Thread: How-to: 5 button DIC upgrade (no reprogram necessary) (04+) [*]
Results 1 to 20 of 30
  1. #1 How-to: 5 button DIC upgrade (no reprogram necessary) (04+) [*]
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    This writeup on the 04+ Drivers Information Center Upgrade has been added to the How To section and can be found HERE.
  2. #2 Re: How-to: 5 button DIC upgrade (no reprogram necessary)
    Oklahoma
    Okay. Allow me to ask the question 'cause I just dont know. What is the advantage of doing this or what does it give me that I currently do not have with my current D.I.C.?
  3. #3 Re: How-to: 5 button DIC upgrade (no reprogram necessary)
    Williamsport, PA
    the 3 button DIC that comes standard with the base model 04+ only has trip computer and a very general oil monitoring system. The 5 button model has trans temp gauge, volt gauge, boost gague (if applicable), outside temperature gauge, compass, timer, oil % remaining, trip computers, avg speed, avg fuel economy, instant fuel economy, range, etc. This upgrade only applies to the 04+ crowd. You could put the DIC into any other car that uses the Class 2 Serial Data bus and have these features as well though I suppose.
  4. #4 Re: How-to: 5 button DIC upgrade (no reprogram necessary)
    Oklahoma
    Crap, why must you tempt me so. I read that list and Im like HECK YEAH, where do I get one for my 2001. I really dont like you right now.
  5. #5 Re: How-to: 5 button DIC upgrade (no reprogram necessary)
    Williamsport, PA
    haha, sorry... 04+ only.
  6. #6 Re: How-to: 5 button DIC upgrade (no reprogram necessary)
    Oklahoma
    You're fired. Pick up your things and get out.
  7. #7 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    Williamsport, PA
    Hey, if you read the introduction, you would see, it does say 04+
  8. #8 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    Oklahoma
    You're still fired, now get out.
  9. #9 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    Williamsport, PA
    hey, i'm going to post my heads up display install how-to soon... don't get it confused... just for the 04+ models also
  10. #10 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    Oklahoma
    Ooooooo, its on now!
  11. #11 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i'm curious as to why you bothered drilling holes in your existing surround? wouldnt you want the 3 hole button dash piece for later if you have to put the 3 button one in to go to the dealer?
  12. #12 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    Williamsport, PA
    I thought of it but decided I may actually swap the controls inside the 5 button and just have the xtra 2 buttons not work properly. The mileage would still show up correct and I don't have to keep track of the extra piece.
  13. #13 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    SW Chicago Suburbs
    Quote Originally Posted by TyroElite View Post
    i would expect that the functionality of the 3 button brain in what looks to be a 5 button would confuse/concern dealer...
    maybe not though
    on a side note, i bet you could have the mileage in the 5 button programmed to match your vehicle... i would think a spedo repair shop could do it. (perhaps calling specmo.com) ?
  14. #14 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    Williamsport, PA
    it is possible but not very easily done and usually costs (from what I've heard) quite a bit of money. Plus, sending it away still means you can't drive the car while its out. I don't think they would care (or use) the extra buttons. They are only for volts and trans temp and oil life and such and fuel economy. The actual mileage shows up as soon as you open the door or push the trip button and that still works no matter the buttons that are connected. I'm thinking mostly for inspections when they check the miles. Even though for warantee work, the shop could look at either the BCM or the DIC to see what they are... if they match, I don't think they'd care what buttons work and what don't.
  15. #15 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+)
    SW Chicago Suburbs
    i suppose so.
    though if you did want to get it programmed, you'd just need to have it programmed for MORE miles than your car has... then when your car hits that mileage, plug it in! :P
  16. #16 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+) []
    Fayetteville, AR
    Thanks for all that you're doing for the 04+ GP community Tyro, youre the sh*t man!! Hook me up with that HUD write up,lol!
  17. #17 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+) []
    SE Level Member Randy_W's Avatar
    May 2008
    sALISBURY, md
    What if you are not worried about the miles on the clock and just want the 5 button, what wiring is needed?
  18. #18 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+) []
    Fayetteville, AR
    okay...im confused, the 5 button DIC and trim plate setup that Ed Morad sells isnt just a plug and play type of thing? or if you were to do it the "plug and play" way then you would have to have your odometer sent off to be reprogrammed? So this is why you did this mod the way you did as opposed to just plug and play?
  19. #19 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+) []
    SW Chicago Suburbs
    Quote Originally Posted by Quicksilver_GP View Post
    the DIC brain tracks mileage, in adition to the speedometer cluster. if you dont care that they match, you can just plug it in and go. if you want the mileage to be correct, you need to have the mileage programmed into the DIC. (way around this is if you could find a DIC that had a bit more miles than your car, then when your car is to that same mileage, plug it in) -- tricky to catch the exact mileage perhaps though.
  20. #20 Re: How-to: 5 button DIC upgrade (no reprogram necessary) (04+) []
    Williamsport, PA
    Yep, the only place you (or a service/inspection station) can see the mileage is on the DIC. So, if you don't either find one with more mileage than what you have and swap them at precicely the same moment or keep the original wired up it could end up getting you in some odometer fraud issues. Something you deffinately don't want.
  1. 3-button to 5-button DIC (04+)
    By TyroElite in forum General Tech Discussion
    Last Post: 08-19-2010, 01:46 PM
  2. When is the Non-HD to HD Trans Upgrade Needed
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2008, 03:53 PM
  3. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
