Thread: Make A 4" Fenderwell Intake (FWI)[*]
Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 199
  1. #61 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GXP Level Member
    Theworld
    Is there any real difference between this:
    and the FWI
  2. #62 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Charles City, IA
    Yes that is a short ram pulling hot air from the engine bay. The fwi puts the air filter in the fender pulling in cold air. fwi> short ram unless u are using alky/intercooled.
    SMGPFC Two Nipple General
  3. #63 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Canby, MN
    Would i need and clamps or brackets or anything how much did this cost you
  4. #64 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Flint, Michigan
    my question is for vailskiier. I have an 08 with the MAF like yours. How did you go about getting a leeve to fit on the air box side of the MAF. Mine bolts into the air box.. is that how yours is too?
  5. #65 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Nov 2008
    Houston
    I have an 07 and the MAF bolts on the airbox too, it looks like he used the coupler from the original airbox.
  6. #66 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Nov 2008
    Houston
    Heres mine on an 07, needs a bit of cleaning up, but works great.
    Make A 4" Fenderwell Intake (FWI)[*] Attached Images
  7. #67 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    Quote Originally Posted by mike171562 View Post
    thats a 3in pipe... not 4 inch... stock is basically a 3in as well
  8. #68 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Flint, Michigan
    yes but why would you need a 4 inch pipe when the throttle body its going into is only 3 inches. and the MAF is only 3 inches. Doesnt make any sense
  9. #69 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Nov 2008
    Houston
    Thats what I was thinking, if there is a 3 inch bottleneck at the MAF and the throttle body, I did not see that it would make much difference.
  10. #70 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Banned
    Wichita Falls, Texas
    Because some people actually have a set-up that allows 4" all the way through into the blower casing.
  11. #71 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Wausau, WI
    Quote Originally Posted by tlane3546 View Post
    also my MAF is directly on my TB......so for me, the four inches allows for as much possible flow through the bends, angles and the air capacity that the IAT gauge sits........so you are getting a full three inches worth(or whatever max capacity is) into the TB......otherwise these things would not allow a true three inch pipes worth of flow into the TB.
  12. #72 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GXP Level Member
    Theworld
    I don't know if it's just me.. but I can't find a 4" Flexable Elbow anywhere, I tried Home Depot and Lowes.
  13. #73 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Banned
    Quote Originally Posted by KawaFord View Post
    Yeah, your going to have one hell of a time finding it too.
    I can probably get you one, or you can order one off line though.
  14. #74 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GXP Level Member
    Theworld
    I'm just going to hold off on FWI until I have enough $ for a wiz intake.
  15. #75 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Run that by me one more time. That intake is uber fail. Get the TDC instead.
  16. #76 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Wausau, WI
    You look at the TDC FWI yet? better look, and functionality for a better price in my opinion........it is your car though...
  17. #77 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GXP Level Member
    Theworld
    Quote Originally Posted by Liquifire View Post
    Why buy TDC, when you can make one for a fraction of the cost?
  18. #78 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Exactly...so why in the f**k are you going to buy a Wizaired...IDK you just contradicted yourself.
  19. #79 Re: Make A 4" Fenderwell Intake (FWI)[*]
    oh I'll be doing the FWI maybe next week sometime after pay day.
  20. #80 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Flint, Michigan
    i did it and it works awesome.
  1. Make a difference section
    By LowlyfeGTP in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 03:15 PM
