Thread: how to make your projectors worth the money for cheap...
Results 1 to 12 of 12
  1. #1 how to make your projectors worth the money for cheap...
    Joliet, IL
    first do this-ClubGP Message Forum troubleshooting
    then below and you will have NO BOUNCE
    i adjusted mine so they fit nice and i re did the weather stripping on them fukk the bs weather strip they come with i now have a single piece running around the corners and all the way under neath the lights (automotive weather stripping from lowes/home depot)....no bounce AT ALL, tight fit, no big gaps just small ones on the inside no more than the stockers tho...they are perfect now....def glad i invested in them...
    i especially like how my thicker strip tightened up the corner fit.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: how to make your projectors worth the money for cheap...
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    just followed this "how to" the other day, helped a lot. accidentally cut to short but created some new cutoffs. made it way harder than it should of been but everything turned out alright.
  3. #3 Re: how to make your projectors worth the money for cheap...
    GT Level Member GTBabyGirl's Avatar
    Pittsburgh, PA
    i know this is an old thread but do you notice with yours like a cut off on vision?
    *sig too tall*
  4. #4 Re: how to make your projectors worth the money for cheap...
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    What?
    2006 Mitsubishi Evo IX MR
  5. #5 Re: how to make your projectors worth the money for cheap...
    Jul 2008
    sumter,south carolina
    u talkin bout low beams?
    02 GTP with mods 05 GP for DD
  6. #6 Re: how to make your projectors worth the money for cheap...
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    yup i know get pissed at me if u want to... But is there any other places with instructions tot he no bounce mod? bcuz there is no pics in that one...
  7. #7 Re: how to make your projectors worth the money for cheap...
    Jun 2010
    ontario
    The weather stiping idea works pretty dang good!!!
    if you ever break your projector's brackets, fix them with oem brackets from the scrappers;
    your going to have to cut the stock one and use a plastic molder to bond it together, replace all part you want to beef up
    if the cleat coat is peeling, wet-sand and buff/polish then then re-apply some clear coat, should work good
    and the bouncing if there still is some: the oem bracket would've fixed most of it, the rest can be done by making sure all the screws and bolts on the projector/bracket are tight, then there is a little mod that i am planning and it is currently a secret but will be revealed sometime in the near future, it will give off a better look and eliminate the bouncing left
  8. #8 Re: how to make your projectors worth the money for cheap...
    Jan 2012
    Philadelphia
    yea i used weather stripping on my lights i got he same exact ones its the one way to go with these lights !
  9. #9 Re: how to make your projectors worth the money for cheap...
    SE Level Member Konvinced89's Avatar
    Layton, UT
    i didnt see this before when i was trying to fix mine, wouldve helped alot but i got zipties, and basically aimed the lights a little lower than i wanted, then tied the bracket that holds the light's vertical adjustment to the car's metal bracket that the housing sits in. it's a little ghetto but it works okay, i only see them bounce over really harsh bumps or continuous rough sections of road.
  10. #10 Re: how to make your projectors worth the money for cheap...
    Jan 2012
    Philadelphia
    i just wish they would fit like OEM
  11. #11 Re: how to make your projectors worth the money for cheap...
    SE Level Member Panthers144's Avatar
    Nov 2011
    Pennsylvania
    what brand lights are these? and whats the bulb size? direct fit plug and play or not?
  12. #12 Re: how to make your projectors worth the money for cheap...
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by Panthers144 View Post
    Search. There is plenty of info about these on this forum.
  1. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  2. Need money asap.... F/s
    By pdrr98 in forum Introductions/Noob Questions
    Last Post: 07-03-2009, 12:31 AM
