirc to outside and vice versa. all vac lines are right, no leaks. im about to sell this damn car.
    if anyone would, take a picture of the blend door actuator open so i can see the inside gears, so i can manually calibrate mine, ive messed mine up and need to see where the position sensor gear is relative to the drive gear.
    There is a YouTube vid of this.
  4. #64 Re: Blend Door Actuator Replacement
    Jul 2014
    Phoenix
    A helpful tip when pulling out that drivers side actuator (97-03). After removing the carpeted board above the pedals and the plastic panel below the steering wheel, pull off the black metal bracket the aforementioned plastic piece was attached to (four bolts and a couple screws). This gives you a straight shot to the LH blend actuator (I'm 6'5" with big hands and was able to get in there with little issue). Use a 7/32" deep socket to remove the three small bolts from the actuator and unplug (no extension or ratchet required). Once panels are out, should only take a couple minutes to pull the actuator! Hope this helps...
  5. #65 Re: Blend Door Actuator Replacement
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    Would this be my problem. I have dual digital control, and when i go from defrost to floor it doesnt move. it stays on defrost.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  6. #66 Re: Blend Door Actuator Replacement
    Feb 2010
    TN
    Whoever decided to repost this THANK YOU!!! I have to do this soon, now does anyone know the part # for 1997 Grand prix GT with the regular heat not control?
    Thanks again
  7. #67 Re: Blend Door Actuator Replacement
    Jan 2013
    Tennessee
    Quote Originally Posted by 1996pontiac View Post
    Mine does Something similar, on Full blast, the air alway blows partly out of the defrost instead of vents (very weak at vents). Actually, it seems Almost like the blend door actuator for the defrost is stuck in a halfway position. Can't seem to locate the actuator that controls it, is it a vacuum control? Does 1 vacuum unit control all of the blend doors?
    Also, I had the passenger side vent blow hot with the A/C on a few times the other day, after turning off/on and cycling the vents, etc it seemed to fix it but I am wondering if the head unit (temp/vent/heat/AC selector with LCD) might be going bad? Do these "go bad" and/or need replacing often?
    Anyone else ever encounter these issues and have a solution? Aggrevating Auto Climate B.S....wish I had the manual (simpler) version.
  8. #68 Re: Blend Door Actuator Replacement
    the blend door actuator in the first post of this how to only controls the heat or cold air, or mix of them.
    the air flow direction is all vacuum powered. search around for more info on this, theres a ton of threads that cover it.
  9. #69 Re: Blend Door Actuator Replacement
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    I'm gonna go out on a limb and assume this write-up isn't for 97-03... because following the steps listed would still require my arm to slither like a snake with a screw driver the size of a baby spoon to remove the driver's side actuator...
  10. #70 Re: Blend Door Actuator Replacement
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by Centauri View Post
    Oh, it's correct, I have done it. Pain in the ass, has to be all done by feel. It can be done though, just take your time.
  11. #71 Re: Blend Door Actuator Replacement
    it worked for my 98 regal, and i got large hands, it was no fun to change the d/s. iirc only one screw went back in to hold it in place.
    you can see it, you need a flashlight and then you peek through the edge of the open lower dash.
  12. #72 Re: Blend Door Actuator Replacement
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    sub'd
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  13. #73 Re: Blend Door Actuator Replacement
    Sep 2014
    St. Paul, MN
    Well... that was ****ing awful. I'm 6'6" and there are few things in my life that have been more awkward to accomplish physically.
    Word to the wise; raise rear of your driver's seat and lower the front, then drop the back all the way down; try to make it like a plank for your body. Then roll up a pillow or something just in front of the seat on the floor for extra back support. Go at the operation with your head at the pedals looking directly up at the actuator.
    It took things from impossible to merely miserable. And I even got both screws back in.
  14. #74 Re: Blend Door Actuator Replacement
    lol. im also 6'6, i did the whole job on my knees out side the car door, i peeked in at the actuator from the edge of the dash with a flash light, then mushed my 3x wearing gloves hands up in there lol
  15. #75 Re: Blend Door Actuator Replacement
    Enfield, CT
    x2 except I'm not as tall as Scotty lol
  16. #76 Re: Blend Door Actuator Replacement
    Jun 2016
    sarnia ont canada
    that is a good write up except you need to tell people that the pad is removed with 7mm socket and those 4 bigger bolts on the metal part under the steer wheel is a 10mm socket ; plus they are recessed so you need a extension on your driver with a wobble end because they are not directly aligned with those 2 holes ; the other thing is that the 2 little screw type bolts that hold that actuator in place are 7/32 socket and if you do not have a palm drive it is near impossible to get them out ; after removing the pad and plastic panel plus that metal support under the steering wheel on the left side or drivers side its very difficult to get at that actuator because of the harness that runs in front of it ; it is a very tight spot and you need to get your hand up to reach it laying near horizontal on your back or on your knees from just outside of the drivers door ; trust me if you do not have a metric socket set with extensions and a palm drive to get those 2 small bolts out you'll be cursing at pontiac engineering ; these forums are nice but lets start telling folks what kind of sockets you need for various bolts ; most on i';d say 2001 and up pontiacs are a mixture of metric and standard ; those 2 actuator ones I Tried a 6 mm but it was too big ;5mm was too small so next I got on a 1/4 " drive 7/32 " and it fit perfectly ; so the other thing here is on all above sockets make sure you are using ones meant for a 1/4 " drive as the 3/8" drive ones are too big ; thank you appinboy ;
  17. #77 Re: Blend Door Actuator Replacement
    i wear 3x gloves. tell me about it. only one of the actuators bolts went back in too. refused to fight with it any longer and tear up my hands a bit more.
  18. #78 Re: Blend Door Actuator Replacement
    Jun 2016
    sarnia ont canada
    like some one else said in here laying on your back with a pillow on the floor would help with reaching up ;this a tight spot and even with a 7/32 deep socket and 1/4 drive rachet it is a tight spot ; you are further ahead with a palm drive rachet ; also make sure you get the right blend door actuator mean for your particular car ; I got one from a parts store that had only 4 pins on the electrical end my has 6 pins and it did not work properly but thank god I tried it before I reinstalled everything ;
    Last edited by appinboy; 06-20-2016 at 09:49 AM. Reason: forgot the electrical end plus wrong part #
  19. #79 Re: Blend Door Actuator Replacement
    Jun 2016
    sarnia ont canada
    also it helps to have a palm drive ratchet with 1/4 drive deep 7/32 socket ; and make sure you are getting a better quality blend door actuator ; those cheap knock offs from china do not have any stops on the motor at each end of lets say cold and hot so if you motor signal screws up it will keep driving that door flap till it warps or the plastic drive snaps on it ; just beware ; then you will be into some major repairs ;on the back of your actuator the part side that sits against the housing make sure on that drive it has a stop on each end of its travel ;yes the cheap ones do work but if they fail you will wish you had bought that more expensive part
  20. #80 Re: Blend Door Actuator Replacement
    Jun 2016
    sarnia ont canada
    also which way should your temp switch be in in hot or cold when installing the actuator motor ; i know that actuator only goes on one way on that post of the door but manually you can put the door in hot or cold with the actuator not installed to see if this is your problem ;thank you
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
